04-12-2023, 11:17 AM | #1 |
Rep 3,127
NEW PRODUCT RELEASE: Dinan G87 M2 Carbon Fiber Intakes
Featured on BIMMERPOST.com Dinan G8x M2/M3/M4 Carbon Fiber Intakes Part Number(s):
Release Date: Available Now! Description: With the most potent BMW inline-6 to date, the S58, the newest iteration of the M3 has set itself apart from its predecessors; given the option for AWD, a model first, the M3 breaks boundaries long maintained by the quintessential brand icon. Being the signature chassis Dinan modifies, development on the G8x needed to similarly raise the bar and distinguish itself from the pack; a difficult task but one we relished the opportunity to embark upon. After months of comprehensive design and validation, that journey has come to its conclusion for the first of those ambitious aspirations - the Dinan G8x Carbon Fiber Cold Air Intake. Equal parts function, sound, and beauty, the intake not only looks and sounds the part of something special but performs the part as well. With a 12% increase in airflow to the engine without any negative effects on inlet temperatures or pressure, the Dinan G8x system delivers on all fronts. Drawing in more unimpeded air for consumption yields more efficient turbos (less work to make the same power) with the capacity for greater power potential on modified builds. Central to the design and our obsessive-compulsive need for a symmetrical engine bay is a singular plenum that replaces the separated driver and passenger intake ducting on the stock setup. The combination of the two tracks into one enlarged and distinctive shared pathway allows 50% more volume to be achieved in this tight space in addition to simplifying the installation and improving the overall look. The center plenum gives way to enlarged airboxes that house 11% larger cotton air filters delivering superb filtration while maximizing flow. Feeding the filters are the factory grill inlets as well as additional cutouts on the top of each airbox lid. The semi-open design was analyzed extensively to ensure that these additional inlets had no ill effect on temperatures or flow. However, the secondary airbox passages do allow an avenue for the induction soundtrack to escape the confines of its former plastic prison for everyone's benefit. Whether under hard acceleration, deceleration, or just spooling the amplified sounds are sure to make an impression. Beyond improvements to flow and sound, the appearance of the Dinan G8x M2/M3/M4 intake system is unrivaled. One need not do more than take a casual glance to know that care was taken with the system to blend in naturally with the factory engine bay while sufficiently augmenting it to a tier above. Playing off the hard angular edges that are present throughout, the Dinan intake system carefully takes these queues and carries them throughout for a true OEM+ look and feel. A 2x2 twill carbon fiber weave is used throughout and available in either gloss or matte - a first for Dinan, further setting the intake apart from those that came before. Features/Benefits:
13
Tag18135.50 Orange fever2351.00 M3 boi3211.00 JA-0628.00 6speed_M23633.50 T0RM3NT3621.00 chrisk03153.00 AlpineBoost3926.00 Game7397.00 JDK47.50 Seattlesquash894.50 T3CH46.50 ronin13013999.00 |
04-12-2023, 11:19 AM | #2 |
Rep 3,127
Blatant grab of early real estate in this sub-category. Never had this opportunity before so I am taking advantage of it. =)
18
sl0m01296.00 Kevin_The_Clean13241.50 Rx-7ames1892.50 M3 boi3211.00 curtdragon471.50 skiparock182.50 6speed_M23633.50 T0RM3NT3621.00 AlpineBoost3926.00 Zirenz20061534.50 ellipsis2121617.50 M Division1196.00 JTO245274.50 pobrienny51.00 WagonMaverick372.00 Chet for short203.50 pyrorupt3.00 DivergedM2580.00 |
04-12-2023, 12:18 PM | #4 | |
Rep 2,948
Are you building a car to track (road race)? If not, why the obsession with front to rear weight percentages. If you are looking to make the car faster on the street, shedding weight in general will make the car faster. Lowering it, within limits (read, not slamming it) will help make it handle and drive better. |
04-12-2023, 12:26 PM | #5 | |
Rep 1,836
The reason I asked is because no one has published the weight of their system to date for all G8x cars. In order to not make a problem worse, you have to put the down the shovel. I'm not pretending like this makes a huge difference, I just want to know. |
04-12-2023, 12:34 PM | #6 | |
Rep 2,948
Maximizing the platform for track (road race) setup isn't always maximizing the platform on the street. You make your car lighter and trying to keep the front to rear distribution "perfect" as you see it and I will shed overall weight (power kept equal on both), and I bet I will gap you on the street. |
04-12-2023, 12:57 PM | #7 |
Rep 3,127
That would be a first for that question. Its never been weighed to my knowledge (stock or the Dinan) as I would assume any difference would be negligible but I'll put in a request in with the shop to weigh the systems once they switch our car back to stock.
