01-10-2023, 11:13 AM | #1 |
Rep 1,559
Angled vs. Level Oil Change
Has anyone noticed much of a difference in the amount of oil that comes out when draining with the car level vs. only the front lifted?
In the past I have always used 4 floor-jacks to lift the car level, but now I'm wondering if I can get even more old oil out if I drive the front tires up on ramps, as maybe more oil will drain from the oil cooler? As a plus I'm sure driving up on ramps will be a lot easier/quicker than messing with the 4 floor-jacks. Thoughts? |
01-10-2023, 11:59 AM | #2 |
Rep 596
I havent looked buy typically your drain plug is on the back of the oil pan so one would think buy tilting the car toward that drain plug would in fact cause more oil to come maybe even faster than if it were level. Your KTM might be different than my yamaha but its suggested you tilt the bike side to side during an oil change to remove as much used oil as possible.
01-10-2023, 12:15 PM | #3 | |
Rep 1,559
01-10-2023, 03:46 PM | #6 |
Rep 748
Based on the pic attached, it appears the oil drain plug is at the rear, driver side of the oil pan.
For DIYers like ourselves, it looks like we could maybe get away with only jacking up the front passenger side? That is, if it’s inconvenient to have both sides up in the air at once. I plan on jacking up the passenger side using the side jack point and placing my old rhino ramp under the passenger wheel. At least until I pull the plug and get some QuickJacks |
01-10-2023, 07:39 PM | #7 |
Rep 596
01-11-2023, 09:18 AM | #8 | |
Rep 1,559
It's sorta comical how many engines I hear starting when leaving an intersection. |
01-11-2023, 09:32 AM | #9 | |
Rep 612
XC3LLR82062.50 |
01-11-2023, 09:25 PM | #10 |
Rep 596
Yeah I'm not super old but this is my first car that has that feature my c7 def didnt hell even the lane assist is a new feature I immediately turned off. I get why they do it those epa credits but still.
