Possible Diff Issues?
03-28-2023, 09:10 AM | #1 |
Rep 19
Drives: BMW 328i xdrive Sportwagen 6MT
Hello!
I have a 2012 e91 6spd with an n52. Recently I've been hearing two odd noises while driving, one of which I am thinking could be a diff going out. Anywhere above around 30mph, I start to hear a moderately loud buzzing noise. The pitch of the buzz increases with speed and is at its loudest on the highway. The other noise happens only around 50-60mph and seems to be correlated to throttle input. The only thing I can compare it to is a locomotive as it sounds like the car is sort of chugging. Power does not seem to be affected when this noise happens, and there is no jolting or odd movement. I really have no idea what this could be and I have not been able to find any other posts about issues like this. I've tried capturing these noises on video but they really do not come in well at the speeds I hear them since I have roof rails and a ski box. For reference, I've done virtually all the big engine maintenance items within the last year (water pump, VCG, Oil filter housing gasket, and oil pan gasket). Car just hit 137k miles. Please let me know if you have any ideas! Thanks, -Gavin |
03-28-2023, 02:01 PM | #2 |
Rep 1,105
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
Just last weekend sent my e91 to a friend for his kid. At 130k miles it needed a new wheel bearing on the driver's side rear. But that was clearly audible at 20mph and up. It was not a buzzing noise but more of a whine that went up and down based on speed. I think it is rather common for the e9x series to need a rear wheel bearing or two near the 130k mile range. I would have an independent BMW expert take a look and listen.
gavinm00210.50 |
03-28-2023, 03:40 PM | #3 |
Rep 1,232
Have you evaluated the wheel bearings for the vehicle? I have needed to replace all rear bearings on both of my cars at least 1x.
You could also check the axle shafts to ensure the boots haven't broken and leaked out all the grease. |
gavinm00210.50 |
03-29-2023, 10:58 AM | #4 |
Rep 19
I have not looked at the wheel bearings yet, the only reason being noise did not sound like a wheel bearing to me. My first car was an E53 X5 that had a wheel bearing go out and it sounded much different. I will still take a look just to make sure as it very well could sound different on this car.
I will check on the cv boots too although I did my front axles a couple of years ago so the rears should be the only possible problem. Thank you all for your suggestions so far! |
03-30-2023, 12:26 AM | #5 |
Rep 218
Does it sound like this ?
https://youtube.com/shorts/7_QQmTKz1SM?feature=share |
gavinm00210.50 |
03-31-2023, 03:30 PM | #6 | |
Rep 19
03-31-2023, 05:48 PM | #7 |
Rep 218
Its not that loud on roads its only loud in the shop. Those light are only on because traction control completely off and was getting up to speed to diagnose.
That car has no lights when on the ground.. if its sounds similar its a differential pinion Bearing.somecases its bad and will cause vibrations and rumbling . In this case it only made a whirring sound with no symptoms of crunching or vibrating or dragging i changed the diff oil and the noise decreased alot and the old oil barely had any metal shavings. Im not a expert on bmw differentials but with my experience with a dodge nitro differential had the same sound . And everyone said its going to fail and it didnt impact any performance and stayed whinning for 6 years . I woould expect BMW diffs being just as strong... if you feel crunching and vibration and a impact on performance then its recommended to change it |
04-03-2023, 08:47 AM | #8 | |
Rep 19
04-03-2023, 01:06 PM | #9 |
e91Owner
425
Rep 1,130
I’m surprised no one mentioned the guibo yet—I’ve never experienced it myself, but there are plenty of people who have had similar issues to yours and it was the culprit.
04-03-2023, 08:18 PM | #10 |
Rep 2,143
The humming /chugging like noise around 50mph is likely center driveshaft bearing (or CSB)
I plan to replace mine in the near future as I have that noise too. It is really only audible on the highway at around 50mph. I have refreshed my entire underside and changed all the fluids and the noise is still there, so I know it's not diff, axles, bearings etc. |
