2007 e92 335i no crank
04-18-2023, 02:15 PM | #1 |
Rep 4
So I bought a 07 335i about a month ago and the radiator fan went out. I replaced the fan and let the car get up to temp idiling until the fan turned on. Once the fan turned on I shut the car off and went to turn it back on. When I hit the start button it wouldn’t turn over. Everything else works just the starter won’t engage. I pulled the starter and checked it and it still works.
I have codes 2A17: DME: DMTL, system fault 2E7C: BSD bus Communictaon Fault 2E84: BSD, message; electric coolant pump: missing 2E84: BSD, message; intelligent battery sensor (IBS): missing I’ve tried the simple like unplugging the coolant pump and etc to see if those were the reason for code and that didn’t work. Battery is charged and tested and good. Like I said the starter is good. Only possible thing I can think is DME went, any ideas? |
04-18-2023, 03:40 PM | #2 | |
Rep 4,103
The DME has NOTHING to do with Activation of Starter Solenoid. The CAS Module, specifically Terminal 50 (KL50) sends a voltage signal to the Starter Solenoid to Crank the Starter. CAS will ONLY activate KL50 and crank starter IF: 1) P/N switch signal received by CAS indicates either Park/Neutral Gear (AT); 2) Brake Light Switch Signal received by CAS; 3) Clutch Depressed signal from Clutch Switch (MT) received by CAS; Those "Safety Switch" signals can be read as Live Data if you have a Scan Tool that can connect to CAS Module, or if you have INPA/ISTA Diagnostic Software. If you don't have either, you can at least do these Tests: 1) Insert Remote Key in Insert Compartment: does Radio play? Do Brake Lights light when brake pedal is pressed? You could still have bad wiring between Brake Light Switch and CAS, but at least you can see if Switch works. 2) If AT, insert Remote Key in Insert Compartment, turn on Ignition by pressing START button WITHOUT pressing brake and see if instrument cluster lights and Climate Control Panel lights. If BOTH light up, then CAS is activating KL15 and KL30G relays as it should. 3) Check to see what Gear Selection is displayed in lower display of Instrument Cluster. It SHOULD be "P" if Shift Lever is in Park Position. Now press Brake and move Shift Lever to R, N & D Positions. Is EACH gear selected displayed on Lower Instrument Cluster Display? INPA or ISTA would quickly display presence or absence of those inputs to the CAS Module, and ALSO status of each CAS Terminal. However there is ONE MORE test you can do to test Starter Activation, AND to test for KL50 signal from CAS, WITHOUT INPA/ISTA BMW Factory-Level/ Dealer-Level Diagnostic Software. Please try those tests noting each result and post those results here. George |
04-18-2023, 03:44 PM | #3 | |
Rep 4
04-18-2023, 04:19 PM | #4 | ||
Rep 4,103
George |
Orien0.00 |
04-18-2023, 05:53 PM | #5 | |
Rep 4
