03-31-2023, 12:36 PM | #1 |
Rep 62
Correct Oil pressure readings / oil pressure low warning
Hello all,
I recently got oil pressure low warning. and it goes on and off All I could think about is faulty reading from the sensor but I actually recently replaced the sensor (3rd party). So I checked few pressure readings engine off : 2x inhg which is around 8~13 psi, I dont remember single digit and when it starts it goes up to 78~85 inhg (36~41 psi) I'm not sure if these reading are correct or not what are expected readings when off and cold start? |
03-31-2023, 06:50 PM | #3 |
Rep 779
With the engine off, there should be 0psi/inhg.
The N55 has a 2 stage oil pump. At low RPM you should expect around 40psi. At higher RPM you should expect more than 65psi. There is an oil volume control valve that may be bad. https://www.fcpeuro.com/products/bmw...ve-11417622768 |
03-31-2023, 06:51 PM | #4 |
Rep 62
03-31-2023, 06:52 PM | #5 | |
Rep 62
thanks |
04-02-2023, 02:19 AM | #6 |
Rep 2,376
Idle should be +/- 40psi
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
04-02-2023, 11:49 PM | #7 | |
Rep 62
04-03-2023, 02:09 PM | #8 | |
Rep 779
If it's 2 wires, there may be a short between the 2 wires. Looking into the connector for the pressure sensor, the wiring harness side...Is there oil residue? Sometimes when the sensor fails, it will send pressurized oil into the wire which CAN send pressurized oil all the way to the DME, and sometimes fry it. A short could be a bridged connection with a pieces of wire, or a short could also be metal infused oil acting as a conductor that connects both wires. This is primarily a mercedes thing but it can happen to any car. Last week I had a Mercedes in the shop for a crankcase breather. The solenoid failed and sent oil up the harness all the way to the ECM. Unplug the ECM connector and the ECM was full of engine oil |
05-02-2023, 09:26 PM | #9 | |
Rep 62
I've replaced the sensor, and so far no warning. might of been bad sensor.. |
