01-29-2023, 11:01 AM | #1 |
Rep 407
Steering Wheel Off Center
Do you have dealer try to fix or live with? I am OCD. I know dealer will do some kind of damage to steering wheel trying to move it. Lol! It’s slightly to the left.
01-29-2023, 02:11 PM | #2 |
Rep 433
Sorry, but can you re-word your question? I can’t make any sense of what you are asking
M240i x-drive (Thundernight, 19" 893Ms, Cognac, Pro Pack, Adaptive, Sunroof)
01-29-2023, 03:10 PM | #3 |
Rep 504
If your steering wheel is off center you will need a wheel alignment which adjusts the tie rods. The steering wheel has no adjustment.
2017 Chevrolet Corvette
2023 BMW M240i xDrive |
01-29-2023, 03:14 PM | #4 |
Rep 407
01-29-2023, 03:23 PM | #5 |
Rep 433
Then it sounds like the alignment needs looking at by a garage
01-30-2023, 03:09 PM | #8 |
Rep 41
Hey Bandit, I had the same issue on my new M240. The dealer had to made an alignment twice in order to get it center. Like somebody mentioned, they do not remove the steering wheel in order to fix it. And I don't blame you, we are paying for a BMW, we can expect and ask for top quality.
DrJLag420799.00 |
01-30-2023, 04:32 PM | #9 | |
Rep 407
02-01-2023, 05:44 PM | #10 |
Rep 104
I’ve never removed a steering wheel but in case its not tire alignment/camber, tire pressure, etc. I did watch a video the other day of a guy replacing the steering wheel paddles and mentioned making sure the steering wheel was aligned properly when tightening back up so just throwing out an alternative if its not the other things
02-01-2023, 08:03 PM | #11 |
Rep 504
You cannot misalign a steering wheel since it’s splined and keyed. OP’s issue will be solved by an alignment.
Giovany_249.00 |
02-06-2023, 07:15 PM | #12 | |
Rep 1,200
You need to experience the car on a variety of roads. If the steering wheel is indeed off center the tech will use a level that rests on the spokes of the steering wheel. The wheel centered/level this can have the front wheels turned a bit. The tech can adjust the tie rods to bring the front wheels into proper alignment. Bear in mind though you will be faced with on some roads having to counter steer to deal with the crown/camber of the road. And on multi-lane roads while the right most lane may require you steer to the left a bit on the other lane you may have to steer to the right a bit. |
11-06-2023, 07:01 PM | #13 |
Performance Driving Coach
1273
Rep 631
Drives: 2024 M2 (G87)
So is mine! It was like that since delivery. Did you get that fixed?
11-06-2023, 08:14 PM | #14 |
Rep 407
11-06-2023, 08:22 PM | #15 |
1273
Rep 631
I’m going for my break in service tomorrow and telling them to fix it.
11-07-2023, 06:07 PM | #17 | |
1273
Rep 631
It’s all fixed now and they did not charge me. I’d suggest getting this done so you don’t wear your tires wrong.
11-07-2023, 08:04 PM | #18 | |
Rep 407
Autobahn SoCal1273.00 |
11-10-2023, 08:08 AM | #19 | |
Rep 477
11-10-2023, 09:10 AM | #20 |
1273
Rep 631
Steering wheel off center due to toe in and camber. Alignment fixed the issue.
11-10-2023, 09:26 AM | #21 | |
Rep 477
Apoligies if I’m being dumb. Have a new car arriving soon and will keep an eye out for this |
11-10-2023, 09:31 AM | #22 | |
1273
Rep 631
I’ve heard several G87 owners complain of this as well so it is very annoying for the factory to screw this up. I thought I was being OCD until BMW service verified this and told me I was the 5th one they have seen with this issue. I felt it most on the highway I was constantly moving the steering wheel to the left to stay straight.
Evilmoretea220.50 |
