12-01-2022, 05:56 PM | #1 |
Rep 92
Cruising RPM ZF8 vs 6MT
I've got an build in the order bank with a 6MT. I was dead set on going with the 6MT since this will likely be the last generation of M-car with a manual transmission, but after playing around with an RPM calculator I'm not so sure.
Right or wrong, I made the assumption that the M2 will have the same gearing as the 2022 G80 manual and auto cars. If so, when equipped with the 6MT, the engine would be turning 2,955rpm @ 80mph but with the ZF8 it would only be 2,025 rpm @ 80mph. 900 rpm is a pretty huge difference in my book and while I'm not buying it for mpg it makes me second guess my choice. This car will be my daily driver 8-10 months out of the year and my commute is mostly interstate. I'm not sure I'll enjoy droning along at 3k rpm on the highway for an hour a day.... Anyone driven the 6MT G80 as a daily with mostly highway driving? I'd like to hear your perspective if you have. Does this info make anyone in a similar boat reconsider their transmission choice? |
12-01-2022, 07:35 PM | #3 | |
Rep 2,539
I'm going to be honest with you, do you know how absurd that sounds? No, it's not going to drone. Order the car with the 6 speed and thank us when it's delivered and you actually want to drive it.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed 2017 M3 YMB Executive, 6 Speed, ZCP Everything else: 2024 Wrangler 4Xe 2020 MK 7.5 GTI |
9
fanofbmwe462919.50 Caerus536.00 BRAKE!991.50 Albator_IIII1062.00 aerobod4257.50 pz6193334.00 starlord724.00 miiipilot529.50 T3CH46.50 |
12-01-2022, 08:01 PM | #4 |
Rep 2,564
F80 M3 here and yes, about 3,000 rpm at 80 mph. Never impacted my fuel consumption though. I drove mix of country roads and highway and averaged 23.5 over the course of 80k+ miles.
hoss_wagon236.50 Albator_IIII1062.00 |
12-01-2022, 08:02 PM | #6 | |
Rep 346
Short of that reason, there is no other reason to get a manual over auto. The auto does everything else much better (to be honest, if the G87 is anything like the G80, the auto probably suits this car better than the manual) - but of course, I'm still getting a manual |
Albator_IIII1062.00 zero213276.00 |
12-01-2022, 08:14 PM | #7 | |
Rep 1,602
You don't really notice the engine over the sound of the tires. Unless they add a ton of sound deadening to the G87, i suspect it'll be the same. Most of the NVH at 80 mph isn't coming from the engine, i6 engines are notoriously smooth even at 3K RPM. |
Caerus536.00 hoss_wagon236.50 |
12-01-2022, 08:16 PM | #8 |
Rep 511
I'm keeping my M240 for the daily grind. The ZF is nice and smooth with quick shifts and great fuel economy. I do miss rowing the gears sometimes. That's why my M2 will be a 6-speed manual. I will probably drive it to work once in a while. Mostly a toy. And I've always wanted an M2. I wouldn't pass up a chance to get the 6-speed seeing as they are becoming less available, but you gotta do you. Happy motoring. Cheers!
12-01-2022, 08:31 PM | #9 | ||
Rep 2,564
12-01-2022, 09:27 PM | #10 |
Retired Major
1062
Rep 764
Not bad MPG. Good to know.
2023 G87 ///M2 (production began Jul 4th 2023) 2008 E90 335i | Silver Grey | Terra | Piano Black | 6MT | ZSP | ZKO | ZAT | ZKI | ZPL | ZKL | |
12-02-2022, 09:57 AM | #11 | |
Rep 1,843
But I'm still choosing it. That's the trade-off for dual personality vehicle - road car and track beast. And it won't be my daily! Haha |
hoss_wagon236.50 |
12-03-2022, 08:57 AM | #13 |
Rep 965
Drives: G87 M2, G20 330d, Brabus Smart
I had similar concerns before pulling the trigger on my '16 F80 and drove the DCT and Manual before buying. The extra gear in the DCT DID account for a bit more aggressive gearing on the manual to achieve the same speed. Ultimately though, I found the sound in the cabin (that's with the so-so sounding S55), as well as the feel at 80mph just fine in the manual. Enjoyably, I was cruising at around 2750-2900 in the manual, which actually let me sit right in the torque curve - allowing for nice thrust when flooring it in 6th.
Unless you're using the M2 as a freeway commuter or are one of the die hard "must have fastest version" buyers, I consider the difference negligible, as a whole.
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp) |
12-03-2022, 04:36 PM | #14 |
Rep 352
Drives: 2023 M2
Are we sure that the final drive ratio is the same between the MT and AT? They frequently are not.
12-03-2022, 05:44 PM | #15 | |
Car Geek
4258
Rep 3,905
More spec info in the BMW press release: https://www.press.bmwgroup.com/globa...04444EN/568008 6th gear in the manual is 0.846 for a drive ratio of 2.929:1, 8th gear in the auto is 0.640 for a drive ratio of 2.019:1. |
12-05-2022, 12:10 PM | #16 |
Rep 2,463
Drives: 2021 M2C
Not that it has any relevance on anything here, but the DCT is at about 2,500 rpm at 80mph.
