11-27-2022, 11:22 PM | #1 |
Rep 202
Oil service went from 8,000 to 6,000 miles?
So I have about 4,900 miles on the car and this morning it was showing "oil change service due at 6,000 miles". But just a couple days ago it was showing "oil change service due at 8,000 miles". Anyone know the reason for this? I did drive the car aggressively here and there after the break-in procedure but no where near enough to raise any concerns.
12-06-2022, 12:31 PM | #3 | |
Rep 217
nijnella236.00 |
03-07-2023, 09:09 AM | #4 | |
Rep 85
To me that sure reads like the oil change is due at an odometer reading of 7,003 miles, which seems early to me. I'm mostly pretty easy on my car; I enjoy its performance, but I wouldn't say I drive it hard regularly and most of its miles are cruising on the interstate. If it is due approximately 7,000 miles from now, that would put it at around 12,000 miles. It also hasn't changed in the last week that I've been checking it daily, and I put at least 50 miles on my car per day. Does this number only update every so often? |
03-07-2023, 09:23 AM | #5 |
Rep 223
Seems like as good a thread as any for this question...
I'll be new fo BMW when my G42 arrives. For every car I've owned previously, ive changed the oil at around 5,000 miles and thought that was the general consensus for oil changes. How do BMWs get 10,000 miles between oil changes? Is it just a matter of modern engines being build better? (My current car is a 2014 so maybe things have changed 😄 |
03-07-2023, 10:30 AM | #7 | |
Rep 85
There will be a lot of enthusiasts on forums like this who say you should change your oil more frequently than the on-board computer says you should. It's up to you whether you want to listen to the engineers who designed the engine and the oil life monitoring system or follow decades-old rules of thumb. |
03-07-2023, 11:57 AM | #8 |
Rep 223
So basically I've spent twice as much on oil changes as I've needed to over the past 9 years 😅.
Really good to know. Don't know why I never thought to check that the 5k interval i was used to growing up might have improved. |
03-07-2023, 05:40 PM | #9 | |
Rep 160
I assume this was the reason, but I certainly don’t constantly push the car hard. I didn’t see any notice or warning it was due. Now I am due August 2023 or 6,002 miles. I am currently at 13,313 which would be 11,478 miles after first one.
Current: 2022 M240i X-Drive Thundernight
Previous: 2014 435i M-Sport Estoril Blue PCD 5/20/14 2007 335i ED 4/13/07 2003 325i |
08-19-2024, 02:25 PM | #10 |
Rep 18
08-21-2024, 07:23 AM | #11 |
Rep 2,556
