11-23-2022, 03:35 PM | #1 |
this is the way
20007
Rep 8,949
G87 might be heavier than we all thought
Just came across this and I don't know what to make of it. On one hand they are notorious for posting wrong figures online. On the other hand, I can't figure out which one has the correct figures, but if I were to guess I'd say the ones from BMW USA News website appear to be correct, although I can't say for certain. If that is the case, it would mean the car is even heavier than we all thought.
The BMW USA website lists the weight of the car at 3,814 lbs for the AT which would mean the MT should weigh about 3,761 lbs. The problem is that the BMW USA News website has 3,814 lbs for the MT, not the AT. BMW USA Curb Weight - Automatic Transmission (lbs) 3,814 BMW USA News M2 Specifications Curb weight (lbs) 6MT 3,814, 8AT 3,867 |
11-23-2022, 03:40 PM | #2 |
Rep 347
Do they give the weight with full tank of gas factored in and all other liquids?
Because I mentioned elsewhere Mischa put the G42 on scales with half tank and got 3783 lbs. So with XDrive and Auto I wanted to understand how that compares to the M2 with RWD and manual. |
11-23-2022, 03:46 PM | #3 | |
this is the way
20007
Rep 8,949
11-23-2022, 03:56 PM | #4 |
Rep 347
Depends on the specs of each car. Base vs base? Base varies in different countries. US has the heavier sunroof base and some places have CF roof as standard. One number could have the CF seats in and the other not?
11-23-2022, 04:04 PM | #5 | |
Rep 3,312
US press release numbers(scroll down): https://g42.bimmerpost.com/forums/sh....php?t=1961085 The difference with US curb weights vs EU/DIN. EU/Germany: 1. Leergewicht EU (Car with 90% fuel, 68kg driver, 7kg luggage (75kg). Latest EU definition uses only driver @ 75kg) 2. Leergewicht DIN (Car with 90% fuel, no driver, no luggage) USA: 1. Curb weight - weight of car with fluids and fuel at 100% as well as weight of any option expected to be in more than 33% of vehicles sold. Last edited by M3WC; 11-23-2022 at 04:10 PM.. |
11-23-2022, 04:05 PM | #6 |
this is the way
20007
Rep 8,949
Doesn't matter as we are not comparing each region or country against NA. Specifically focusing on the USA numbers, the car appears to be heavier than advertised.
11-23-2022, 04:09 PM | #7 | |
this is the way
20007
Rep 8,949
11-23-2022, 04:10 PM | #8 |
Rep 3,312
11-23-2022, 04:27 PM | #10 |
Rep 3,312
(MT) DIN - 1700 kg (3748 lbs)
(MT) US curb weight - 3814 lbs If you add in about 40lbs for standard sunroof vs EU slicktop, another 8lbs for 100% fuel. You are within 18lbs of the DIN weight listed by BMW. So, 3814 lbs for US curb weight doesn't seem out of the ordinary. Also consider the US weight could and most likely does include more options. EU also has a more basic seat standard, that is most likely lighter as well. The F87 OG seats were lighter than the M2C seats. |
Ilyam5942.50 |
11-23-2022, 04:32 PM | #11 |
Rep 3,312
11-23-2022, 04:42 PM | #12 | |
this is the way
20007
Rep 8,949
11-23-2022, 04:43 PM | #13 | ||
Rep 785
Biimmer70.00 |
11-23-2022, 04:48 PM | #14 | |
Rep 785
11-23-2022, 04:56 PM | #15 |
Rep 3,312
StickyPickle1621.50 |
11-23-2022, 04:59 PM | #16 | |
Rep 3,312
Agree it is a porker. The 18/19 standard wheels from M3/M4 would help. |
11-23-2022, 07:43 PM | #18 |
Rep 346
To put it into real life context, not going to matter much.
It's a heavy car. Let that sink in. It ain't going to handle like a Cayman GT4 whether it's 3700 or 3800 or 3900. The brakes, suspension components, other consumables are not going to last years more because it's 3700 vs 3800. |
11-23-2022, 08:22 PM | #19 | |
this is the way
20007
Rep 8,949
11-23-2022, 09:00 PM | #20 | ||
Rep 1,433
Tag20007.00 |
11-23-2022, 09:17 PM | #21 | |||
Rep 1,533
What do you think install would run… about $800? |
11-23-2022, 09:22 PM | #22 | ||||
Rep 1,433
fanofbmwe462918.00 |
