11-05-2022, 07:55 PM | #1 |
Rep 143
Speedometer error?
Last night coming home from a long trip I noticed that there is a discrepancy between all three means of checking my speed.
Set in cruise control at 75mph the GPS speed as indicated by Waze running on an iPhone 13 consistently showed 73mph. The speed indicated on my Escort radar detector showed a consistent 74mph. I find myself wondering if this is an isolated thing or if we all have speedometers that are off. Or could it be that the two GPS indicators are wrong? Furthermore-- I'm wondering if the odometer is also wrong. Does anyone have similar observations? |
11-05-2022, 08:18 PM | #2 |
Rep 355
my speedometer is roughly 1-2 MPH higher from my GPS on my radar detector. also, I noticed the same when you pass those radar speed tracker signs.
11-05-2022, 08:26 PM | #3 | |
Rep 1,188
Drives: 2008 e92 335xi
And yes, your odometer is accurate.
11-06-2022, 05:09 AM | #4 | |
Rep 124
11-06-2022, 06:09 AM | #5 | |
Rep 1,200
My 230i's speedo reads between 1 to 2mph high. My M-B van likewise. Other cars' speedos had errors ranging from none to 5mph high. As for the odometer, years ago -- in 2002 -- when I bought my Porsche Boxster I noticed the speedo was reading 5mph high. I was concerned about the odometer. I set the trip odometer to 0 and my GPS device's distance to 0 then headed west -- pretty much driving as straight as an arrow flies -- across a portion of Kansas. At 200 miles showing in the GPS device the car's odometer read 200.2 miles. With a 50K mile warranty the 0.2 mile error over 200 miles works out to 50 miles error. |
11-06-2022, 12:23 PM | #6 | ||
Rep 706
In the US by federal LAW speedometers can be HIGHER or LOWER than actual speed. So that excludes the liability excuse, as far as US anyway. re: 49cfr393.82 Quote:
11-07-2022, 08:13 PM | #7 |
Rep 271
Mine reads faster too. Manufactures do this to end the warranty sooner than the max mileage, saves them a ton of money. Years ago I read an attorney sued over this.
This is only my opinion as I'm a retired professional ASE master grease monkey technician, now instructor. Your best teacher is your last mistake. Use what I post at your own risk as you know teachers only know book knowledge.
11-07-2022, 09:13 PM | #8 | |
Rep 748
This is well known with BMWs and as you can imagine, it's been discussed in millions of threads on this forum |
Invisiblename355.00 MichaelL41.50 |
11-09-2022, 08:40 AM | #9 | |
Rep 1,200
The engine controller/instrument cluster controller record mileage. This is obtainable with the right diagnostics tool. Even if the speedo/odometer stop reading right at least the mileage is being recorded. Way way back with another car I noticed the odometer was not counting the miles as it should. Speedo was working ok. Took the car in to the dealer. The car was tested and I was told since the speedo was reading right the car was ok. Some few years later at another dealer for something else I learned there was a known problem with the model/year of car I owned. The grease used to lube the gear drive that moved the number wheels would dry out and the extra drag would keep the number wheels from turning. There was a recall on this. But the car was long out of warranty and I didn't care enough to bother having this done and having to pay out of pocket for it. IIRC the recall was no longer available for free. And I recall a problem with a recent make/model of car in which the odometer would just stop counting miles at some goofy number like 13,342. Software bug... In this case I think if this was deliberate on the part of the auto maker it got this wrong, it screwed itself. If only the odometer was available for mileage the car's warranty would never expire on *miles*. |
