12-06-2022, 04:14 PM | #1 |
Rep 83
Added Illuminated ///M Headrests on M50i
Just wanted to share a recent mod I did. Might not be everyone's cup of tea, but in case others are interested...
I was always jealous of the illuminated headrests and the M seats available on Euro models that we can't have here in the US. Decided to try a retrofit the emblems and was successful. Here are the parts/steps: 1) Replaced the headrests with the X5M/X6M headrests (I don't have a part number as I found them on eBay for a great price)... the headrests are a direct/perfect swap as far as fitment into the seats. I realize their shape is a little different due to the way they nest into the M seats, but I think they still look great and I found this to be cleaner vs retrofitting the illuminated emblem into the existing headrest. 2) I swapped out the illuminated X5M/X6M placard on the headrests with the placard that comes on the X3M (PN: 52-10-8-745-038) which just says ///M and not the full model designation, these also are a direct fit/swap for the other placards on the headrest (all these placards across all BMW models seem to be the exact same shape/fit/plug) 3) Picked up some custom wiring harnesses made by njw1967 which allow you to basically make these plug and play and tap power from the footwell light on the bottom the seats. Many are using these to retrofit their non-illuminated emblems into the illuminated ones, but this worked perfectly for my project too 4) Last step was to get some help from maximking in order remotely to code out the active headrests that I had removed to eliminate the error code thrown by the car. I fully realized I removed a minor safety feature here, but not all models come with this anyways. Pretty happy with the end result! The emblems come on when you unlock the car or come near it with the proximity key (looks awesome at night) and then shut off automatically a few seconds after locking the car. Last edited by paulrr; 12-06-2022 at 04:19 PM.. |
14
maximking107.50 karzrkewl908.50 nZtiZia4719.00 Blue87377.00 Merciless5867.00 boneca2025.50 Scottdip14.50 KLCC79.50 njw1967619.50 Cooltones241.00 Daily_drivX5M261.00 gqgambler717.50 1Boxer34.50 Dr. Jekyll211.50 |
12-08-2022, 07:48 AM | #4 |
Rep 719
Thanks for the mention Paul
They look great buddy I am just in the process of making another batch of wiring looms at the moment, got an enquiry from Australia for a set. |
12-12-2022, 09:13 PM | #6 |
Rep 46
Paul, is there any adjustability with these headrests? Do they tilt forward or backwards? Any button the side? Are you able to retract the headrest further down so that the posts are not visible?
12-13-2022, 12:33 AM | #7 |
The Dark Knight
422
Rep 1,262
So if I add this to my 2019 xdrive 40i with motorized headrests then would it remove the motorized functionality? If not and if it behaves the same as my oem headrests then I am 100% interested in doing this.
OP - any link to where you bought the headrests from on eBay? |
12-13-2022, 03:25 PM | #8 | |||
Rep 83
here's the link for the eBay listing I purchased from, the price is outstanding, about 1/2 of what the quote was here from a US dealer, the item shipped via FedEx express, is a factory part (not aftermarket), and it arrived in about 7 days https://www.ebay.com/itm/403934001463 |
12-13-2022, 04:26 PM | #9 |
Rep 719
Just a note guys, ive sold my wiring kits to a few guys in the States who are having the badges retrofitted into the OE headrests by interior trim guys.
Not got any pictures yet but I have been promised some. Maybe worth considering |
12-13-2022, 08:11 PM | #10 |
Rep 3,940
On the real X5M seats, if the headrest is in the lowest position, the posts are hidden.
12-14-2022, 11:10 AM | #12 | ||
Rep 83
yes it's not difficult, but to me purchasing the premade wire loom with the correct plugs already that made this totally reversible with no modification to the car with basically a plug and play install was worth every penny, just made it so much simpler/easier, but yeah definitely could be done from scratch |
njw1967619.50 |
12-14-2022, 12:33 PM | #13 | |
Rep 719
If you remove the OE loom from these headrests my loom would plug directly into the badges |
12-14-2022, 02:49 PM | #14 |
Rep 83
yes, but since these headrests are not open from the back like the X3 ones, they are fully closed up, it's not nearly as simple I think to fish the wire through, that was why I went this direction of using the OE headrests with the wire already coming through
12-14-2022, 08:53 PM | #15 | |
The Dark Knight
422
Rep 1,262
12-14-2022, 11:11 PM | #16 |
Rep 83
I purchased the wiring loom from njw1967 which makes it plug and play into the footwell light plugs in our vehicle.
The only modification I had was to cut off the plug end that he has which connects straight to the illuminated emblem, and then cut the plug coming out of the OEM headrest, and hardwire the two together. It’s only two wires to connect together. |
05-02-2023, 07:06 AM | #17 | |
Rep 1
05-09-2023, 08:51 AM | #18 |
Rep 719
