04-02-2023, 12:24 PM | #1 |
Enthusiast
291
Rep 287
Drives: 2022 230i M Sport
Engine Cover Utility?
Okay, did some research (not exhaustive), nothing conclusive about what the purpose of BMW engine covers are.
Reasons I've seen include: noise reduction (I believe this to be true), protect from dirt/dust (BS...my engine's filthy), routing air for cooling (sounds weird), trapping heat for controlled temps (sounds odd), and finally, looks nice (agreed, but...very subjective). I heard of one BMW mechanic (connected to Scotty Kilmer's site) who felt it traps heat to the detriment of the engine and it is for looks and injector noise...hence removed. I've heard this from others too, but I also hear it is critical to the functioning of the engine or they wouldn't have it in the first place. I feel this debate is like the oil debate, never gonna have an authoritative answer. Though, I recognize it is not nearly as important as oil...in fact, not that important at all. All that said, however, is there anyone who's aware of authoritative insights on BMW engine cover utility? IMO, it's for looks and noise, nothing else. The majority of BMW buyers appreciate both, so I see why BMW would do it. I am sure this group has stronger opinions, or at least care to know. Thoughts? Last edited by Dinosoar; 04-02-2023 at 07:39 PM.. |
04-02-2023, 12:40 PM | #2 |
Rep 602
Looks and to damper the awful noise from the injectors so every owner doesn’t start to freak out.
Nothing more nothing less. Engines are ugly to the common folk so car companies cover them in plastic to make them look “nicer” |
04-02-2023, 07:17 PM | #3 |
Enthusiast
291
Rep 287
I agree...though I don't know this to be true. I took mine off and will track oil temps to see if they run slightly lower. I heard one guy claim he saw such a difference. I find it hard to believe, but will run the "test" nonetheless.
04-03-2023, 05:24 AM | #5 | |
Rep 602
You are splitting hairs here. Nothing magical happens removing that thin piece of plastic. |
danallxt738.50 |
04-03-2023, 11:37 AM | #6 |
Rep 706
yup, this is kinda ridiculous
but if you are gonna run a "test" better make sure all the variables are the same: ambient air temp same air density the same run time the same if driven, drive exactly the same route, same distance, exactly the same throttle applications etc otherwise your test is totally invalid. Also my BMW oil temp gauge is a bar graph type that is not exact enough for any comparison...i miss the digital oil temp readout of my previous vehicle. |
04-03-2023, 09:16 PM | #7 | |
Enthusiast
291
Rep 287
04-04-2023, 02:14 PM | #8 |
Rep 706
excuse me for trying to be helpful, but if you don't take into account what i mentioned your so called test is a total waste of time and misleading.
your concern about oil temp and engine cover is ridiculous anyway. |
04-05-2023, 08:15 PM | #9 | |
Rep 201
Drives: 2023 BMW 240i xDrive
Marisa Tomei: “It’s an industry term” My Cousin Vinny leaky faucet scene. CLASSIC
2023 BMW M240i
2015 BMW 235xi Alpine White, Coral Red Dakota.Traded 2009 BMW 328xi Alpine White-Traded |
Dinosoar290.50 |
04-05-2023, 10:28 PM | #10 |
Enthusiast
291
Rep 287
Oh, I believe you were trying to be helpful. Just don't know why you throw in a dash of "rude" with your advice. It's not a serious endeavor, just a question to garner people's knowledge on it, that's all. It's not ridiculous, just a conversation. You should be nicer, even on the Internet. Thanks for your concern, though.
M2siast5876.00 |
04-07-2023, 07:48 PM | #12 |
Rep 442
The cover does quiet the loud DI fuel injectors quite a bit. My wife's old Focus had DI injectors without a cover, and you could hear them in the cabin they made such a racket. Take the cover off your car and you'll hear the loud ticking.
The other purpose of the cover is actually to hold heat in. This sounds stupid, but heat management in the engine is part of the emissions control. The engine runs way cleaner and more efficiently once it is at operating temperature. When you stop the car, the cover helps to hold the heat in so that when you restart it it is closer to operating temperature. The electric water pump and thermostat are very efficient at cooling the engine in normal operation, so it doesn't add heat to the engine. The water cooling is way more effective than any convective heat loss without the cover while running. Does holding that extra heat in cause damage to other components? Especially if driven hard or in a hot environment? Well, you could argue that, but I'm not sure it makes much of a difference. In our cars there isn't much under the cover. And you could argue that rapidly changing/cooling temps without the cover could cause issues also. (Now one of the hot-vee V8 engines is a different story.) And yes, the cover is also there for cosmetic reasons. Although the only people who actually open their hoods these days would rather probably see the raw engine parts. (Like me.) |
Dinosoar290.50 |
04-08-2023, 11:14 AM | #13 | |
Enthusiast
291
Rep 287
I talked to my Genius about it...he confirmed a few things. Yes, it's just for noise muting, and looks. He said while it may affect heat build-up, it would not be noticeable in the gauges when there's active oil-cooling like in both the B48 and B58 motors...same with water, of course. He said it would merely, then, have to turn on less. Makes sense. So, I did weigh the B48 cover in at 3.5 lbs. I assume a B58 cover is easily over 5lbs....so, for us fanatics, taking weight off the front axle is good! Two, it may ease temps and cooling, and third, the cover will be it great shape when it goes back on for selling it. |
04-08-2023, 11:18 AM | #14 | |
Enthusiast
291
Rep 287
04-08-2023, 11:32 AM | #15 | |
Rep 428
M240i x-drive (Thundernight, 19" 893Ms, Cognac, Pro Pack, Adaptive, Sunroof)
04-08-2023, 01:54 PM | #16 |
Enthusiast
291
Rep 287
04-08-2023, 02:32 PM | #17 |
Rep 1,559
04-08-2023, 05:53 PM | #18 | |
Rep 148
There are also people here who insist the car doesn't have active lower grille shutters. |
XC3LLR82062.50 |
04-08-2023, 06:05 PM | #19 | |
Rep 1,559
But you’re right, it manages heat extremely well. |
04-08-2023, 08:53 PM | #20 |
Rep 430
Drives: BMW G87 M2, F25 X3
04-08-2023, 10:43 PM | #21 |
Rep 1,559
04-10-2023, 02:37 PM | #22 | |
Rep 706
Are you sure you are not looking at water temp? The oil temp gauge on my M240 is way to crude to determine any exact measurement, it has a 45 degree temp rang between bar scale indicators, so it's a crude guess as to what it actually is. Oil temp will vary a lot depending upon how its driven and the conditions its driven in. My previous ride's H20 temp would stay rock steady at 210 degrees (after a very quick 1-2 mile warmup) no matter what. On the other hand the oil temp would vary a lot. It had a digital oil temp readout to the nearest 1 degree. My oil temps would vary according to ambient air temp, urban vs rural driving, and how hard i was driving and how much turbo demand i was using. |