04-12-2023, 01:07 PM | #8 | |
Rep 1,836
04-12-2023, 01:09 PM | #9 | |
Rep 1,836
04-12-2023, 01:18 PM | #10 |
Rep 2,948
You really dont understand what I am saying? The weight balance you are being so concerned with will have little effect on maximizing the performance on the street. That is truly beneficial for those tracking or road racing (on track). Overall weight shedding, whether from front or back, will be of most benefit for driving on the street (maximizing ovwrall power to weight). Oh, and in case you weren't aware (not sure but stating this based on guessing you didnt know, if you did, my apologies)...gapping means watching my taillights. Can you over do it either way, of course but that would be in an extreme meaaure. |
04-12-2023, 01:34 PM | #11 | |
Rep 148
I'm waiting to see if anyone goes all in and fits carbon fiber wheels and brake discs to shed 50 pounds of unsprung rotating mass. The $25k - $30k cost probably doesn't make sense on the M2, but it would really be interesting to see. |
04-12-2023, 08:09 PM | #12 | |
Rep 1,836
04-12-2023, 11:55 PM | #13 | |
Rep 166
Drives: '21 EB 240, G87 M2 (preodered)
2021 EB M240 6MT: TC Kline Camber Plates & Coilovers, Eventuri CAI, AA Catted DP, Remus Non-Res Catback, FTP CP; M Front Lip, Rockers, Mirrors, Spoiler, Interior
ourlee913.00 AlpineBoost3926.00 |
04-13-2023, 09:09 AM | #14 |
Rep 3,127
9
LCDRJohn607.50 zero213252.00 sl0m01296.00 M3 boi3211.00 Bumpinjeep5507.00 Tag18135.50 AlpineBoost3926.00 JTO245274.50 Seattlesquash894.50 |
04-13-2023, 09:38 AM | #15 | |
Rep 2,948
Curious, what type of filer do you use? When I got the cf intake on my B9 S5 from AWE, they had just come out with the product and it came with the oiled filter and it was a mess (they have since replaced with the dry filter). Also, will you be coming out with an upgraded heat exchanger? Last edited by M_Power Rob; 04-13-2023 at 09:51 AM.. |
04-13-2023, 09:50 AM | #16 |
Rep 753
I can't wait to see what kind of tuning you will come out with, and how much HP we can get back after BMW "detuned" the S58.
04-13-2023, 10:27 AM | #17 |
Rep 1,836
04-13-2023, 10:53 AM | #18 | |
Rep 3,127
That said, oiled filters should have only a very light coating of oil on them that should not be messy at all. Should barely be perceptible to the touch. Sounds like you just may have gotten a filter that was waaaaaay over oiled for the Audi that slipped through the cracks from the vendor. And yes, heat exhanger is one of the many projects for the platform. Waiting til we finish break-in to really put it through its paces and get proper audio at load but thus far in "regular" driving it sounds identical to my ears. |
zero213252.00 AlpineBoost3926.00 |
04-13-2023, 11:13 AM | #19 | |
Rep 2,948
Thanks for the response. I assume you will be posting updates as new parts become available. |
04-13-2023, 07:12 PM | #20 |
Rep 843
I like turtles
ellipsis2121617.50 |
04-17-2023, 07:42 AM | #22 |
Rep 3,151
Wow those look gorgeous. I’d take these any day over the eventuri
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
