04-02-2023, 06:31 PM | #1 |
Rep 1,386
3 piece M mirrors V2
Looks like there's a newer version of the 3 piece fake mirrors..
https://www.aliexpress.com/item/1005005004460002.html They come with built in turn signals that have the exact same LED design as the real M mirrors. I currently have the full pre-preg carbon 3 piece set from AUTOID however the lacquer failed after 14 months and I never heard back from them. They claimed to offer a 3 year warranty on all TRE products (their carbon brand) however I suspect they all come from the same supplier. It looks like these guys have copied the design and built in some turn signals to the bottom piece. I also replaced my turn stock turn signal for the sweeping LED ones purely because they are around 4-5x brighter than stock. However knowing what the Chinese foled tail lights are like I'm not sure if these will be bright at all?
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
04-03-2023, 04:15 AM | #3 |
Rep 1,386
04-03-2023, 10:12 AM | #4 |
Rep 666
04-03-2023, 12:19 PM | #5 |
Rep 1,386
You've completely confused me ha, I'm not selling anything.. OEM mirrors sell on eBay for over inflated prices. Nobody seems to back down on prices because they most likely paid too much themselves too.
The ones referenced above are 3 piece replicas, if you're wanting to barter those prices you will be best speaking with the sellers on aliexpress. I haven't contacted any of them so I wouldn't know whether their prices are negotiable.
2015 435i - 401whp
04-04-2023, 08:48 PM | #6 |
Rep 1,816
Just checking eBay and see what's available. Some say "or best offer" so you can message those sellers and try and haggle. Personally I think the F8x OEM mirrors look better than these replicas. If you have blind spot monitoring you have to go with OEM.
04-05-2023, 10:23 AM | #7 |
Rep 1,839
i considered these replicas before I found out about blind spot monitoring issue. the upside of these over OEM (other than price) is that you dont have to take your door cards off. I notice used BMWs that had their door cards off always have creaks and rattles.
04-05-2023, 11:51 AM | #8 |
Rep 1,816
Yeah my car has some occasional mild creaks which may be from swapping out the ambient lighting LED modules mainly when accelerating from a stop. It's kind of annoying but it's not very loud so isn't a huge deal. My previous 430i didn't have any creaks after doing the same though.
04-05-2023, 08:33 PM | #10 | ||
Rep 1,386
It's also probably worth noting I had the prepreg carbon versions of the original 3 piece kit - the actual cover itself never snapped 100% into place, maybe you could argue the other two pieces had some miss alignment but I spent hours trying to get it right. Eventually one of my friends bought the plastic painted version and the fitment was pretty much perfect. Comparing the inside clips they do appear to be a different design on the plastic ones compared to the fully prepreg carbon ones.. so if anyone fancies them in carbon maybe choose the carbon/abs ones and not the prepreg versions.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) Last edited by fortythirtyfive; 04-06-2023 at 07:24 AM.. |
