2011 BMW 328i E90 Head Unit Install
11-08-2022, 04:49 PM | #1 |
Rep 8
I just purchased a 2011 BMW 328i E90, which unfortunately came without a Hand Unit and all of the Wires / cables were cut. After calling around I purchased a used Harman/Becker CIC Navigation Head Unit 6512 CI 922863. The rear of the unit has 3 Coax Style Cable (Pink, White, Orange) on the Right Side and 3 Coax Style cables along the bottom (Blue, Pink & Black) Being that all of the cables were cut , with the exception of the Pink Cable that goes directly to the Display Screen on he Dash, I have no idea how where the other 5 Cables are connected to on the car and/or on the Head Unit. I am brand new to this site so excuse me if I'm not very good at this. I would greatly appreciate any technical assistance , suggestions, advise, photos, wiring diagrams etc that anyone can provide me.
11-09-2022, 04:48 AM | #3 |
Rep 2,143
If you are able, go to a junkyard and get the car side harness cut with the connectors and enough wire to repair your harness. Take pictures before cutting.
The follow the links above to know what goes where. |
11-09-2022, 11:05 AM | #4 |
Rep 13,128
There is not much in the way of wiring diagrams.
What there was is Block Diagrams with color codes of the wiring coming of the connectors on the modules. This used to be available on a tech info site that BMW does not allow access to . So now you need a working copy of Ista D or the shop manual . Ista D is highly recommended as it gives you a technical data base and guided troubleshooting all procedures adjustments pictures and diagrams. |
11-10-2022, 12:58 PM | #5 |
Rep 8
Thank you Eljay & Ctuna for your assistance, which I greatly appreciate! Thus far I've been able to 2 of the 6 Cables, the Pink Harness Pigtail Connector connects to the Display Screen, the White Pigtail Harness Connector just below Connects to the Aux. / USB , the Smaller Single Pin Pink Connector I believe is for Satellite, which I'm not sure that I have? I found an experienced BMW Audio Specialist who can repair the two Cut Optical Cables, and all Head Unit Connections once I'm able to confirm where the other 3 the Pigtail Style Connectors ( Blue,Black,Orange) connect, otherwise he will have to dismantle the dash and run a whole new wiring harness which will run me over $3,000. I'm not sure how to attach pictures of the Unit and of all of the cut wires via this site but I can cend them to anyone that may be able to help me via email. My email is Raul.Estrada@elcentrodeayuda.org Thank You !!
11-10-2022, 02:50 PM | #6 |
Rep 8
11-10-2022, 04:57 PM | #7 |
Rep 13,128
You should put up pictures of what you are talking about .
There should be pictures of that stuff on the idrive and maybe stereo sub forum. Fiber optic cables are not that expensive and shouldn't be that hard to route. Connectors for the back of the idrive and single cables are color coded. |
11-10-2022, 05:02 PM | #8 |
Rep 13,128
11-10-2022, 05:45 PM | #9 |
Rep 8
Great advice Ctuna, I just posted 3 Pictures 1. Front View of CIC Unit 2. Rear Vie of CIC Unit showing all of the color coded HSD Connections 3. Picture of the Cut Optic Fiber, HSD Connections & Wires that should connect that connect to the CIC Head Unit. Unfortunately being that the Color Coded HSD Connection Heads were cut off , I'm now having to figure out where the 6 HSD Connections connect, which I've now identified that the Pink connects directly from the Head Unit to the Navigation Screen, the White Connects to the AUX/USB thats in the Glove Compartment. Once I know where the Orange , Black, Blue & Single Pin Pink Connect I can try to trace the signal then Reconnect the GSD Connections and Connect the CIC Head Unit. Nicko 43 has been a big help as well. Thank you one & all for all your help in what is usually a simple Pug & Play.
11-10-2022, 06:14 PM | #10 |
Rep 13,128
The pictures should be posted here.
And they aren't . Go to advanced option and select and download easier from a PC at least for me or attach phone to pc. |
11-10-2022, 07:01 PM | #11 |
Rep 8
I just created a Photo Album which I assumed would be connected to this Thread, guess not I'm still new to this site , I just tried again to attach a picture of the fear of my CIC Head Unit hope it goes through , I appreciate your help!
11-10-2022, 07:08 PM | #12 |
Rep 8
Success ! here is a pic of the Optical, HSD & Wires that were cut and need to identified in order to be reconnected to my Harman Becker CIC 6512 9222863 Head Unit , Thanks again everyone !
