Headers or catless midpipe? Can't have both
11-08-2022, 11:52 AM | #1 |
Rep 34
I'll be moving to New York State (Rochester) in about a year so I do have to pay attention to emissions tests. Also, I don't want to wreck the environment for a few extra horsepower, but with 4 cats on this thing I figured I can remove 2 and find a happy medium. So, which option is better, from a performance perspective while passing emissions tests?
1. Catless headers while retaining stock catted midpipe. I have a 328xi and from what I understand the rear bolts of the exhaust manifold are a bear to get to with the subframe there, so that's something to consider. Otherwise, I feel this is the option to go with for performance (and probably sound). 2. Keep stock exhaust manifolds and remove secondary cats. This would be much, much easier and if I had access to a welder I could simply cut out the cats and weld in pipes. From what I've read, most/all catless midpipes don't fit the awd models as the differential is in the way. This option would be easier and cheaper, assuming I have access to a welder, but would offer less power. Can I get y'all's thoughts on this one please?
2008 328xi
11-10-2022, 09:30 AM | #2 |
Rep 224
Drives: E92 328i 6MT
Catless headers sound like the way to go since you want performance. That is the setup I have with stock midpipe. Once hot, doesn't really smell much at all. You would be cutting it close on a sniffer test though.
2007 E92 328i 6MT | KW V3 | 3SI | SSR Type-C 18x9.5/10.5 | AA Headers
infinitenexus15.00 |
11-13-2022, 01:17 PM | #3 |
Rep 2,680
headers … 2nd cats a waste of $$$
consider ceramic coating to keep temps lower like Swain tech |
desertman1232215.50 infinitenexus15.00 |
11-14-2022, 02:17 PM | #4 |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
+1 for catless headers + the original secondaries
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
12-28-2022, 11:15 AM | #5 |
Rep 34
Ceramic coating is a great idea. I'm saving my pennies right now to pick up a pair, and once the weather turns warmer hopefully I can install them.
I have an xi so fitment can be a bit different with some things, like the midpipes. If I can find another 328xi in a local junkyard I'll grab those midpipes and delete the cats, that way I can run catless and then swap some cats on when it's time for inspections. At least, that's the plan, we'll see if I actually find any in junkyards haha.
2008 328xi
12-28-2022, 01:27 PM | #6 | |
Rep 2,680
get the best headers you can afford because it will make installation easier and have better flow. As an example Supersprint have perfect fitment. |
12-28-2022, 02:04 PM | #7 |
Rep 34
I actually just picked up a set of Roundelworks headers, as I've read good things about them on here. Now, I just need to wait for spring!
2008 328xi
