04-11-2023, 08:46 AM | #1 |
Rep 188
Pulsing idle noticed this morning
I haven't had time to do any proper pulls or logging, but wanted to fish around for some opinions here to put my mind around it.
I had an errand to run on my way into work this morning and when I started my car up and sat for a bit to send an email, I couldn't to help but notice an new pattern to my engine's idle I hadn't noticed. Before I stopped to run the errand, my engine had come fully to temp and drove fine, as usual. When finished with the errand, I sat in the car for a bit, engine off with radio and accessories on (maybe a half hour) and was alerted to the battery having discharged. I started it up as I did need to get to work, it was a bit slow to do so. The engine had cooled of a bit as it was in the low-40s, but that's when I noticed the idle pattern. Here's a short log at idle before I pulled off: https://datazap.me/u/mcsweeto/pulsin...22-23-24-25-26 The RPMs were noticeably pulsing. It stuttered a bit and felt a little underpowered pulling of. Maybe this had something to do with the battery drain, but here I am.
2015 M-Sport 435i xDrive (6MT)
MHD Stage 2+ / VRSF Catted DP / ARM F3X IC / BMS CP / AFE Pro Dry S |
04-11-2023, 11:26 AM | #2 |
BMW CCA Member
490
Rep 808
Or maybe it's time for an intake walnut blast?
I was asking about this with a local indy shop. The F3X series doesn't have idle issues like the E9X did, but they did mention that some F3X come in with intakes coated in dirt at like 50k miles and some still clean at 100k+ miles. (As an aside when I had my Miata supercharged, I noticed a TON of dust in the intake tract when I ran a K&N oiled filter.) Either way, with direct injection cars, dust and dirt accumulate in the intake track which may affect idle. |
04-11-2023, 06:44 PM | #3 | |
Rep 188
I'm starting to think the battery drain was contributing somehow. After it came to temp again it felt fine, as it did later in the day on the drive home.
exE36M3489.50 |
04-12-2023, 10:49 AM | #4 |
Rep 2,376
Mine start doing what sound similar consistently after ~10 cold starts after a re-flash. Rough idle in open-loop as the cat pre-heating cycle is supposed to take place. However, car is not doing any pre-heating as I have the "I like to speak to my neighbours again" option enabled.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
04-12-2023, 10:51 AM | #5 |
Rep 2,376
Tried to explain the problem to both MHD and Fabian several times, but I guess they have more important stuff to do
(A Dane in China) |
04-12-2023, 11:01 AM | #6 |
Rep 2,376
My bad - should have checked the log first Def not the same problem. -8.6psi at idle......WHAT?? Try throw a new MAP sensor at it.
(A Dane in China) |
04-12-2023, 08:22 PM | #7 | |
Rep 188
Yeah, that -8.6psi is what motivated to me to post after seeing the log. The fuel trim, RPMs, timing all seemed to be funky. I need to log again but I suspect that was some kind of anomaly.
