BMW E91 RWD 6MT Unicorn spec
10-30-2022, 09:13 PM | #1 |
Rep 19
Hi all, I am considering selling my Wagon. Please find the details below: BMW E91 328i 6MT, w/ factory sport pack. Black exterior, black (faux) leather interior and a clean title. Mileage: ~101,500 miles VIN: WBAVS13587FV95035 Pictures: https://flic.kr/s/aHBqjAddpK Owners: 5 (I’m the 5th) Title: Clean Location: Michigan 48103 Asking price: $15k I’ve owned the car for 2.5 years, and done about 7,000 miles in that time. It gets driven sufficiently long journeys to keep it working well, and rarely sits in traffic. It runs great, and gets good attention wherever it goes (even more so once they realize the full spec). 1 of 429 rear wheel drive manual E91 wagons they brought to the states, and of those, this is a desirable spec. I’m an enthusiast, and treat the car with respect. The car has only been in Michigan since 2018, and it doesn’t get driven much in the winter, so it’s still pretty clean under there. No rust on any body panel at all. I am pretty meticulous about giving it a rinse if it does get used in salty conditions. This is an enthusiast-spec car, with the following desirable options: - Rear wheel drive - (RWD) - 6-Speed Manual Transmission (6MT) - Factory sport pack - sport suspension + seats + steering wheel - Full adjustable (manual) sports seats - Single hump dash (no sat nav) - Staggered 17” wheel setup (wider at rear) Modifications: - “Carbon Fiber” vinyl wrapped interior - Front splitters (body color matched) - Chrome exhaust tips (stock exhaust) - ZHP gear knob - BMS (Burger Motorsports) clutch stop - BMW Performance pedals (inc. dead pedal) - All weather trunk liner - Genuine BMW oddments tray - Black kidney grilles (original chrome included) - LED angel eyes Included: - All the original manuals and paperwork binder for the car. - Full set of winter wheels with correct TPMS (no low tire pressure dash errors) - All weather mats + carpet mats. - All original parts where applicable. - 2 Keys Recent maintenance: - Clutch + Flywheel - 07/2020 - Wheel bearing - 07/2020 - Windshield - 07/2020 - Valve cover + gasket - 05/2021 - Eccentric shaft sensor - 05/2021 - Oil change + filter - 08/2021 - Coolant change - 08/2021 - Windscreen washer motor - 03/2022 - Front wipers - 03/2022 - Rear brake pads (+ wear sensor) - 06/2022 - Oil change + filter - 07/2022 - Spark plugs - 07/2022 - New ground cable - 08/2022 Known Flaws: - The driver's seat has some minor damage to the leather. I’ve filled it with a repair kit, which has helped it not get any bigger. - The driver’s cup holder doesn’t work properly. You can still use it, but you have to pull it out with a credit card or similar. - There are scratches on every panel and dings on some. It’s a clean, honest, driver-quality car. The interior is pretty clean and complete. - The trim under the carbon fiber wrap is the desirable brush aluminum trim, but it is generally not in great state; hence the wrap. I give the wrap a ‘decent first attempt’ on my behalf; it’s not perfect, but it lifts the interior. - The head unit display is pixelated when the weather is warm - common issue with these. - The aircon could probably use a recharge, it struggles a bit when sat still but works fine when the car is moving.
IG: @dads_e91
