04-21-2023, 11:29 AM | #1 |
Rep 1,384
6th gear hesitation
Noticed I'm having some hesitation / almost holding back and jerking between 5th-6th sometimes, generally though it's 6th gear.
I presumed I had some bad torque settings on xHP as you can set it to shift faster or reduce turbo lag. Set these back to 0 and reflashed, I also tried the adaptation thing where you turn the car on, pedal to the floor for 5 seconds and then shut the car down. I still get it though. It's not always there, probably happens 1 in every 5 times but it's super jarring and a little worrying. Cold starts are also pretty terrible, car feels like it's kangaroo'ing through 1st to 3rd at super low rpms, that disappears after a minute of driving though. Any ideas what could be causing it? Excessive trans or clutch wear? FTR I'm a 8AT running MHD Stage 2+ with the 3/6 power fix enabled. I also did a gearbox oil change around 8k miles ago.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
04-21-2023, 02:46 PM | #2 | |
Noob
70
Rep 255
FBO, MHD Stage 2+ E20, Xhp Stage 3
04-22-2023, 06:30 AM | #3 |
Rep 1,384
04-22-2023, 12:43 PM | #4 | |
Rep 7,622
You can check your adaptation values in XHP and see if they seem out of the ordinary. 6th gear is the weakest one. Also are you 100% sure the trans fluid is filled correctly per procedures? |
04-22-2023, 06:45 PM | #5 | |
Rep 1,384
Today I got back under the trans and tried filling it with more fluid but it wouldn't take anymore without gushing the old stuff out. This was after getting it up to temp, I also tried shifting through drive modes. I took liberty of flushing out any "sort of" old fluid with new and was surprised to see there's still a lot of metallic shimmer in the fluid that came out. This was something I noticed the magnets had collected a lot of when I did the original fluid change last year. 2 different garages who offer the ZF fluid changes said this was nothing to be worried about when I checked (last year) but it still seems a little excessive. What I did do though was reflash an older xHP version, one prior to them adding the M hard shifts where it gives you a kick when upshifting.. I had zero lag. I tried it on several occasions and it was back to being normal, so I flashed back to the latest version (3.8) and boom, I had one instance of lag between the gears. Maybe it was bad luck and just didn't "happen" whilst on the older version, just seems a little odd to me, the kick feature is cool but if it's actually causing these inconsistencies then I'll stick with the older versions.
2015 435i - 401whp
04-23-2023, 01:54 PM | #6 | |
Rep 7,622
What stage XHP tune are you running? I went down from stage 3 to stage 2 a while back when the whole discussion around Pure Drivetrain's post came up. Stage 2 honestly feels good, but the maps are updated far less frequently. Which i guess in this case maybe isnt a bad thing. |
fortythirtyfive644.00 |
04-23-2023, 03:07 PM | #7 | |
Rep 1,384
Maybe it's time I stepped down to stage 2 - I was always told xHP wasn't to be a concern as it doesn't hurt the trans, I was always skeptical of that though haha. I guess if it ain't broken then it doesn't need touching.. unless there's a good advantage to do so say with MHD. Adaptation values below:
2015 435i - 401whp
04-23-2023, 03:31 PM | #8 | |
Rep 7,622
04-29-2023, 03:04 PM | #9 |
Rep 1
I am experencing the same thing. 5 to 6 is the problem. I have stage 1 tune and xhp stage 2. Tried reflashing to newer version today with no luck. Funny thing is, if i shift manually it feels noticeably better
04-29-2023, 03:28 PM | #10 | |
Rep 1,384
- So I flashed down to stage 2, it is noticeably smoother but also slower in-between shifts which I have sort of balanced out with the torque reduction settings, it's helped me dial in faster shifts and much louder shift blips too. Overall I think I'll stick with stage 2 over 3, not only for less strain but overall it feels much more refined. Something I did however notice was the line pressure bump option was enabled, that's something I ALWAYS avoid. Not sure when this got enabled but I'm hoping it's not been required to activate too much, I have read several posts about this ruining seals and slowly destroying 8AT's. Also I'm not sure if there's an app bug too, after flashing my new settings I happened to double check everything and noticed certain settings hadn't changed even though others had. One in particular again was the line pressure bump being re-enabled.. it took 2 flashes to get this option fully disabled.
2015 435i - 401whp
04-29-2023, 06:09 PM | #11 |
Rep 779
PDS has stated XHP stage 3 is not good for the transmission.
Considering 6th gear is a known weak clutch pack, I bet your trans is slipping. Mine was noticeable on a hard downshift into 6th. Use an actual scanner and graph the turbine speed sensor to the output speed sensor. If you see a 50rpm difference between the 2, on the hard shift into 6th, it's time for a transmission. |
04-29-2023, 06:20 PM | #12 | |
Rep 7,622
04-29-2023, 06:47 PM | #13 |
Rep 1,384
Manual shifting - maybe it's just in my head, it just didn't seem as snappy to flick between gears but adjusting the torque reduction values helped a little.
2015 435i - 401whp
