BMW 2 Series Technical Topics (G42) Cosmetic Modifications (Exterior, Interior, Lighting)
      12-14-2022, 12:43 PM   #1
HawksG42
CE560XL Pilot
Drives: 2022 M240i
M Heritage Badging Installation
Does anyone have a video of them swapping out the standard hood and trunk lid badging for the 50 Years M Heritage badges. I've seen videos of swapping on other vehicles, just not the M240i. I've never done anything like this and the last thing I want to do is jack it up! The trunk lid seems to be pretty straight forward (nylon strap slid behind the badge and pull), it's the front that's stressing me out.
      12-14-2022, 02:02 PM   #2
Vudumonkey25
Vudumonkey25's Avatar
Drives: BMW M240i x Mercedes CLS550
Super easy
Tape around the top and bottom edge.
Heat it up
I couldnt get the nylon strap to not curl up and come thru the other side.
I ended up just slipping a squeegee like this one under the edge and they came right up https://a.co/d/dFENepZ
Clean up left over glue and clean. I didn't have much at all.
Peel and stick new ones on and give a good press.
Legit takes under 10min even if you have a lot of glue to clean
Under 5 if you get a clean pull
Ended up doing it like this video
'22 M240i BSM, Shadowline, Black 791M wheels, Red Calipers, ///M Carbon Front Lip, ///M Carbon Spoiler, ///MCarbon Door Sills, Milltek Catback w/Black Tips, Dinan Carbon Intake/Engine Cover, AA Catted DP, Dalher Valve Controller, OEM+ Strut Bar, Red Start/Stop, Floating center caps, TLG Mud Flaps, Black Badges, Led Projectors, 50th Emblems, Carbon Diffuser/Mirrors w/smoke signals/Side Wings/Cooling Shroud/KIES fire extinguisher, Yellow DRL
      12-14-2022, 07:28 PM   #3
HawksG42
CE560XL Pilot
Drives: 2022 M240i
Originally Posted by Vudumonkey25 View Post
Super easy
Heat it up
What did you use to heat it? A hair dryer or an actual heat gun? I don't want to ruin the PPF. I'll ask my guy if there's anything special I need to do.
      12-14-2022, 07:29 PM   #4
Vudumonkey25
Did you use a heat gun on it or just a hair dryer? I have a full front PPF on it so I'll ask my guy if I need to do anything to protect it.
Hair dryer
It doesn't need much. Hot day out is probably good too
      12-14-2022, 07:33 PM   #5
HawksG42
CE560XL Pilot
Drives: 2022 M240i
Hair dryer
I'm in AZ so maybe I'll wait until spring. I'm really anxious to put them on though. Oddly enough it's only been in the 50's around here lately. Freezing!!!
      12-19-2022, 01:54 PM   #6
Winrya
Drives: BMW M240i G42
I’m going to try the cable tie or banding trick but this video shows how easily they come off
I’m doing mine over Xmas. Noticed the front badge has little anchors and I’m slightly worried they might break when being removed
      12-19-2022, 03:44 PM   #7
Vudumonkey25
They pulled up fine. Just bent a little. No biggie. You probably aren't reusing them anyways as the glue is gone anyways.
Really easy
      12-19-2022, 09:07 PM   #8
HawksG42
CE560XL Pilot
Drives: 2022 M240i
https://youtu.be/4b7xhqP48EU
Great find!!!!
Two things….One, I need a pressure washer so I can use a proper foam cannon. Two, this looks WAY easier than other videos I’ve seen. Thanks you for finding this!
      12-19-2022, 09:09 PM   #9
HawksG42
CE560XL Pilot
Drives: 2022 M240i
Really easy
Was this your video? If so, thanks for posting!
      12-19-2022, 09:15 PM   #10
Vudumonkey25
Nope, but pretty much did the same thing.
Ind and some others don't even heat it. Just tape, slup squeegee, clean left over glue. And swap.
      12-23-2022, 12:36 PM   #11
HawksG42
CE560XL Pilot
Drives: 2022 M240i
Super easy to do! I didn’t have a pry tool so I used a Lego separator from my kid’s Lego set to pry it up. Took 15 minutes for both MAX! Kinda scary to do for me since I’ve never tried to do anything like this.
PP3121373.00
      12-23-2022, 03:49 PM   #12
Vudumonkey25
Awesome, good job. Told you it was cake
      12-23-2022, 04:53 PM   #13
HawksG42
CE560XL Pilot
Drives: 2022 M240i
I was just nervous that I would damage something I couldn’t repair myself and then my wife would be all over me. Thank you for the tips!!!
      12-24-2022, 11:03 AM   #14
Winrya
Just done mine. Front popped off in seconds and didn’t leave any adhesive. Rear I found I couldn’t pull off with the banding trick, had to lever off with plastic trim removers.
Really happy with the result
Coconut804.50
PP3121373.00
      12-26-2022, 10:09 PM   #15
HawksG42
CE560XL Pilot
Drives: 2022 M240i
I had issue with the back as well. Definitely a little more stuck than the front.
      12-26-2022, 10:10 PM   #16
HawksG42
CE560XL Pilot
Drives: 2022 M240i
They look great with the BG too!!
      12-27-2022, 09:42 AM   #17
Invisiblename
United Kingdom
360
Drives: M240i
With it being so easy to remove the badges, I just hope none of you get ‘badge collectors’ calling!
M240i x-drive (Thundernight, 19" 893Ms, Cognac, Pro Pack, Adaptive, Sunroof)
      12-27-2022, 02:17 PM   #18
Winrya
Yea good point that. I imagine what will be the worst part of that scenario is the damage they will cause doing the removal
      01-04-2023, 12:16 AM   #19
HawksG42
CE560XL Pilot
Drives: 2022 M240i
I guess that depends on your neighborhood but everyone around me wouldn’t even know that it’s not OEM and couldn’t care less anyway. Not to mention it’s garaged the majority of the time
      01-04-2023, 04:40 AM   #20
Invisiblename
United Kingdom
360
Drives: M240i
Never park away from home?
PP3121373.00
      01-05-2023, 04:55 PM   #21
G42UPRA
G42UPRA's Avatar
246
Drives: Mazda 3
Glad this thread exists... I had them on my order but the allocation didn't come through until this week. Turns out they won't supply the heritage badge for any order placed in 2023. 😔
      01-09-2023, 04:07 AM   #22
HawksG42
CE560XL Pilot
Drives: 2022 M240i
Of course I do but not in an area where I have to worry about it. Nobody is going to carry s tool to remove them without destroying it either. Otherwise badges would be missing all over the place. My dad had an old Dodge pickup truck with the cool Ram hood ornament, now THAT was stolen all the time. He eventually quit replacing it.
