04-17-2023, 05:36 PM | #1 |
Rep 4
I just got 2014 335i, what first mods should i do to make it reliable?
Everyone was saying the n55 was way more reliable then n54. So i went ahead and bought a 2014 335i at 17. How could i make it more reliable?
04-17-2023, 06:34 PM | #3 |
Head Fry Cook at McBurgertown
507
Rep 1,005
04-17-2023, 06:59 PM | #4 |
Car Hypochondriac
335
Rep 903
Drives: 2014 335i M-Sport Estoril Blue
Mickey mouse coolant flange, coolant overflow line, check your valve cover gasket and the oil filter housing gasket.
04-17-2023, 09:42 PM | #5 |
Rep 666
Front main seal, oil pan gasket, then rear main seal are all prone to leak, too; aside from what everyone has mentioned before me.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
04-17-2023, 10:47 PM | #6 |
Rep 93
#1 change oil on time no more than 5k miles
#2 fix any oil leaks, valve cover, oil filter housing gasket (critical one), make sure shop or you prime engine. #3 only buy oem parts, fcpeuro is good place to buy parts. |
04-18-2023, 10:11 AM | #11 |
Rep 93
You need to get a BimmerLink app and obd2 adapter to read the codes. It could be anything, from coil packs/spark plugs to some sensors. How many miles on this car?
juliansanchez0.00 |
04-18-2023, 12:13 PM | #12 |
Rep 7,622
If you are going to be taking the car to a shop every time you have an issue, owning and maintaining a BMW is probably going to become expensive very quickly.
juliansanchez0.00 |
04-18-2023, 01:33 PM | #13 | |
Rep 290
Drives: E46 M3 & LCI X3 35i M Sport
You have the money to pay for expensive maintenance or you learn how to troubleshoot & DIY. |
juliansanchez0.00 |
04-18-2023, 06:13 PM | #14 |
Rep 4
Thank you all for the help! I know how to do maintenance, with the help of a little youtube lol. But don’t know how to find the code, is the BimmerLink app and obd2 adapter the best?
04-20-2023, 07:42 AM | #15 |
Rep 37
not the best but they are good, if u plan on tuning get mhd with the bluetooth obd adapter
juliansanchez0.00 |
04-20-2023, 10:29 AM | #16 |
Rep 7,622
juliansanchez0.00 |
04-20-2023, 12:11 PM | #17 |
Rep 4,174
04-21-2023, 09:17 AM | #18 |
Rep 248
Drives: 1989 325i & 2014 335i
Hey OP, congrats on the car.
As others have said, start with basic maintenance. Oil change, air filter change, fix oil leaks as they occur, replace the mickey mouse flange when you can, replace drive belt as needed. Also as said before, ownership is going to be VERY expensive if you take your car to the shop for every problem. Download and pay for BimmerLink, it is a code scanning app specifically for BMWs. https://www.bimmerlink.app/ You're also going to need a bluetooth adapter to connect your phone to the car. I got the Veepeak OBDCheck BLE+ Bluetooth from Amazon. It works great. At some point you may want to also buy BimmerCode, which allows you to change a ton of features about the car so that it functions the way you want. https://bimmercode.app/ Start with pulling the fault codes, then read about them to know what they mean, then try fixing it yourself. A drivetrain malfunction could be a massive problem, or something as simple as needed new ignition coils and spark plugs. |
juliansanchez0.00 |
