rough idle
04-17-2023, 07:24 PM | #1 |
Rep 9
rough idle
I have an 07 328i, I was having MAF codes but I replaced the MAF and there was a vacuum leak from a bad valve cover gasket, so I replaced the gasket. CEL turned off after driving it a bit. But still having rough idle just not as bad as before. Also it seems like it wants to stall out and turn off on deceleration. Any advice on what to look for or fixes or even personal experience would be appreciated.
04-18-2023, 08:03 PM | #2 |
Yoda of mods
1678
Rep 3,008
Drives: X5 RWD
Might want to try new spark plugs.
Current: 2020 Explorer ST (Agate Black Metallic) AWD, F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
04-18-2023, 08:09 PM | #3 |
Rep 1,682
Maybe the PCV valve diaphragm is bad. Is there is whistling sound under the hood? The plastic valve cover can crack too, leaking oil down onto the exhaust on the passenger side.
The 3-way PCV plastic pipe may have cracked. Usually that's replaced together with the valve cover. Rough idle could also be the coils or the eccentric shaft sensor. Is there oil in the sensor connector? https://www.e90post.com/forums/showthread.php?t=1988219 |
Paxandrax0.00 |
04-19-2023, 10:38 AM | #4 | |
e91Owner
425
Rep 1,129
