Average Mileage is stuck at 6mpg. Any solutions?
11-09-2022, 09:27 PM | #1 |
Rep 852
My average mileage is stuck at 6mpg. After resetting it almost immediately goes back to 6mpg and stays there.
Has anyone encountered something like that? Any ideas where to troubleshoot? 2006 325i, no idrive, MT. Thanks!
"Let me see what I can do... sir"
11-10-2022, 12:03 AM | #3 |
Rep 852
Doesn’t matter the distance; easy or hard on the throttle, it is always 6mpg
11-15-2022, 08:01 AM | #5 |
Rep 2,143
Does the range calculate "properly"? Is it showing miles left approximately assuming 6mpg or does it show it what you'd usually get with the corresponding fuel level remaining?
Have you scanned the car for any codes? I would start there. Also, found this that may be useful to try: https://www.1addicts.com/forums/showthread.php?t=320316 |
11-15-2022, 01:50 PM | #6 | |
Rep 852
No codes related to the issue, I scanned. Thanks for the link - I'll take a look.
12-05-2022, 06:58 PM | #8 |
Rep 852
I did the miles/gal manual calculation, and the actual is around 21mpg.
Also, per 1er post, I don't think the correction factor is a solution for my case. How does fuel metering work in our cars?
12-06-2022, 03:14 PM | #9 |
Rep 1,232
I thought there is a part of the calculation that goes thru the fuel regulator.
I did notice when I replaced my fuel regulator the MPG calculation somehow appeared to update at a different rate than my original regulator that had 200K+ miles on it. |
StradaRedlands5013.50 NOTCOMINBACKTOXICPLACE166.00 |
12-08-2022, 05:45 PM | #10 | |
Rep 852
The odd thing is that other indicators report correct numbers. I.e. instant mileage gauge seemed to be showing relevant mpg, as well as estimated range is also within the reason. Average speed also correct. Can this be related to the speed sensor?
