04-10-2023, 09:06 AM | #1 |
Rep 38
Car hard to start after refueling
Anyone have an idea why my F30 N55 is hard to start after refueling? It seems to be whenever I remove the gas cap. I thought it was my JB4 messing with something but I removed it and it’s still doing it. It won’t turn over at all the first try, second try it turns over but immediately dies and third time it turns over, runs extremely rough, sounds like it’s going to die and then starts to run normal
04-10-2023, 12:20 PM | #3 |
Rep 383
I mean, I don't have a specific cause, but it sounds like gas is evacuating the fuel rail/lines somehow.
Bad check valve somewhere is the system, or leaking fuel injector maybe? Coupled with releasing the pressure in the tank when you open the fuel cap? Can you recreate it by opening the fuel cap, or is it only after adding fuel? |
04-11-2023, 03:38 PM | #5 |
Rep 666
Many things can cause issues of this semblance, and I don't wish for your car to have some codes. But without codes, it's kind of hard to hone in on where to start looking.
From personal experience, below is a list of things that I've had similar issues from the past: 1. Battery going out or a battery change without registry 2. VANOs solenoids 3. ECC shaft sensor plug invaded with oil 4. Grounding cable come loose or corroded from motor to chassis 5. Oil pressure or oil level being low; this affects how VANOs can control advance timing, at times the oil filter's small little seal ring can cause such issues if sealing is bad. There are many other causes to have similar issue without an engine code, but the above 5 I've dealt with while there weren't any codes being seen.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
