04-20-2023, 01:26 PM | #1 |
Rep 278
Drives: 13 f30 335i Msport
Bosch EU5 Injectors
How's it going guys, so I'm having an issue and wanted to see if anyone else has run into this. I am in the process of replacing my injectors. I have used ista to confirm that I do have EU5 injectors currently on the car and have ordered the Bosch EU5 injector but I notice that on the injectors that came in, there is no three-digit code for the flow adjustment/coding process.
I have confirmed by the part # on the box and on the injector itself that these are indeed EU5's. Additionally, I have reached out to the company I bought the injectors from with my VIN and the part number on the box and they have confirmed they are EU5 as well and they should fit my car. Let me know what you all think. Images of new injector:
13 f30 335i < 08 e92 335i < 04 Subaru WRX
04-20-2023, 09:11 PM | #3 | |
Rep 383
Are you just replacing a single injector, or all? Are they all like this? Maybe just return them if you can and buy from FCP Euro or other well known source. |
04-21-2023, 12:58 PM | #4 |
Rep 278
I got them from this vendor https://eeuroparts.com/ seems like a rock auto type place.
04-22-2023, 02:36 PM | #6 |
Head Fry Cook at McBurgertown
507
Rep 1,005
I've bought from eeuroparts several times.
Never had an issue. I would also agree; seems like a "Rock Auto-type" place that specializes in European models. |
04-23-2023, 03:29 PM | #7 | |
Rep 107
04-23-2023, 11:22 PM | #9 |
Rep 145
You're right, confirmed in ISTA as I had recently swapped all my eu5 injectors out.
Nope, you're wrong. It is the 3 digits circled and coincidentally, all my new one is the same as OPs, all 939 |
04-24-2023, 05:43 AM | #10 | |
Rep 383
Please confirm your source and post it. Even EU6 injectors should have this compensation number printed, if pictures on FCP’s website are correct. Something isn’t right with the parts OP has where nothing is printed. Last edited by SuperLomi; 04-24-2023 at 06:57 AM.. |
04-24-2023, 09:01 AM | #11 | |
Car Hypochondriac
335
Rep 903
Drives: 2014 335i M-Sport Estoril Blue
@4:16 if timestamp doesn't work |
04-24-2023, 09:41 AM | #12 |
Rep 383
I think the problem here is your confusing a circle in the documentation highlighting the number to be the circle on the part. It's not even the same shape as the print on the part.
In that video 282 as a compensation value is an expected number. 939 is not, and it wont be the same for every injector. This video is also for an E chassis, and here’s the TIS image for that car, pointing to the same location. Not a circled number. I have to stress again when I did this I first confirmed the numbers programmed into the car matched the numbers on the injectors I removed, and they corresponded to the value I am indicating. I get the confusion, but the 939 number is not the correct number. Last edited by SuperLomi; 04-24-2023 at 09:58 AM.. |
04-24-2023, 09:58 AM | #13 |
Car Hypochondriac
335
Rep 903
Is it worth pointing out that the pic you have there is showing the opposite side of the injector? Juiced, what's printed on the other side of yours?
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
04-24-2023, 09:59 AM | #14 | |
Rep 383
Here's the full image from the E-chassis TIS for your reference. Last edited by SuperLomi; 04-24-2023 at 10:06 AM.. |
04-24-2023, 11:29 AM | #15 |
Rep 278
Hey, guys so there is nothing on the back of the injector regarding the flow adjustment code. Here are some pics of the front and back of my injector. I posted a third picture of the box and wanted to see if anyone had a eu5 injector on hand. Could you confirm if the number I highlighted on the box matches the flow adjustment number on your injector? bc the 939 that is circled is also on the box. Sorry for the large pictures but figured large is better than blurry.
04-24-2023, 11:54 AM | #16 |
Car Hypochondriac
335
Rep 903
Ok, yeah that's very strange. Does your box have an authenticity label/sticker? You can check if the part is genuine here: https://protect.bosch.com/
Time to reach out to eeuroparts regardless. That 3 digit code highlighted on the box is probably it? But weird that it wouldn't be on the injector itself.
04-24-2023, 12:05 PM | #17 |
Rep 278
Eschmacher Yeah, it does have the authenticity label I did check that as well and it said it was genuine.
I did contact bosch as well, just got off the phone and they said that it was strange that the number wasn't on there either. Odds are I am going to return them. Sucks if eeuroparts is not legit they were a good source, or at least I thought they were.
04-24-2023, 12:11 PM | #18 |
Rep 383
I don’t think that’s it.
Here is my box. Date code on my injectors is Aug 2021, vs yours in June 2022, so maybe label changed between then and now, but that number does not correspond to the compensation value. If I had to guess the 939 may indicate manufacturing location. My Original injectors made in Germany have 060 code circled. |
04-24-2023, 12:19 PM | #19 |
Rep 278
Hey, I also wanted to include a copy of the PDF form bosch of Authorized resellers/retailers of bosch products.
04-25-2023, 04:58 AM | #20 | |
Rep 145
939 is the correct number according to this. The one circled is right https://ibb.co/zVkdLCG Source: So if you have a more updated ISTA image than I have for the F chassis, then let me know, but that one is dated a week or so ago and has the circled number labeled as number 2 in the chart where it corresponds to the compensation number. Now, it brings us to an issue where, did ISTA change instructions? Did Bosch alter something? What number is the correct number? Last edited by kickthecan; 04-25-2023 at 05:55 AM.. |
04-25-2023, 06:05 AM | #21 | |
Rep 383
This is an even clearer image. It's very clear the circle is from the documentation highlighting the number. Come on people let's use some critical thinking skills: The circle isn't the same shape as what's on on the part. The circle is comprised of white and black lines, which match the "tail" leading to the "2". THE FULL IMAGE OF THE PART SHOWS THERE IS NO CIRCLE. This shouldn't be that hard. Last edited by SuperLomi; 04-25-2023 at 06:14 AM.. |
