01-20-2023, 04:08 AM | #1 |
Rep 502
dAHLer Exhaust Valve Control Module DIY and Review
There's a few options for getting more noise out of your stock exhaust.
1. FREE, put it in Sport Plus mode then pull the exhaust valve fuse. No way of closing the valves. Cold starts can be fairly loud. 2. Cost of Bimmerlink, code in SPORTY mode which open the exhaust fully. Only works with ID7, not ID8. 2. $260 Dinan Exhaust Valve Control kit. Allows remote control of your valves, can be programmed to your homelink buttons. Uncertain if the module remembers the last setting, which allows you to startup the car with the valves open. Requires additional wiring for tapping into the 12V supply. Not too keen on being the exact same $100 kit on Aliexpress, just rebranded as Dinan. 3. $520 dAHLer Exhaust Valve Control Module. Allows remote control of your valves, can be programmed to your homelink buttons and it remembers your last setting so you can startup the car with the valves open. True plug and play install. It takes power directly from the OEM exhaust valve plug. Pricey but IMO the most elegant solution with the least wiring and built in Germany with actual R&D and quality standards. You can mount the control module either in the car or outside since the enclosure is water and heat resistant. I choose to mount it in the trunk. I jacked up the rear passenger side so I could fit underneath. There is a perfect spot on the right side of the battery where you can mount the unit and it's next to a rubber grommet leading outside. I removed all the 10mm bolts holding the black plastic underbody panel next to the right exhaust tip and exhaust valve. I cut an "X" into the round rubber grommet and fished the control modules connectors through it. I used butyl tape on the grommet to create a water/air tight seal. Simply disconnect the stock valve connector, plug it into the harness and plug the new connector into the valve. Zip tie here and there to tidy up the wires. I used a bit of black wire loom and 3M Super 33+ electrical tape for some extra abrasion protection and to make it look OEM. I didn’t used the included 2 button remote. Instead I found a larger round remote and stuck it on top of a low profile cupholder ashtray. I originally programmed the rear view mirror homelink buttons to control the valves but it just felt odd reaching up to do so plus you have to hold it down a bit longer to get it to activate . I like how the cupholder solution is within easy reach.
2017 Chevrolet Corvette
2023 BMW M240i xDrive Last edited by Coconut; 01-21-2023 at 10:24 PM.. |
01-20-2023, 09:31 AM | #3 |
Joint Chiefs of Staff
24206
Rep 190,807
Thank you for posting
Coconut751.00 |
01-21-2023, 04:52 AM | #4 |
Rep 502
Decided to mount the module higher up after noticing the wireless RF remote doesn’t always work. I took off the passenger side carpeted trunk panel and found a nice spot above the fusebox. No issues with the remote now.
Passenger side carpeted trunk panels removed. Repositioned module on top of the fusebox frame.
2023 BMW M240i xDrive |
02-11-2023, 10:14 AM | #5 |
Rep 201
Drives: 2023 BMW 240i xDrive
Wow major props for tackling this project. I run the other way when it comes to anything electrical. Just that exposed fuse panel makes me break out in a cold sweat. I’d manage to short out the whole car or burn it to the ground.
These are the first photos I’ve seen of the exposed battery in a G42. My 2015 had a hinged panel that lifted up to expose the battery. Not the case in the 42. Does that trunk panel just pry up? I was just looking at it and didn’t see an obvious way to open it. Great pics always accompany your posts.
2023 BMW M240i
2015 BMW 235xi Alpine White, Coral Red Dakota.Traded 2009 BMW 328xi Alpine White-Traded |
Coconut751.00 |
02-11-2023, 01:22 PM | #6 |
Rep 502
^Thanks
Yes, the trunk panel just lifts up however it is nearly impossible to grab it with your hands since the fitment is so tight. I had to use a screwdriver to wedge into the side to pry it up.
02-11-2023, 03:11 PM | #7 |
Rep 706
ya mean yours didn't come with this?
kidding...just took some strap webbing, glued to back to make a lift loop. |
02-11-2023, 03:55 PM | #8 |
Rep 201
Nicely done.
2023 BMW M240i
08-05-2023, 07:01 PM | #9 |
Rep 426
Did mine today. I went with your original location. I pretty much plan to leave it wide open except the occasional long trips with the wife. That plastic plug was annoying. I popped it out, Drill the center to cable size. Used a razor to slice it 4-6 times at different angles so it could spread open enough for the Dahler plugs to squeeze through.
I took 2 quick pictures. The trunk shot was before i cleaned it all up and the other shot it how easy the wires come through that hole. I tucked the wires in with zip ties and loosened the bolt on the heat shield above the valve and wedge a corner of zip tie in there before tightening it back up to keep the cable off the exhaust. It for sure made the system louder. I need to take some videos. That extra bit of valve opening fully gave me what felt like a few more pops, bangs and burbles. Cold start was absolutely amplified like very loud. I think you would need to jack or use a ramp if you want to get the dahler unit under the car but by putting it in the trunk you can easier do it on your back in the driveway.
'22 M240i BSM, Shadowline, Black 791M wheels, Red Calipers, ///M Carbon Front Lip, ///M Carbon Spoiler, ///MCarbon Door Sills, Milltek Catback w/Black Tips, Dinan Carbon Intake/Engine Cover, AA Catted DP, Dalher Valve Controller, OEM+ Strut Bar, Red Start/Stop, Floating center caps, TLG Mud Flaps, Black Badges, Led Projectors, 50th Emblems, Carbon Diffuser/Mirrors w/smoke signals/Side Wings/Cooling Shroud/KIES fire extinguisher, Yellow DRL
Coconut751.00 |
09-01-2023, 03:58 PM | #10 |
Rep 40
For around $225 USD there's also the SST controller which seems like it does everything the Dahler does (including the exhaust valve position memory) for much less cost. Built in Germany, seems to be well regarded in the Audi community.
https://www.sst-spezialsteuergeraete...j-ab-2021.html |
Ruebarb375.00 |
09-03-2023, 08:14 AM | #11 | |
24206
Rep 190,807
Ruebarb375.00 |
09-29-2023, 02:58 PM | #12 |
Rep 747
12-23-2023, 08:45 AM | #13 |
Rep 1
super easy install.
Thanks for tips and ideas.
Super easy to install ran it through battery well in trunk and zip tied to stock wires. I used a little aviation heat resistance tape to cover wires. i used some dollar tree velcro tape and attached where I liked it to open and close valve next to pedal tuner. |
12-29-2023, 01:31 PM | #14 | |
24206
Rep 190,807
01-29-2024, 02:44 PM | #15 |
Rep 391
Drives: 2011.75 M3 Space Gray
Mike do they work with the Dinan exhaust system? Does the SST have a model that works with the 2 valve Dinan exhaust? I am interested in a controller. I have a 21 G20 M340i. These are some excellent examples! Thank you everyone for the great information and DIY’s. Last edited by 330iToy; 01-29-2024 at 02:47 PM.. Reason: Updated model of car |
01-29-2024, 04:20 PM | #16 | |
24206
Rep 190,807
I can't guarantee that the controllers will work with exhaust systems that do not reuse the stock valves, but I don't see a reason why they wouldn't.
330iToy71.00 |
