Errors codes on 320D N47
03-28-2023, 09:48 AM | #1 |
Rep 2
Hi All,
I am looking for some advice. I hit a nasty pot hole on the motorway and the traction control light came on with the brake light and disabled the cruise control which was in use at the time. So could only continue my journey in non cruise mode. Since then I have scanned the car with INPA 5.0 and got loads of errors. It doesn't seem to be a ABS sensor fault but I may be wrong. Below is the error codes from INPA. Date: 27.03.2023 17:24:44 Model: E89X Scope: all control module JobStatus: OKAY Quantity: 14 ----------------------------------------------------------------- ADR Gen. name JobStatus 92 VIRTSG92 ERROR_ECU_SERVICE_NOT_SUPPORTED ----------------------------------------------------------------- ADR Gen. name JobStatus Number of errors• Error code Kind of error 00 JBBF OKAY 1 Error stored• A6D1 61• 12 DME/DDE OKAY 15 Error stored• 4C12 61• 4A74 21• 4A79 21• 4A6F 61• 4A5F 61• 4A4F 61• 4A3F 61• 483D 61• 4DFF 21• 44CC 21• 4E04 21• 4E09 21• 4A09 61• 4A7E 21• 3FF1 A1• 17 EKP OKAY No Error stored• 18 EGS OKAY 1 Error stored• 51B0 68• 30 EPS OKAY No Error stored• 40 CAS OKAY 5 Error stored• A10A 24• A0B5 64• A0B0 28• A107 28• A0B3 28• 41 DWA OKAY No Error stored• 50 SINE OKAY No Error stored• 56 FZD OKAY No Error stored• 60 KOMBI OKAY 3 Error stored• A3AC 20• A3B9 20• A550 20• 62 MOSTGW OKAY No Error stored• 63 MASK/CCC OKAY No Error stored• 72 FRM OKAY 3 Error stored• 9CB4 62• E594 24• 9CD4 24• 78 KLIMA OKAY 1 Error stored• E71C 24• ================================================== ============== E R R O R M E M O R Y --------------------------------------- Date: 27.03.2023 17:35:05 ECU: DSC_87 JobStatus: OKAY Variant: DSC_87 ------------------------------------------------------------- RESULT: 2 error in error memory ! ------------------------------------------------------------- 5E20 5E20 - pressure sensor 1 electrical faulty. Error counter: 255 Logistic counter: 40 Mileage 220624 km Vehicle speed 97.00 km/h Brake light switch 0.00 0/1 switch brake fluid level 0.00 0/1 ASC/DSC_aktive (status of ASC/DSC_switch) 1.00 0/1 brake pressure identified 0.00 0/1 ABS-active 0.00 0/1 ASC-active (BMR) 0.00 0/1 ASC-active (AMR) 0.00 0/1 GMR-active (GMR) 0.00 0/1 GMR-active (MMR) 0.00 0/1 CBC-active 0.00 0/1 MSR-active 0.00 0/1 TDR-active 0.00 0/1 SDR-active 0.00 0/1 DBC-active 0.00 0/1 RTA active 1.00 0/1 Run-Up Mode 0.00 0/1 No matching error symptom. Test conditions fulfilled Error present now and already stored Error would cause a warning lamp to light up Error code: 5E 20 E0 FF 28 6B BA 61 08 00 04 ------------------------------------------------------------- 5DE0 5DE0 - BLW FA not/wrong initialized. Error counter: 126 Logistic counter: 40 Mileage 224792 km Vehicle speed 0.00 km/h Brake light switch 0.00 0/1 switch brake fluid level 0.00 0/1 ASC/DSC_aktive (status of ASC/DSC_switch) 1.00 0/1 brake pressure identified 0.00 0/1 ABS-active 0.00 0/1 ASC-active (BMR) 0.00 0/1 ASC-active (AMR) 0.00 0/1 GMR-active (GMR) 0.00 0/1 GMR-active (MMR) 0.00 0/1 CBC-active 0.00 0/1 MSR-active 0.00 0/1 TDR-active 0.00 0/1 SDR-active 0.00 0/1 DBC-active 0.00 0/1 RTA active 1.00 0/1 Run-Up Mode 0.00 0/1 No matching error symptom. Test conditions fulfilled Error present now and already stored Error would not cause a warning lamp to light up Error code: 5D E0 60 7E 28 6D C3 00 0A 00 04 ================================================== ========== |
