01-27-2023, 11:28 AM | #1 |
Administrator
44559
Rep 21,340
BMW Model Updates for Spring 2023 (BMW USA Specific Release)
BMW Model Updates for Spring 2023.
27.01.2023 PRESS RELEASE BMW USA News
Woodcliff Lake, NJ – January 27, 2023…Innovations in individualization, digitalization, and electrification will enhance the BMW model range in the spring of 2023. BMW Operating System 8 and the latest-generation BMW iDrive vehicle interface including the BMW Curved Display will be introduced into the BMW 4 Series and M4 in March 2023. BMW Crystal Headlights – first seen on the new BMW 7 Series – will be available for the BMW X7 from April 2023. Both these luxury models and the fully electric BMW iX will also be offered with the enhanced Parking Assistant Professional, which enables the Remote Control Parking and Maneuver Assistant functions to be controlled via iPhone. And Highway Assistant will be available on X7 and iX models for the first time. BMW 4 Series and BMW M4 now with BMW Operating System 8 and BMW Curved Display. Starting in March 2023, all BMW 4 Series and M4 models will be equipped as standard with BMW iDrive 8 and the BMW Curved Display. The fully digital screen is composed of a 12.3-inch information display behind the steering wheel and a 14.9-inch control display. The modern cockpit design and the extended capabilities of the BMW Intelligent Personal Assistant enable a significant reduction in the number of buttons and controllers in favor of voice and touch control. M4 models will feature M-specific graphics and displays. All 4 Series variants will also include a new toggle gear selector on the center console. M high-gloss Shadowline trim for the side window surrounds will also be standard on M440i models and i4 M50. Aluminum Rhombicle in anthracite replaces Aluminum Tetragon trim, and M4 customers will be able to order Sensatec upholstery for the dashboard. New options for the BMW X7: Highway Assistant and BMW Crystal Headlights For the first time, Highway Assistant will be offered on the BMW X7 as part of the Driver Assistance Professional Package. This suite of Advance Driving Assistance Systems allows for attentive hands-free driving on limited access highways at speeds up to 85 mph. BMW Crystal Headlights – first introduced on the new BMW 7 Series – will be available on the BMW X7 starting in April 2023. Genuine crystals from Swarovski positioned in the upper section of the lights and backlit by LED units act as side marker lights and daytime running lights. In daylight and when lit at night, the crystals reflect the light in a multitude of facets. Also from April 2023, the optional Extended Shadowline exterior trim – available with the M Sport Professional package – will include a rear trim strip in black high-gloss. BMW 7 Series, X7, and iX: control parking maneuvers from your iPhone. The extended Parking Assistant Professional available for the 7 Series, X7, and iX from spring 2023 brings greater ease when parking and maneuvering. Here, BMW employs innovative digital technology to make further advances in the area of automated driving and parking. The extended Parking Assistant Professional gives drivers the ability to guide their BMW into and out of parking spaces and carry out more complex maneuvering from outside the vehicle via the My BMW app on their smartphone (available with My BMW App Version 2.1 2.x). This functionality facilitates the use of tight or difficult-to-access parking spaces. For example, the driver can pause a parking process that is already underway, exit the vehicle, and resume the maneuver while they monitor the area around the vehicle from outside. They can then also control the vehicle’s exit from the space from their iPhone using the Parking Assistant Professional. Controlling the vehicle from outside is also possible for more extensive maneuvers using the Maneuver Assistant function included in the Parking Assistant Professional. Using the My BMW app, customers can control the vehicle from up to six meters away. The Maneuver Assistant can also record and store up to ten maneuvers at different locations, each covering a maximum distance of 200 meters and up to a combined total of 600 meters. When the vehicle returns to one of the stored starting points, the system performs all the driving tasks required to navigate the distance, including acceleration, braking, steering, and, if required, multiple direction and gear changes. And it can do so whether the driver remains inside the car or chooses to control the maneuver from outside using an iPhone. BMW iX now with manual pre-conditioning for the high-voltage battery. All model variants of the purely electric BMW iX will be equipped with a further developed version of the predictive heat management technology for the high-voltage battery from March 2023. As in the BMW i7, it will be possible to initiate pre-conditioning of the battery manually, when the navigation system's route guidance is not active. Pre-conditioning the battery prior to charging maximizes the charging rate when using a DC fast-charging station. Waste heat from the electric motors is used to adjust the temperature of the battery. Highway Assistant will also be available on all iX models as part of the Driver Assistance Professional Package. BMW Digital Key Plus with extended functions In spring 2023, BMW Digital Key Plus, already available for many current BMW models, will gain new and enhanced functions. These will include automatic vehicle unlocking when approaching the car for owners of Samsung and Google smartphones running Android operating systems and the UWB (UltraWideband) chip. BMW Digital Vehicle Access allows users to share their BMW Digital Key between Apple iPhones and Android smartphones for the first time. Shared BMW Digital Keys are also easier to activate in the vehicle. With the latest BMW software upgrade, a BMW Digital Key shared via smartphone can be activated directly in the vehicle by entering an activation code. Previously, a conventional vehicle key had to be located in the passenger compartment. BMW 7 Series: new exterior paint finishes including new Individual two-tone. From March 2023, the BMW 7 Series range will be available in a deep BMW Individual Frozen Tanzanite Blue metallic exterior paint shade. Customers will also be able to order the exclusive BMW Individual two-tone paintwork in BMW Individual special paint finishes.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
jphcbpa372.50 VirtualGuitars7909.00 BrendanZ0402347.00 JustChris17671.50 P_GT39.50 LENBMW2.00 corbinwilliams113.50 |
01-27-2023, 02:03 PM | #2 |
Rep 5,796
Drives: 2024 BMW XM Label
“Highway Assistant will also be available on all iX models as part of the Driver Assistance Professional Package.”
