04-19-2023, 09:53 PM | #1 |
Rep 823
Tire pressure for 4S?
What the best cold pressure and what is optimal pressure when warm(aggressive street) for Michelin Pilot Sport 4S?
Garage; 2020 Raptor, 2011 1M, 2017 M2 PE, 2006 Z4 MC, 2007 Z4 MC, 2001 Spec E46, 2007 GT3
04-19-2023, 11:13 PM | #2 |
Rep 373
I've always considered 35psi cold to be the standard. or if you wanna be exact, look at the door jamb and follow those guidelines. I have a tire inflator at home so I usually just run that when my tires are cold to 35psi. if you're stopping at a gas station in the middle of a road trip, then I can see it getting tricky. if you go to the tire pressures on your screen, it will tell you the recommended warm tire pressure as well.
jhall19571107.00 |
08-18-2023, 11:53 PM | #4 |
Rep 107
Contrary to the old days when manufacturers recommended low tire pressures (30-32psi) for a soft ride, now they want higher pressures for better fuel economy.
I've always used 36psi cold, but I also find that common dial type gauges can be 1-2 lbs off. So unless you are using a really good gauge, you don't really know what you are setting. |
