2011 328i N51 engine, where does this wire go?
04-22-2023, 11:20 PM | #1 |
Rep 43
Drives: BMW 335xi e92
Just finished doing a valve cover gasket for my sister and cannot remember or seem to find a place for this wire to go. I can’t find any other pictures or videos online of a similar wire so I’m getting pretty frustrated and confused, any help would be greatly appreciated thank you.
04-22-2023, 11:48 PM | #2 |
Rep 1,682
There are two ground straps off that post. I see the one going back towards the firewall, the one you are holding looks like a previous owner replaced it with a heavy gauge cable going to the secondary air valve on the stud towards the firewall side. It is slightly harder to get to, and no surprise some without a good selection of extensions just wrongly leave it off.
I think BMW calls it a noise strap or something like that. https://www.e90post.com/forums/showthread.php?t=1829056 https://www.e90post.com/forums/showthread.php?t=1848174 |
StradaRedlands4998.50 n54xdrive18.50 |
04-23-2023, 10:20 AM | #3 | |
Rep 4,088
(CHEAPER ;-) ground strap. The purpose of that is NOT to act as the Main Ground Strap. THAT is located next to Starter Motor under vehicle on US Driver side. That cable should work to prevent Audio Static. Just attach it to one of the two studs (under Nut on Stud) as shown in the attached photo, red oval. That photo is of my 3/2007 build N52K engine, but your N51 should be similar. George |
n54xdrive18.50 StradaRedlands4998.50 |
04-23-2023, 11:39 AM | #4 | |
Rep 43
