02-14-2023, 11:39 AM | #1 |
Rep 61
F31 replacement headlamp lenses?
Looking to buy a pair of replacement lenses for my F31. Can’t seem to find the oem part on FCP or any other webpage. Several aftermarket options that vary in price widely. Anyone have a suggestion or experience with buying lenses?
02-14-2023, 01:50 PM | #2 |
Rep 16,152
There is no OEM replacement lens, only aftermarket. In most cases restoring lenses is a better option than replacing them.
SirMeatPants33.00 |
02-14-2023, 06:07 PM | #3 |
Rep 61
09-13-2023, 03:56 AM | #4 | |
Rep 257
It looks like a time consuming job based on the various Youtube vids that I've seen but thinking of tackling it soon. |
09-14-2023, 01:58 PM | #5 | |
Rep 1,117
And replacing the lens is not that easy, involving baking your headlights in an oven and not destroying them as well as properly sealing them. |
09-15-2023, 08:19 AM | #6 | |
Rep 482
Exactly! SirMeatPants: You have to understand what version of the headlight you have. Is it pre-LCI or LCI as lenses are different. The pre-LCI lens version (halogen and bi-xenon headlights, both) has to have special Y shaped guides at the bottom for the bracket that installs onto them. The LCI version does not. Here is the LEFT lens with Y shaped guides for preLCI headlight: https://www.ebay.ca/itm/155663880210...Bk9SR_TB347TYg The bracket is #14 on the diagram below. The bracket is for gap control between the bottom edge of the headlight and the edge of the bumper cover. The LCI lenses already have the alignment guides built into them from manufacture and do not require the bracket. https://www.realoem.com/bmw/enUS/sho...diagId=63_1350
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 Last edited by Oksamit78; 09-15-2023 at 08:24 AM.. |
SirMeatPants33.00 |
