12-20-2022, 03:31 AM | #1 |
Rep 25
Remote Start Issues in Extreme Cold
Just wondering if anyone has run into issues with using the remote start feature via My BMW or the key fob in extreme cold conditions? Until recently we have been using remote start regularly without issue (except for glitches with the app which seem to be the norm). For reference we are in Canada and temperatures are currently in the high -30/low -40 range with wind chill.
For the last two days however, remote start has not worked at all and the message indicates requirements haven’t been met. From what we can gather the following are requirements for remote start: 1. Vehicle is in idle state or standby state and not in a drive-ready state. 2. Battery is sufficiently charged. 3. The fuel tank capacity is sufficient. 4. Hood is closed. 5. Air Vents are open. As far as we can tell all conditions are met. Unless the battery is considered insufficient due to the cold temperatures? We are stuck in this cold snap for a few more days, and will continue to monitor the issue. We are hoping that when it goes back to “normal” winter conditions, remote start will once again be available. Just thought we’d throw it out on the forums for others’ experiences/thoughts. |
12-20-2022, 01:11 PM | #2 |
Rep 1,559
Did you look under climate control menu to see if remote start got un-checked? This happened to me when I did an update.
Have you tried using Alexa? "Alexa, ask BMW to start my car." |
12-20-2022, 01:49 PM | #3 | |
Rep 706
Did ya happen to check the battery voltage (handy terminals under hood allow this)
MY guess is this. First of all this gen (and other recent gen) BMW does not generally keep the battery fully charged. The specifics are too much to get into here, it has been discussed in forums here...but search on BMW Intelligent Charging System (IGR is the acronym they use). Anyway my guess is the battery was too low for the remote to function, but not too low to start the car. Let me explain, not all cars have remote start, so that is a separate sensor that is active at rest, that takes energy (battery energy)....at rest you car is monitoring the SOC (State of Charge) of the battery...in BMW's own words below: Quote:
For example i checked my BMW battery voltage this morning after reading this post, it was at 12.2 volts. A fully charged is considered between 12.8 and 13.0 for the AGM battery we have. 12.2 is considered less than 50 percent charged. (40 percent). I cannot get into the reasons for BMW not maintaining a fully charged battery and the charging methodology here, ya gotta research the hints a gave above if interested. |
12-20-2022, 03:05 PM | #4 |
Rep 447
I bet you nailed it. I turned it off myself once when going through the settings and not realizing that "preconditioning" was remote starting. Not exactly intuitive verbiage.
12-20-2022, 04:11 PM | #5 | |
Rep 69
Kay.Say22.50 |
12-20-2022, 05:22 PM | #7 |
Rep 438
Nope, not available in the UK
M240i x-drive (Thundernight, 19" 893Ms, Cognac, Pro Pack, Adaptive, Sunroof)
12-26-2022, 08:48 AM | #8 |
Rep 49
Having the same issue. I drive an X3 LCI. This only started when the temperatures got really low this past week in North Dakota. I'm talking like -20C, -4F.
I got a CTEK charger and charged the battery back up. And it worked once, but now stopped again. This was when the temperature picked up a bit. Even left the trickle charger connected and it won't remote start. My nearest BMW dealership is about 4-5 hours away so I am not going to take it in, but I suspect it's related to the extreme cold and this will resolve soon enough with the weather. The BMW is too "SMART" for its own good and is just shutting everything down based on the extreme weather/temperature, and even though I have the battery charger plugged in and fully charged. Would be interested to know what they found for you!!! Hope some of what I said was useful... |
12-26-2022, 05:49 PM | #9 | |
Rep 320
12-26-2022, 06:26 PM | #10 | |
Rep 35
I guess suffice it to say: when it's arctic cold, you're probably SOL unless you're able to own a battery charger/be able to plug one in, or able to drive the car sufficiently to charge the battery back up due to this method -- so remote start will work. I am sure there are good reasons for how BMW handles battery power, but I will say I'm disappointed in it if it renders remote start/preconditioning impossible -- in a climate when it's most desired. I am a new BMW owner & have been concerned that my 6-month-old battery needed service all of a sudden. |
12-26-2022, 07:19 PM | #11 | |
Rep 49
Let me know what you find out on your side. |
12-26-2022, 07:36 PM | #12 | |
Rep 35
I don't have access to a battery charger, outlet or anything like that were I live -- and with the weather as it's been, driving much past getting the engine warm/to operating temp has been out of the question. I was still wrong to do that too, it seems. I tried to explain that it's been dangerous and not a good idea not only with road conditions but arctic wind chills. After doing ~50-55 miles yesterday, I did try a remote start at home after the car was off for 30 minutes--and it worked. Then, this morning, tried again about 14 hours later, and was shown another error message about the battery not having enough charge. Since I can't just not drive my car when it's an arctic blast, I guess Remote Start is out of the question…it's my 1st car with the remote start option, but when it's arctic I suppose it's back to getting in the car and starting it from the driver's seat when it's arctic. Starting it every day seemed to make sense to me, and the car has no problem starting as long as I'm inside it. It's just the remote start that doesn't work -- which, in an arctic blast, is a disappointment and a slight inconvenience. |
12-26-2022, 08:54 PM | #13 | |
Rep 233
You might want to get a jump pack to keep from getting stranded if you're doing short hops all the time. |
Invisiblename359.50 Fahfoofnik19.00 |
12-27-2022, 08:28 AM | #14 |
Rep 472
May I inquire why you would have the car in neutral and not in park for three days? Sorry, I do not understand.
12-28-2022, 11:07 PM | #15 | |
Rep 35
12-31-2022, 05:08 PM | #16 | |
Rep 400
Drives: G42,570GT,Lp5704STS,F36,F34
Garage List 2023 BMW m240i [10.00]
17 Mclaren 570GT [9.50] 12 Lambo Supertrofe ... [0.00] 04 Lambo Gallardo ( ... [0.00] 08 Aston Martin Van ... [0.00] |
Kay.Say22.50 |
