BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      04-10-2023, 11:06 AM   #1
zero21
Drives: G87 sold
Lowering Kits: Springs, HAS, etc.
Reviewing photos - this model needs to be lowered - I think we can all agree. I am now looking at kits to drop 10-15mm rear, and 15-20mm front.
What products are you all looking at? What are there drop ranges and handling/riding characteristics?
      04-10-2023, 11:27 AM   #2
Ghostrider.1127
Ghostrider
Ghostrider.1127's Avatar
195
Drives: M140iX,Z4M40i,M8 comp,M2g87
https://www.kwsuspensions.de/shop?c_...tellbarefedern
https://docs.kwsuspension.de/ea-KWHFS-h688200EB.pdf
      04-10-2023, 01:02 PM   #3
M_Power Rob
Drives: '23 M240 and '23 M2
I spoke to a friend of mine that owns a performance shop and knows and has close relationships with all at H&R. I was told for now, do not use the part numbers for springs for G80/82 M3/M4. Their R&D is/will be working to determine the tolerances/rates and if a separate part number for the G87 M2 will be required. If they determine the tolerance is close enough then the part will be the same. No determination has been made yet as of this time.
zero213277.00
Game8158.00
Tag20162.50
      04-10-2023, 04:27 PM   #4
zero21
Drives: G87 sold
Honestly does not surprise me at all considering the car's chassis has been set up completely different, and has different loads on the four wheels.
Why anyone would try to kid us into thinking the normal M Performance HAS is 100% fine is beyond me. I guess I would swallow it not problem if data was provided, but with my scale weights it shows differentials of up to 200lbs in a corner from the G82. That does not fall within acceptable tolerance for a car that was designed to feel different.
Also why I am waiting on an engineered solution for this car. We already know it's easy to drop it and plug in parts from other vehicles, that doesn't mean they'll perform the way we want
      04-11-2023, 12:30 AM   #5
Vtor465
Drives: G80 Comp Xdrive
I guess I would be your guinea pig lol. My dealer will install mphas before I pick up the car. Ill post pics here and keep you guys posted!
sl0m01304.50
Game8158.00
JustinHEMI7504.00
zero213277.00
Tag20162.50
ourlee1611.50
Bumpinjeep6303.50
ronin130131082.00
      04-11-2023, 12:33 AM   #6
sl0m0
Drives: Sedan
Thank you!! How low do you plan to go? Planning for spacers too?
Vtor46545.00
zero213277.00
      04-11-2023, 12:38 AM   #7
Vtor465
For sure!
Im thinking 20mm front and 10-15mm rear.
Spacers 15mm front
And 12mm rear
sl0m01304.50
zero213277.00
Tag20162.50
ourlee1611.50
      04-11-2023, 12:40 AM   #8
sl0m0
Drives: Sedan
For sure!
Spacers 15mm front
And 12mm rear
Definitely excited to see this! I'm nervous about going to low or too wide and spending unnecessary $ going back and forth. Hoping to dial it in on the first try.
      04-11-2023, 12:42 AM   #9
Game
Game's Avatar
8158
Drives: G80 LCI, G87 (sold)
For sure!
Spacers 15mm front
And 12mm rear
Definitely start your own thread when you get it installed!
      04-11-2023, 12:48 AM   #10
JustinHEMI
Not great. Not terrible
JustinHEMI's Avatar
7504
Drives: 2024 BMW X3 M40i
Looking forward to results! This is definitely a potential for me AFTER I see how the car settles, and see if anything specific to G87 is developed. I had the MP kit on my F87 and I liked it very much.
Current: 2024 BMW X3 M40i.
      04-11-2023, 12:49 AM   #11
Vtor465
Ill def keep you guys posted. I know it's gonna be a hit or miss so I only bought the spacers from Amazon just to test fit see how it sits and looks, in case i need to return and just get a decent set like macht or fc.
      04-11-2023, 12:50 AM   #12
Vtor465
Will do!
      04-11-2023, 12:59 AM   #13
sl0m0
Drives: Sedan
I'm trying to skip spacers and get wheels with the right offset to save a little bit of weight, so you guys with spacers will definitely be the guinea pigs. I've got about 2 weeks B4 I need to put in my order and decide though. I think I'm gonna be cautious with the offset since I will be able to fine tune with HAS.
Vtor46545.00
      04-11-2023, 03:04 PM   #14
Tag
this is the way
Tag's Avatar
20163
Drives: N-1 starfighter
I've been trying to find out if the M Perf HAS requires any coding after the install since the G87 has different spring rates than the G80/2. Can you please find out if that's required when the dealer does your install?
      04-28-2023, 05:35 PM   #15
Vtor465
Took couple of pics. Will upload more and snap quality photos.
Mperf HAS
12mm spacers front
15mm spacers rear
Bumpinjeep6303.50
Game8158.00
JustinHEMI7504.00
jay1k282.50
sl0m01304.50
AZG871163.50
      04-28-2023, 07:07 PM   #16
zero21
Drives: G87 sold
Looks like they did a square drop. Do you know how low they went?
How's the ride pre and post install?
      04-28-2023, 07:30 PM   #17
Vtor465
Tech said it's in the lowest settings F&R.
Ride is identical pre and post install. Love it!
zero213277.00
cmgbk752671.50
      04-29-2023, 02:35 AM   #18
boostspoon
Drives: M2
Mperf HAS
12mm spacers front
15mm spacers rear
Thanks for pics. Can you take them without the funky fisheye lens? Just a good side shot would work.
zero213277.00
      04-30-2023, 07:19 PM   #19
sl0m0
Drives: Sedan
Mperf HAS
12mm spacers front
15mm spacers rear
That is an improvement, what is the HAS set at?
      04-30-2023, 08:35 PM   #20
ourlee
ourlee's Avatar
1612
Drives: WTB your comfort seats
Let’s quote the pictures more thx. (Car looks great)
      05-08-2023, 10:31 PM   #21
M_Tune
Drives: Red Bull RB19
The car looks good but it’s hard to see the stance without a side profile picture.
      05-12-2023, 12:33 PM   #22
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
It's crucial to establish your objectives before embarking on any car upgrades. Are you primarily aiming for visual enhancements, or are these upgrades intended to improve track performance?
By determining your goals at the outset, you can make more informed decisions on which kit if best for you.
https://x-ph.com/sale/
Phone number 702-494-9435
