      12-12-2022, 05:56 PM   #1
AWDSOME
Drives: 2023 M3C Xdrive
PPF recommendation
Thinking about getting full PPF on my 23 M3 when it gets here.
Which brands are recommended? It will be a gloss PPF.
I plan on keeping the car for 10-15 years.
Also is it worth getting the ceramic coating on the PPF?
      12-12-2022, 06:13 PM   #2
jpichardo91
jpichardo91's Avatar
163
Drives: 2023 M3Cx / 2020 BMW x5 M50i
Yes get ceramic coating on top of your ppf.
Most installers just throw it in for free when you get ppf with them.
A bottle of ceramic coating does not cost much and it is not very time consuming for an installer.
AWDSOME635.00
maelfyn158.00
      12-12-2022, 06:27 PM   #3
Asmedbeats
Drives: 2023 M3 Comp Xdrive
  [0.00]
2023 M3 Comp Xdrive  [0.00]
Each installer is different. And to some degree you get what you pay for. Definitely check out their work and reviews. I went with full ppf for peace of mind and plan to keep it long term. Is it probably overkill? Yes. But now I don’t have to be as OCD about where I park. Worth it for me.
I went with xpel ultimate plus. And xpel xr plus for tints. Coated on top with gtechniq halo.
AWDSOME635.00
maelfyn158.00
      12-12-2022, 06:28 PM   #4
Forzanerazzurri
Drives: E46 M3 Coupe/G80 M3CX
Most good PPFs have ceramic coating infused and doesn't require or really accept ceramic coating on top. I would look at STEK and avoid XPEL if you want a film that is easy to install and has minimal orange peel. XPEL is highly overrated. Its mostly popular because of the way it bribes installers with its cutting software and forced exclusivity but it's generally an inferior product to it's competitors.
AWDSOME635.00
      12-12-2022, 06:28 PM   #5
cristy7610
Romania
39
Drives: BMW E92 335I
Few days ago I fully mounted Stek PPF on my G80 and it looks amazing.
AWDSOME635.00
      12-12-2022, 06:46 PM   #6
vbb
vbb's Avatar
2264
Drives: 2022 M4 manual
Xpel and Suntek are both quality products. I've heard good things about STEK too. 3M is viewed by many as being a tier below. That all said, the argument over PPF films is like the argument over which brand oil you should use. The biggest investment is going to be in an installer that does solid work, because even the best films will make your car look worse if the install is bad.
As for ceramic on top of the PPF, sure. The ceramic increases the hydrophobic qualities of your film and makes it easier to wash. The film protects against scratches, paint etching and rock chips. As someone already mentioned, many of the newer films are ceramic infused so the extra layer of a ceramic coat won't do much.
The fact that you plan to keep your car 10-15 years is definitely the biggest pro in favor of doing this though. My personal opinion is that too many people spend too much money on PPF when they aren't going to keep the car very long, and aren't going to recoup that cost. I've seen quotes nearing $10K on paint correction, full body PPF and ceramic coating. Some people can do that without breaking a sweat, and not care if they don't get their money back when they sell their car. I am not one of those people. But if you're in this car for the long haul, yes, I absolutely can understand you wanting to do the best to keep it looking as pristine as possible for as long as possible.
AWDSOME635.00
      12-12-2022, 08:43 PM   #7
Savsearcher
Drives: '23 M3 comp xdrive, '24 iX M60
I’m getting Xpel ppf on Wednesday and need to decide between their 8 mil with ceramic infused or their 10 mil thickness sans ceramic. Both are the same cost. Is the 10 mil thickness preferable?
      12-12-2022, 08:59 PM   #8
Forzanerazzurri
This is the problem with XPEL. Do they not have a 10mm ceramic infused? XPEL is so unfriendly to installers that it doesn't stretch enough and is difficult to be installed cleanly. Then there is the orange peel...
      12-12-2022, 09:20 PM   #9
Savsearcher
Apparently there is no 10 mil ceramic infused, just the 8.
This seems like a case where thicker is better, but is there a trade off?
