04-08-2023, 10:22 PM | #1 |
Rep 42
K&N drop in filter causing P00BD+P0171
Sup all! New here! First post!
Back story: Picked up my 2016 F36 435i with 65k miles a month ago from BMW Mountain View and it's been amazing. All stock power wise; no intake, no exhaust, no tune. Need some insight/advice/help: - No codes with paper filter for my first 200 miles. Did a poor man's MPPK air box mod for more woosh; cut an opening next to the OEM air ram funnel and routed a dryer hose down behind the driver's side headlight, also removed the plastic plate behind the fog light grill to feed in fresh air into that section. Drove another 200 miles. I wanted MORE WOOSH, so I bought a K&N drop in filter and installed it, noticed a bit of stumbling at idle, but I was fine with it, drove about 30 miles on the highway then I popped a P00BD code. - I clear it, assuming DME needs to adjust for high flow air filter. It pops back up within 5mins of highway driving on my way back home. - I spray the MAF down with MAF cleaner and let the filter sit on a paper towel over night to soak up excess oil, the next day I disconnect the battery for 15min to let adaptations reset, slap everything together, start the car and let it idle for 15min, and boom, 15 miles on the highway I pop P0171 and P00BD. - I'm thinking maybe I just have to clear it and drive, maybe the DME is still adjusting, so I get off the highway and pull into a parking lot, clear the code, and hop back on the highway, and within 5min on the highway, CEL comes back for P0171. - I'm confused and panicking, thinking maybe something broke/cracked/etc by coincidence or when I changed the air filter; I'm thinking vacuum leak, fouled spark plugs, dying fuel pump. I pull into a gas station, clear the codes, and pop in the paper filter; the weird stumbling at idle is gone. I drive randomly on the highway for 40 miles, no codes. - The next day I decide to give the K&N another try and swap it in. AGAIN, P0171+P00BD at around the 14-15 mile mark on the highway. I pull into a gas station, clear the codes, swap in the paper filter again. - I've been driving with the paper filter for the last 150 miles now and no codes. Less woosh, but less headache/fear lol. My questions for you fine and experienced BMW/N55 owners: - Is this normal? Are the MAF parameters that strict that I can't install a "high flow air filter" without triggering a code and forcing fuel injectors to adjust? - Is something else causing the codes with the K&N drop in? - This may be a stupid question, but if it's an air flow issue with the K&N that's causing P00BD+P0171, would an axle back cause codes too since the engine would be able to exhaust gasses with less restriction? Any insight, suggestions, feedback, etc are all greatly appreciated. Last edited by junlikesf30s; 04-08-2023 at 10:27 PM.. |
04-08-2023, 11:54 PM | #2 | |
Rep 787
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
04-09-2023, 12:37 AM | #3 | |
Rep 42
What a weird issue. I assumed the MPPK or a modded lower airbox def would not be an issue, it's just an extra hole next to the funnel that's already there lol, AND ITS BEFORE THE MAF. You've personally confirmed it, so I guess I need to decide if I want to keep the K&N and revert my airbox mod OR keep the airbox mod and run paper. So, the MPPK/modded airbox+paper will run cleaner and allow more fresh/cool air to the filter, but the stock airbox+K&N sounds better and allows more air to what matters, which is the turbo. Hmmmm what to do... Thanks for your reply! Last edited by junlikesf30s; 04-09-2023 at 12:44 AM.. |
04-09-2023, 08:13 AM | #4 |
Rep 10,373
Junk the K&N. It's 1950's era filtering technology.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
04-09-2023, 09:35 AM | #5 |
Rep 787
Sounds familiar. I stuck with it though because I could get a better resale price for the Mppk airbox. K&n works fine, just not together with the airbox mod
04-09-2023, 01:44 PM | #6 |
Rep 42
I ordered the CTS intake last night after hearing a friend of a friend's F30 335i lol.
