10-30-2022, 07:06 PM | #1 |
Rep 372
Drives: 2023 G80 Comp X-Drive
White Haze Spot on New 2023 G80 BSM
Have this hazy round spot on my hood. Car has only been washed once since pickup. Hand wash only. No wax. Just polish.
Took some Adams Polish with a microfiber to it and did nothing. I have an appointment set for ceramic coating in a couple weeks so I'm guessing the paint correction will take car of it but still curious what people here think. Any quick / easy way for me to handle now so my OCD can chill out for a couple minutes? (The white haze circle is in the middle. All the other noise in the photo is just the ceiling of the garage reflecting.) |
10-31-2022, 04:19 PM | #2 |
Rep 104
So did you polish that area before you said "i took some Adam's polish to it..."?
I wouldn't stress it, it is probably some leftover body panel covering smears or someone at the dealer tried to buff it out with something. If it doesn't have any protection on it, just leave it alone until the paint correction person does their magic and it will come right out and be fine. It looks like, from what I can tell, the pic is a little poor to discern the suspect spot, some light hazing or leftover product. What color paint? |
MunkyTool583.00 |
10-31-2022, 06:57 PM | #3 | |
Rep 372
I had the car hand washed at my usual spot and noticed right when I got home. That's when I took a little spray polish to see if would help. I don't not actually "polish" the car. Doubt it was something they did at the car wash. You're probably right about dealer messing it up. Will try and get a better pick. |
PHXATC82.00 |
10-31-2022, 09:06 PM | #4 |
Rep 1,720
Haze like that is likely from a medium polish and pad (commonly used by a dealer to remove blemish noticed upon arrival). That can (and should have been) followed up with a fine polish and pad. The PPF shop will remedy that during their paint correction process.
MunkyTool583.00 |
11-01-2022, 05:04 PM | #5 | |
Rep 104
I would bet $ that the dealer put some product on there and/or tried to polish it and didn't check it and correct it before delivery. I still wouldn't worry and the paint correction peeps will take care of it before they put the PPF on it. Be sure to point it out so they notice it as well and there's no issues later. Easy fix, PPF installed, and you're off and driving!! |
MunkyTool583.00 |
11-01-2022, 09:08 PM | #6 | ||
Rep 372
PHXATC82.00 |
11-02-2022, 01:55 PM | #7 |
Rep 268
A good one step polish should remove it, most PPF shops will do that before installing their film. Like mention before, its heavy cut compound (old school 3m compound probably) that body shops and dealers use and most do not finish it properly.
MunkyTool583.00 |
