Water Pump Replacement
11-08-2022, 04:10 PM | #1 |
Rep 54
Hey everyone,
2011 335xi sedan, auto. I've got the BSD codes (pump, OSZ, IBS, and alternator all missing) and my water pump won't stop running with the engine off and is killing my battery. I've already tried disconnecting the BSD at the alternator and IBS, with no change to the codes/pump running. I've also noticed a slow drip of coolant below where the pump is located. I won't have a chance to try the same on the pump and OSZ until i get the car to my parents' this weekend. I had the pump + t-stat replaced back in 2019, and bought the pump through FCP Euro so I'm thinking of just going ahead and ordering a new pump now, assuming it might very well be the pump. 1) What i'm trying to decide is... should i bother doing the t-stat again now too or just do the pump alone?. I'm going to pay my indie to do the labour as I quite honestly don't feel like getting under the car with the weather turning wet and cold now... lol. Will i save on labour at all if they only do the pump? FCP's warranty will cover the cost of the parts so that doesn't matter to me. 2) Can I drive the car a short distance (40min, 35km) to my parents with the BSD short? My main concern is the pump continually running for the 30min drive and fully killing itself part way through the drive. Thanks! Alex |
11-08-2022, 04:41 PM | #2 |
Rep 3,670
When I got a quote to do my water pump, the shop had separate labor for the WP and T stat and did not seem to credit me for the overlap--I didn't press it since I opted to leave the T stat alone.
I'd probably just leave it alone, I've been through many water pumps on my couple of e90s over the past 10 years and I've never once had a thermostat issue or replaced a thermostat. |
StradaRedlands5013.50 |
11-08-2022, 07:02 PM | #3 |
Rep 3,063
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Bummer it failed so fast. Was it BMW or Pierburg brand?
11-09-2022, 01:32 PM | #4 | |
Rep 54
It was VDO
Another question, is there an easier way to disconnect the BSD from the water pump/test the water pump BSD without having to get under and remove the electrical connector? From the DIYs, it looks like a real b*tch even to just get the connector off... |
11-09-2022, 02:52 PM | #5 |
Rep 1,682
If you are changing the pump yourself definitely change out the thermostat.
And if you do not want to pay for a flatbed truck to transport the car, or just get the tools and ramps from your parents', then why not try it if you are not getting the temperature warnings right now. You can monitor the coolant temperature with a scan tool and stop even before the warning shows up I suppose. I would be less worried about the pump seizing up than the engine overheating. Yes a real bummer with a pump failing that early. |
11-12-2022, 09:24 PM | #6 | |
Rep 54
12-10-2022, 01:37 PM | #7 |
Rep 1
N52/N54 Water Pump
Hi guys,
I hope I am not hijacking this thread. Just have a quick question. Does anybody know if the N52 and N54 water pumps are interchangeable? I wanna put a small turbo @ 10-12 psi on my N52. I was considering having a higher-flowing pump from the N54. Thanks. |
12-10-2022, 07:54 PM | #8 | |
Rep 462