      12-12-2022, 09:39 PM   #10
Forzanerazzurri
It's definitely something to consider. To me a film without infused ceramic is not acceptable today. I wish people who swear by XPEL without infused ceramic could see my car at the hand wash. It's pretty incredible.
      12-12-2022, 09:57 PM   #11
Asmedbeats
  [0.00]
To be honest we can argue about different films but for me it came down to the installer. My guy took apart all the trim and door handles etc. I had to even ask if they forgot a panel it is so hard to find the edges in the few areas you can find it. I totally agree the ceramic top coated or infused is worth it if you are already investing in the ppf. Just make sure if it’s not infused it’s a ceramic coating that works with ppf so the healing properties work as advertised.
AWDSOME635.00
kjx3343.50
      12-13-2022, 08:00 AM   #12
kjx
///M ♥ Recycled Dinosaurs
kjx's Avatar
Drives: BMW M4, BMW X5 45e
Installer is everything. An installer that is known to do a great job end to end consistently will be expensive and won’t compromise on the quality of film, or how many times they redo the work until it’s perfect.
Cheaper installers apply precut sheets that show edges that become increasingly obvious as they catch dirt over time. The best ones tuck in the edges out of sight to the point where others don’t even know there is PPF.
I did full body PPF, partially because I have individual paint and partially because that is the only way to prevent swirls and micro scratches on the clear coat as the car ages (hand wash etc is not 100% guarantee of no issues). My partial PPF + ceramic coated X5? The ceramic coated sections (without PPF) aren’t flawless anymore - clear coat will need polishing, and ceramic reapplied.
My full PPF M4? Looks better than it did at delivery at the dealership one year out.
2022 BMW ///M4 Comp M xDrive (Enzian, Kyalami - insta | youtube | bp featured: Delivery + 963M + 2x Enzian!) | 2021 BMW X5 45e (Carbon Black Metallic, Ivory White)
BMW CCA LIFETIME MEMBER | Past cars: 2016 BMW 435i Gran Coupe (Carbon Black Metallic, Oyster White - Euro-delivery)
      12-13-2022, 02:39 PM   #13
ominousM4
Drives: 2023 M4 Comp Xdrive
No problems with Xpel on multiple vehicles. I've witnessed the self healing properties.
AWDSOME635.00
      12-13-2022, 06:26 PM   #14
Savsearcher
Do you get the 8 mil or 10 mil thickness?
      12-14-2022, 01:19 AM   #15
fl1by
Drives: G80, Raptor, STI and C8
XPEL ULTIMATE PLUS 10. 10 Mil. I have to agree with others comments that the installer is a huge factor here that cant be overstated. If the installer says they can knock out a G80 in a 6 - 8 hour day go somewhere else. Also buy touch-up too. If there are any corrections that need to be done the installer will have the paint.
AWDSOME635.00
      12-14-2022, 03:03 AM   #16
docjavier
docjavier's Avatar
Spain
1295
Drives: G80 M3 F10 535i
Did the installer remove the bumper, door handles and items like grills lights?
How long did it take? The installer I will be using told me he would like to have the car for 10 to 14 days. 7 days to install it and 7 days to let it sit. Using XPEL Ultimate Plus.
2023 G80 M3 C/XD SMB, 2012 F10 535i M-Sport, BM3 stage 2. 2014 Porsche Cayenne GTS.
      12-14-2022, 05:14 PM   #17
forcefed
forcefed's Avatar
Drives: .
I think the only time these installers remove parts from the body is when they don't use the precut pieces and simply apply film to the whole area and cut everything out, but you're going to be paying a premium for this type of install.
      12-14-2022, 06:23 PM   #18
Forzanerazzurri
Door handles take 2 mins to remove and should be otherwise you end up with an ugly line in the film.
AWDSOME635.00
hoyasaxa737.50
      10-18-2023, 08:08 PM   #19
BSMG82M4
BSMG82M4's Avatar
Drives: BMW G82 M4 Competition
Has anyone wrapped their car with CovrGard? How does this compare with Stek and the other ppfs?