**** yeah! Hope I’m reading that correctly for existing iX owners! |
Xyz$12341.00 |
01-27-2023, 02:09 PM | #4 |
Rep 120
Now 4 series owners will have the privilege of iDrive 8 making navigation by CarPlay unusable.
BMW refuses to acknowledge that they broke CarPlay with iDrive 8. Dealers are throwing their hands up too. Come on BMW - fix this thing. |
01-27-2023, 02:26 PM | #5 |
Rep 52
My iX is being built as I type. It won’t arrive with HA but I’m hoping I can add it. 🤞
01-27-2023, 02:29 PM | #6 |
Rep 5,796
01-27-2023, 02:55 PM | #9 |
Rep 52
VirtualGuitars7909.00 |
01-27-2023, 03:23 PM | #10 |
Rep 6,756
Drives: E46 M3, GT3 Cup, X7, G80 M3
What have people been experiencing? I have not observed issues with the X7 and idrive8.
'23 X7, '22 GT3 CUP, '25 M3 LSB on Tartufo
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential, JRZ 3-Way, Flossmann Wide Body, Brembo Motorsports, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
01-27-2023, 03:29 PM | #11 |
Rep 120
IDrive 8 and CarPlay don’t play nice together. It results in the GPS location in any CarPlay navigation app being off - showing your location off by anywhere from 100 feet to a mile. It renders nav via CarPlay useless. Multiple threads active under 3 series and x1.
01-27-2023, 03:50 PM | #13 | |
Rep 6,756
01-27-2023, 04:07 PM | #14 |
Brother
895
Rep 712
It's amazing how little I care about this brand today versus several years ago.
I don't think I've enjoyed a single decision they've taken since around the opening of Potasi. Pessimism aside, that greenish-blue is downright gorgeous Anyone know the color code? |
01-27-2023, 05:11 PM | #15 |
Rep 134
I am telling you, some of these sophisticated greens showing up are
01-27-2023, 05:21 PM | #16 |
Rep 14,474
Garage List 2025 BMW M2 [9.50]
2022 G82 M4C X-Drive [9.81] 2018 F80 M3 CS [9.92] 2018 BMW i3 REx [5.33] 2015 BMW i3 REx [3.00] 2016 BMW F80 M3 [7.63] 2016 BMW F30 340i ZTR [10.00] 2013 BMW F30 328i [8.50] 2006 Audi S4 25Quattro [7.33] |
This is the first I’ve heard of this. What’s the problem?
2025 G87 ///M2 LCI - Stock Previous: 2022 G82 M4 Comp X-Drive • 2018 F80 M3 CS • 2016 F80 M3 |
01-27-2023, 07:20 PM | #17 |
Rep 966
Drives: M8 GC || M5 Comp || X7 40i
How much do you think the Crystal headlights will be?
2024 M8 GC Black/Black || 2021 M5 Carbon Black/Midrand beige || 2021 X7 40i Amertin metallic with Ivory white merino
2019 M5 F90 || 2018 X5 s35i || 2017 M5 F10 with Arkapovic Exhaust || 2016 535 || 2012 535 hated it after the E60 || 2010 535 E60 - my fav || 2008 528 E60 my first |
01-27-2023, 10:10 PM | #19 |
Rep 638
I'm curious if the rumored engine refresh is still happening
Link https://g42.bimmerpost.com/forums/sh...d.php?t=901686 Last edited by sikotic; 01-27-2023 at 10:24 PM.. |
01-27-2023, 10:20 PM | #20 |
Rep 1,873
Drives: 23' X7 40i M Sport
Nice to see them move on from the rear chrome strip on the X7 with the Extended Shadowline option. The ‘mirror bar’ on the MY23 is hokey and impossible to replace because it extends into the tail lights.
