E91 bt retrofit thru cd changer
04-14-2023, 04:14 PM | #1 |
Rep 1
Hi guys.
I know this topic properly have been discused a million times. But I cant seem to find an answer to this problem. So the Thing is, have telefon bt, but not streaming music ofc. So i have installed and bt receiver with optic in and out, connected the 2 green most cables from the cd changer. I am a little unsure about wether the cd changer must be pluged in with power or not. But either way, i am only getting the message on the ccc unit when choosing cd, that there Arent any readable cds in the changer, tho the most cables should be playing music. So do i have to fill up the cd changer and let it be there, and just use the most cables in the bt unit? Or could there be something els wrong? |
04-15-2023, 12:43 PM | #2 |
Rep 13,128
For stuff like you describe typically the Dension or Mr12Volt.
You only need to enable the cd option in the Head Unit. The device then use the CD interface on the Head Unit to control the device. There are many threads on this in the stereo sub forum. I have the simple mr 12volt interface . I used NCS expert to enable the CD interface on the Pro Radio. http://www.e90post.com/forums/showth...hlight=dension https://www.e90post.com/forums/showt...ight=bluetooth If the cd changer came with the car it's already enabled . remove the cd changer and put your device in instead. No Cd changer required to install or run. Last edited by ctuna; 04-15-2023 at 12:51 PM.. |
