12-10-2022, 07:47 PM | #1 |
Rep 131
M Wheels on M240i?
Anyone try the M2/M3/M4 wheel sizes on a M240i?
OEM 963M forged wheel set shown Front: 19×9.5, 275/35 R19 Rear: 20x10.5, 285/30 R20 |
12-15-2022, 01:05 AM | #3 |
Rep 27
Drives: BMW M240i RWD
Also following…
I was also interested in this for awhile and found this thread today. |
12-15-2022, 04:11 AM | #4 |
Rep 610
Not sure this would work.
The guys at @ Apex are the people to ask.
Currently Driving: '23 G87 M2, '22 BMW M240i xDrive, '18 F87 M2, '98 E36 318is @AUTOID | WWW.AUTOID.CO | SALES@AUTOID.CO |
ApexWheels1533.50 |
12-15-2022, 09:32 PM | #5 |
Rep 69
someone on ig name "80lehtinen" he's got some good pictures of the car with the 826m wheels 19x9.5 et20 all around. on stock suspension maybe someone can try 255/35/19 squared. per his posts he's lowered 35mm on ohlins coilovers and "265/35/19 michellin cup 2's shaved off 2.5mm from the rim hubs at rear and 3 degrees camber front, 2 degrees rear."
04 Z4 3.0i
22 M240i xDrive |
boost.m24023.50 |
12-16-2022, 12:21 PM | #6 | |
Rep 131
We know the dimensions below fit the new M2 but it's my (admittedly basic) understanding that the new M2 chassis (G87) is more like the M4 chassis than the M240/230 (G42) chassis. Seems like the extra width of the M2 is where they picked up some space for larger wheels/tires. Front: 19×9.5, 275/35 R19 Rear: 20x10.5, 285/30 R20 Last edited by hooked; 12-16-2022 at 01:51 PM.. |
12-16-2022, 12:34 PM | #7 |
Rep 1,207
12-16-2022, 01:58 PM | #8 | |
Rep 131
Those are the 898s 19". BMW offers them in some of their winter/summer wheel+tire packages. I *almost* got them for my winter setup but not too crazy about the gray color and the white lettering. |
12-19-2022, 05:07 PM | #10 | ||
Rep 6,983
If they do match the OE M3/4 offsets, then it would be quite difficult to run them on a normal G42. OE G80 M3 offsets in the 19/20 are ET20 front and rear with 19x9.5 F and 20x10.5 R being the most commonly sold option that I've encountered. That would be really aggressive for a normal G42 2 series and poke out way beyond the fenders. As the post above shows, you can make the front fitment work with narrower tires, camber et c in the front. Not a fan of milling a backpad of any wheel to change the offset though if I'm honest. The low factory M3/4 offsets actually let us make the most concave BMW wheels I've ever worked with that are still a direct fit with our 20x10 front G80 M3 fitment being an ET8. That's the first single-digit BMW offset I've been involved with but the wheels work well on the M3. Example: 20x10 ET8 Front wheels with 20x11 ET18 rears. TLDR: I don't think they'd be an easy fit with stock fenders because of the widths and lower offsets. -Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by Expert@ApexWheels; 12-19-2022 at 05:17 PM.. |
hooked217.00 |
12-21-2022, 04:21 AM | #11 |
Rep 447
12-21-2022, 08:44 AM | #12 | |
Rep 131
245/35ZR19 93Y 8.5Jx19 ET25 255/35ZR19 96Y 9.5Jx19 ET35 |
12-21-2022, 12:46 PM | #13 | |
Rep 6,983
The narrower wheels and higher offset mean they can't be as concave as the M3/4 fitments, but I think they still look great on the car. -Tom
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey |
12-21-2022, 05:08 PM | #14 |
Rep 131
Thanks. What size tires are on this car? The rear looks like it's sitting noticeably higher? Maybe a taller sidewall than the front? If so, I assume this is a RWD version unless the photo is playing tricks on my eyes?
12-22-2022, 12:09 PM | #15 | |
Rep 6,983
-Tom
hooked217.00 |
12-22-2022, 05:54 PM | #16 | |
Rep 131
Expert@ApexWheels3938.00 |
