01-24-2023, 11:35 PM | #1 |
Rep 9
Drives: 2012 bmw 335i n55 F30
N55 vacuum pump sounds like rod knock
Hello new to the forms but I always read them
Always helps me out thank you in advance. I’m having issues with the vacuum pump it’s making rod knock noise and as soon as I disconnect the vacuum hose that goes from the pump to the valve cover noise goes away I’m wondering if it’s the pump it’s self or somthing in the valve cover restricting airflow Also, valve cover is brand new installed about 300 miles ago I was driving and all of a sudden I heard a noise and Car went into drive train malfunction, and I heard a rod knock noise, but it turns out it’s not the engine because once I disconnected the vacuum pump noise goes away any help will be much appreciated |
01-25-2023, 02:37 PM | #3 |
Rep 9
I’m getting 11A002 fuel pressure below target
And 165014 shaft sensor |
01-25-2023, 05:32 PM | #4 |
Rep 7,622
IIRC the vacuum pump interacts with the HPFP so that would be consistent with that code. i would do some reading/searching on that, i have seen someone post in detail about that system but i don't know much about it.
01-25-2023, 05:35 PM | #5 |
Rep 9
I left it to a mechanic his going to replace it and go from there I guess see what happens I also got low oil pressure today hopefully the chain didn’t break
01-29-2023, 04:15 PM | #8 |
Rep 9
Car has JB4 tune
I took it to a mechanic vacuum pump is bad I’m replacing vacuum pump and all the timing guides also rod bearings since there going to be in there I might as well change the oil pump too |
01-29-2023, 06:33 PM | #9 |
Rep 7,622
02-03-2023, 08:42 AM | #10 |
Rep 145
How does it sound? Did it sound similar to this?
https://youtube.com/shorts/qIY80twOGbA?feature=share I will upload a better video but for me, noise continues after disconnecting the vacuum hose...I'm at a lost on what to do The noise also increases in frequency as I rev too Here's another vid. You can hear this lower toned, constant noise. I move the cam over towards the cylinders and you can hear that it sounds like normal N55 injector noise...when I bring the camera back to the other side of the engine, you can clearly hear something different. The noise speeds up as the car revs up too. When I unplugged the vacuum line from the pump to the valve cover, the noise continues. I can also hear/feel the vacuum and suction from that tube so I am still wondering what it can be. Last edited by kickthecan; 02-03-2023 at 11:59 AM.. |
02-03-2023, 02:25 PM | #11 |
Rep 9
In my case my noise was more of a rod knock noise but ended up being my vacuum pump got locked up and broke the oil pump guide car is still at the shop getting a lot of work done
02-03-2023, 10:38 PM | #12 |
Rep 269
If I may ask, how many miles on your N55 engine?
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
02-03-2023, 11:03 PM | #13 |
Rep 9
145k miles
02-03-2023, 11:18 PM | #14 |
Rep 269
Oh, are there mods to your engine/turbo/software as well? Curious as to the longevity of the N55. Want to have an idea what I might be getting into if I buy an M235i.
Thank you for your answers!
