12-09-2022, 11:43 AM | #1 |
BimmerPost Supporting Vendor
9599
Rep 10,891
IND | MMR Performance Magnetic Differential Oil Drain Plug - M22x1.5
The MMR Performance BMW Magnetic Diff Plug is a simple, cost effective upgrade that can dramatically increase your differential's lifespan. As the differential wears, tiny metallic particles become suspended in the oil - our magnetic diff plugs help to safely separate these nasty particles out of your lubricants. There's no avoiding it - your differential wears a little each time you drive the car. So it becomes inevitable that tiny metallic particles become suspended in the oil. And of course, the harder your differential works, the greater the risk of this nasty metallic debris, meaning the greater the benefit of using a magnetic diff plug. This diff plug has a large surface area of the magnetic end help to catch such particles, therefore cleansing your oil allowing it to more effectively lubricate, whilst minimizing further potential wear before it happens. The MMR Performance Magnetic Diff Plug is produced from T6061 lightweight aluminum and is anodized in our trademark finish. Insist on an MMR Magnetic Diff Plug at your next service! NOTE: Fits differentials with M22x1.5 thread The MMR Performance Magnetic Differential Oil Drain Plug - M22x1.5 may be viewed at the following link to our online store: https://ind-distribution.com/product...l-plug-m22x1-5 Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
