02-15-2023, 03:48 PM | #1 |
Rep 3
*Mile Hi Club*
Hey guys/gals, I’m finally ready to get relevant to the forums with my 130,000 mile sapphire black 2013 f30 sport. I received a drivetrain error message on my display with power cut on the fwy. We had the car towed to vtmotorwerks in Pleasanton, CA. They reported back that the valvetronics system needs servicing. I am a DIY guy, but prefer a professional touching the motor.
Coming from hi maintenance ///M cars, my gf and I were hoping you could provide insight on other common repairs recommended to oil the N55 (ex. timing chain, rods, etc.). We have owned the car young @ 57,000 and has been a great car without crazy issues. It is a DD that she takes to school so I’d like to prevent any rescue missions. My question is, any hi mileage owners that can recommend anything major while the car is in pieces? We would like to keep the car long term as it is a milestone car entering our 30s and has kept us safe. 2nd owner. 2013 335i Sport 130,000 Miles Maintenance done: Valve cover Oil Filter Housing Gasket Charge pipe Coolant hoses Paint correction+ceramic Toyo Tires Proxes Sport Last edited by F30ST; 02-15-2023 at 04:03 PM.. |
02-16-2023, 06:45 AM | #2 |
1297
Rep 3,536
Trans should have been serviced 2 or 3 times by now as well as at least one water pump...
02-16-2023, 10:56 AM | #3 |
Noob
70
Rep 255
be prepared to do the OFGH and Coolant hose a second time and I switched out the water pump at 100,000 miles just to be safe. I serviced my tranny (drain and fill) at 138,000 miles for the first time and there was no slippage or noises of any kind before or after so get that done ASAP, since I waited so long (you did as well) I plan on doing another drain and fill very soon. currently at 144,000 and going strong
FBO, MHD Stage 2+ E20, Xhp Stage 3
02-22-2023, 11:43 PM | #4 | |
Rep 664
Drives: 2013 BMW 335i
To OP: I also changed out the oil filter housing gasket, it tends to start leaking. |
02-22-2023, 11:46 PM | #5 |
Rep 664
Can you guys advise which water pump i need? Found two different water pumps. I have a 2013 F30 N55 with M-Sport package
https://www.fcpeuro.com/products/bmw...rg-11518635090 and https://www.fcpeuro.com/products/bmw...ve-11517583965 |
02-23-2023, 07:38 AM | #6 | |
Rep 643
M235i rwd 6mt
02-26-2023, 11:11 PM | #7 |
Rep 835
Drives: Bmw 335i f30 N55 ( sold)
Mine has 111k miles.
My PCV valve just went at 110k miles. Had to get a new valve cover Camshaft sensor went One coil went 90kish miles sparks we’re done by me, Valve cover gaskets replaced 75k miles inlet cracked and charge pipe blew off 60k miles one plug went I’m currently planning to have a ship do my OFHG as mines leaking pretty bad And I had some serious electronic issues which I replaced battery fixed all that SOS malfunction showed up, coded that out Front passenger seat mat sensor bad; just bought a new seat off eBay I got this 335i for 25k with 40k miles sport like edition. If I didn’t get it as cheap as I did about 6.5 years ago I would of sold it a while ago. But car market so expensive right now I’m just fixing and holding on
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
02-27-2023, 09:06 AM | #8 | |
Rep 93
02-27-2023, 12:16 PM | #9 |
Noob
70
Rep 255
yes sorry i meant OFHG it was a typo and it was also my second time replacing it, first time was at 60,000 miles which I replaced with the synthetic rubber gasket from Bavarian Auto but it cracked again at 135,000 miles and so did my coolant line (for a second time). I've been FBO and tuned for 80,000 miles now. Coolant line is a cheap part so I would keep an extra in your trunk otherwise you could be left stranded.
02-28-2023, 10:05 PM | #10 | |
Rep 664
03-01-2023, 09:46 AM | #11 | |
Noob
70
Rep 255
17128570061, 17128507235 Its one of the easiest parts to fix on this car but just like the water pump there will be zero symptoms of this line cracking or breaking it literally just happens all of a sudden.
03-01-2023, 09:22 PM | #12 | |
Rep 664
03-01-2023, 09:24 PM | #13 |
Noob
70
Rep 255
Yes exactly keep an extra in your trunk, it will Crack again
03-07-2023, 08:38 PM | #14 | |
Rep 835
I have learned from YouTube and doing on my own, which for future bmws will help me lol
2012 bmw 335i sedan
03-07-2023, 11:47 PM | #15 |
Rep 3
thanks for all the feedback guys.
I just got the car back from my indy and the valvetronic servo motor went out along with the replacing the eccentric shaft. I am still hearing a slight tick upon idle so may dive into getting the timing chain and other internals checked out to bulletproof my n55 after putting some miles on. I want to do simple bolt ons because I do come from a vf engineering s/c'd e46m and read all about the instant power gains. About $5,000 into this motor to get it DD worthy so the itch for power is starting to kick in. I have also replaced the pcv valve and coolant expansion tank line in the past I might also add. |
03-07-2023, 11:52 PM | #16 |
Rep 3
Tischerbmw @ getbmwparts.com is usually where i get my OEM Parts for a pretty good cost or autohauosaz.
to do list: expansion tank 5k oil change interval radiator belt tensioner belt drive pulleys waterpump battery various cooling hoses in the way |
