BMW 2 Series Technical Topics (G42) Wheels / Tires
      03-09-2023, 03:43 PM   #1
Ca86108
Drives: m2 comp, f80 m3 comp, e92 m3 c
Widest tires on stock wheel front and rear? (no fender flares)
What are the widest tires I can fit on the front and rear with the base fenders (not fender flares from high performance and cooling package) on the stock/base wheels (not from the high performance and cooling package)
      04-02-2023, 11:11 AM   #2
Saturns
Saturns's Avatar
175
Drives: G42,570GT,Lp5704STS,F36,F34
To keep within xdrive specs. No flares. None ZTK.
Tires
F 245/40R19
R 275/35R19
Wheels
Front
19x8.5
+25
5x112
66.6
Satin Bronze
Rear
19x9.5
+33
5x112
66.6
Satin Bronze
I just don't remember if I had to put 10mm spacer on front to make flush.
      04-02-2023, 11:43 AM   #3
Saturns
Saturns's Avatar
175
Originally Posted by SlowG42 View Post
This is soooo clutch! Almost identical wheels specs to what I’ve been looking at! Stock ride height?
Yes stock height.
Wheels....
https://www.superspeedwheels.com/flowform-rf05rr
      04-13-2023, 01:38 PM   #4
Baldilocks73
Baldilocks73's Avatar
323
Drives: G42 M240i (on order)
The Non-ZTK wheels aren't 9.5" wide though, so fitting a 275 might not be optimal.
      05-19-2023, 10:33 AM   #5
rockblock
rockblock's Avatar
62
Drives: 2023 M240 xDrive
I have 19" style 893 non-ZTK and they are 9.5 rears
Here are the tire fittings per wheel width
https://www.tiresandco.ca/tire-equivalence-advice.html
      05-20-2023, 08:15 AM   #6
CTGT2005
Drives: 2022 m240i
Stock wheels no fender flare are a 19x8 if you got the one that came with a square set up and 225 run flat tire. Generally if the wheel is about 85% or more of the tire width it looks okay. Start going wider than you get bulging sidewalls and it looks off.
8x25.4mm = 203mm/225 = 90%
You could get away with 235 tires on stock wheels, 245s even but the look would be a little off.
      05-22-2023, 10:21 AM   #7
Baldilocks73
323
The 893 wheels ARE the ZTK wheels.
      05-23-2023, 02:42 PM   #8
rockblock
rockblock's Avatar
62
Not sure, my dealer did not mark them as ZTK on the BOS.
      05-23-2023, 02:51 PM   #9
Baldilocks73
323
Yep. Those are the wheels that are part of the ZTK package.
      05-23-2023, 03:43 PM   #10
rockblock
rockblock's Avatar
62
Maybe in the US - here in Canada they don't offer ZTK...I think here it's called "M Enhanced Track package" - it's an extra $3,500 CAD and provides Adaptive suspension + 893 wheels (all of which you can configure separately)
      07-27-2023, 12:09 PM   #11
nype
nype's Avatar
Drives: BMW M240i / BMW X5 35d
M Enhanced Track Package:
19" M Lt/Aly Wheels, Double-Spoke, 893M, Jet Black, Burnished,Perf. Non-RFT
Adaptive M Suspension
M Technology Package
M Technology Package:
With the M Technology Pack the increased heat capacity of the braking and cooling systems guarantee a long-lasting high performance under extreme driving conditions (similar to motorsport) (especially in conjunction with high outside temperatures). Includes upgrades for the drive train cooling system and the M Sport brakes.
