04-21-2023, 02:17 PM | #1 |
Rep 1,546
Can I do better? Proposed Winter Setup
OK, I drive in Winter, and in snow, and in the pothole-ridden Boston corridor.
Let's say I have roughly $4K as a budget (tires and wheels). Can I do better than this plan? Square setup running 275/35R19. Ignore the exact winter tires for a sec, I consider them pretty interchangeable. The wheels should be 19x9.5, I think EOM ET is 25. Seems logical that a decent load rating + low unsprung weight is a good idea to resist potholes. I'd also like something I can get in brushed/clear color, as IMO it is easier to clean than black. So it's a cliche, but WHY NOT use APEX VS-5RS? Only 19.1 lbs, can get them in clear color, under $800. (The SM-10 are probably also a cheaper option, but weight 3.5 lbs more.) Unless I care about looks or badge, I don't see any advantage to using OEMs (826M, 827M) as winters. Did I miss anything? |
04-21-2023, 03:19 PM | #2 |
Rep 2,149
Drives: i5 eDr40, G80 and F80
In Chicago here. On my G80, I ran a set 829M plus Alpins in the winter and now trying a set of 827M plus Pilot Sport All Seasons. I ordered both since tire and wheel supply chains were delayed last year and I needed something to drive on. They both finally arrived. And I kept them both because I was pretty sure I’d get a G87. So I’m not sure which ones I’m going to put on it assuming I get it but I like the way the 829Ms look on a G87 after seeing a couple of winter pics. If you don’t like black wheels you may not like either of these. The 829Ms with the above tires were $3k and the 827Ms were $4k.
04-21-2023, 03:35 PM | #3 | |
Rep 1,546
04-21-2023, 03:36 PM | #4 |
Rep 1,836
Wheel weight should not be a concern in winter conditions. It doesn't matter if they're 19lbs or 30lbs.
04-22-2023, 09:17 AM | #6 |
never could compete with Lloyd Braun
5276
Rep 5,378
You can do what I did with my G80 and run this for about $2600 all in:
VMR v710 19x9.5 et22 square with 275/35 Vredestein Wintrac Pro tires. I did keep my 15mm f / 12mm r spacers on with this, though... mostly for aesthetics. I got everything through EAS... tpms, mount, balance and shipped for $2600 back in 2021. Got me through two winters so far with no issues. Last edited by JTO24; 05-24-2023 at 06:41 AM.. |