Sounds amazing in person, apparently a lot of people dont pop codes with a stock tune, something to do with how they designed the portion of the tube for the MAF. I'll just have to deal with swapping the stock tube+box in for smog. I think what's happening with the MPPK+K&N is that there's way too much air flow for the MAF to handle at it's stock location+stock DME settings. Has to do with the stock closed box panel filter design with ram air forcing too much air through the filter, which is why I was only popping codes on the highway, would also explain why the paper filter isn't popping codes since it's thick/dense. If I dropped the $1800 for the MPPK from BMW, they would install the MPPK airbox and remove fogs for more ram air, then they would tune the DME, which I assume is changing MAF parameters along with upping boost, but I'd never do that for 20-30hp, I'd rather BM3/MHD it. Not a part of my plans for the car for a while though, going to wait for my extended warranty to expire first in 40k miles/5 years. Moving to a cone design like the CTS, along with their MAF housing, i wouldn't be ramming air passed the filter, instead just filling the area around the filter with cool outside air for the intake to suck in. Which is why people with a stock tune don't complain about the CTS or Injen intakes popping MAF codes, but the Dinan does because it's a closed box, and I bet those complaining about the Dinan are running the MPPK lower airbox too lol. TLDR; closed box design + air ram + higher flowing filter = codes open intake design + air ram = ok |
04-09-2023, 03:39 PM | #7 |
Rep 16,143
04-10-2023, 11:18 AM | #8 | |
Rep 7,622
CTS is a good intake due to the MAF design as you mentioned. The issue with the Dinan is the MAF design. https://f30.bimmerpost.com/forums/sh....php?t=1765289 |
04-10-2023, 06:06 PM | #9 | |
Head Fry Cook at McBurgertown
507
Rep 1,005
thejeremyman94374.00 |
04-11-2023, 05:37 PM | #10 | |
Rep 42
So why is it that another user confirmed that K&N+MPPK caused codes, but K&N+stock lower airbox was fine? Is that just another factor in disturbance of air flow, as in the MPPK/mod is just enough of an extra opening to make the K&N pop codes? Just blows my mind how sophisticated the DME is. Also, yes! If I was just driving around town, running errands, 30-40mph, etc, the codes never popped. I was definitely ONLY popping the P00BD and/or the P0171 during highway speeds/RPMs; 70-75mph @ 1600-1800rpm in comfort or 2200-2500rpm in sport/sport+. I don't know if this plays a factor in the ram air, because as you said, I don't have the AFE scoop, I do however have a tube from the MPPK mod hole that routes behind/down the driver's side headlight and into the area behind the driver's side foglight/grill area. Are you tuned btw? I read that tunes would ultimately fix the MAF codes so the injectors don't go crazy. Thanks for the link, gonna bookmark it. Last edited by junlikesf30s; 04-11-2023 at 05:56 PM.. Reason: Reword/Provide info |
04-11-2023, 07:45 PM | #11 | |
Rep 7,622
Yes i am tuned. Also i am pretty sure the other people who reported the K&N issue were also tuned. The tune shouldnt have any impact on these MAF codes coming up or not, but someone with KN could test that if they wanted to. |
04-12-2023, 01:28 AM | #12 | |
Rep 42
04-12-2023, 12:11 PM | #13 |
Rep 787
I also run a dinan stage 2 tune with my k&n. I don't think I bothered to disable it at the time I was trying out the Mppk airbox so I can't be sure if having the tune is or isn't a factor, other than to say that the code came up when the tune was enabled.
04-12-2023, 05:13 PM | #14 |
Rep 42
Interesting. So it looks like the N55s just don't like the K&N with MPPK/extra air flow. Good to know.
04-18-2023, 09:47 AM | #15 |
Rep 93
The weakest link of the intake is turbo inlet, mppk intake is good even with bigger turbo. But that’s interesting that aftermarket filter doesn’t work well with mppk intake, I always kept stock filter. Even with pure500 turbo, mpe exhaust is must imo for a n55.
04-18-2023, 06:56 PM | #16 | |
507
Rep 1,005
MPPK + AFE Pro Dry + MST V2 inlet - would this work with a Pure 500 without throwing codes while still keeping WGDC low, as opposed to a CTS intake? Tune would be OTS MHD stage 2 or the new 2+ (whenever the HPFP arrives). I prefer the underhood look of the OEM package, but I don't drive around with the hood open - I'd rather have the max performance benefit. My Spidey sense tells me the CTS has the capability to flow more air, but that's only anecdotal observation - I've never done a physical measurement/side-by-side comparison. |
04-18-2023, 07:26 PM | #17 | |
Rep 4,174
You could use an air straightener or a velocity stack in the box - but you shouldn’t need that on a stock airbox. Last edited by AmuroRay; 04-18-2023 at 07:46 PM.. |
04-18-2023, 07:45 PM | #18 | |
Rep 4,174
04-18-2023, 07:58 PM | #19 | |
Rep 7,622
04-19-2023, 11:31 AM | #20 |
Rep 42
Little update:
Received and installed the CTS intake. For $265 shipped to my door, it's a good purchase. I agree with you thejeremyman9 , the sound is a little obnoxious at times. For the stock 7-10psi tune, the turbo howls and the diverter valve hisses pretty hard. The car sounds like a Japanese tuner car now lol. I'll run it for now, but I'm considering going back to the modded stock box/mppk with the AFE drop in. Maybe the Valvetronic axle back would balance sounds coming from the front and rear of the car? Put 100 miles on the car since I installed the CTS intake, and so far so good, no CEL. |
04-19-2023, 12:10 PM | #21 | |
Rep 7,622
04-19-2023, 12:57 PM | #22 | |
507
Rep 1,005
