BMW 2 Series Technical Topics (G42) Cosmetic Modifications (Exterior, Interior, Lighting)
      04-23-2023, 03:39 PM   #1
Vudumonkey25
Vudumonkey25's Avatar
Drives: BMW M240i x Mercedes CLS550
V Brace Cover install - quick guide
I bought these red Vbrace covers way back in Jan of 2022 https://www.aliexpress.us/item/3256803482223279.html
Looking under the hood it seemed way to complicated especially in NJ winter.
I eventually installed https://autotecknic.com/products/aut...d-g42-2-series but when I had all the parts out for that I still couldn't see into the area of the v-braces
https://g87.bimmerpost.com/forums/sh....php?t=1965577
This thread finally showed me what needed to be done and since it was a nice day out I decided to tackle it.
First you need to remove the plastic cover that the seal sits on. Pull up on the seal and move it towards the engine out of the way. Use a trim tool to lift up the 4 push in retainers then pull up the their base
Once those are removed you need a trim tool to remove the plastic section. You can see the 3 sections that all have 2 tabs. A little wiggling and a trim tool pops these out.
Now onto the main part
You need a t30
There are
  • 8 black bumper bolts with washers (red)
  • 4 black bolts with yellow markings on the v brace guard (purple)
  • 3 silver v brace guard bolts (yellow)
Remove all the above bolts and put them aside. I circled them in the first image
Slide the bumper out from under the silver clips circled in green. You just need to push it towards the front of the car and they slip right out.
Once you work out the v brace cover take a rag and give the braces a wipe.
The v braces are longer than what I ordered so I used a hacksaw to remove about 3.5" you could probably take up to 4" off
Starting at the farthest point I just apply pressure and "snapped" them on
Now putting it back together you do the reverse. I got the v-brace guard back into place then clip the bumper into it. I then put the silver bolts (yellow in pic) and black v guard bolts (purple in pic) back in. After they were all by hand in I started putting the bumper bolts back in (red in pic)
Once all the bumper bolts were seated I snugged down the silver and black bolts that hold the v brace guard into place
I closed the hood. This allowed me to push the bumper forward and get good spacing back between the hood and bumper. The clips held it in place pretty well.
I tighten the bumper bolts as they lined up
I repeated this 2 more times just to make sure the lines were all good.
Snapped the plastic seal cover back on and put the retaining clips back in. Get the car nice and hot and see the results
Name:  bolts colors.jpg
'22 M240i BSM, Shadowline, Black 791M wheels, Red Calipers, ///M Carbon Front Lip, ///M Carbon Spoiler, ///MCarbon Door Sills, Milltek Catback w/Black Tips, Dinan Carbon Intake/Engine Cover, AA Catted DP, Dalher Valve Controller, OEM+ Strut Bar, Red Start/Stop, Floating center caps, TLG Mud Flaps, Black Badges, Led Projectors, 50th Emblems, Carbon Diffuser/Mirrors w/smoke signals/Side Wings/Cooling Shroud/KIES fire extinguisher, Yellow DRL
Ruebarb416.50
viperx100680.50
Rag9000125.50
Coconut807.50
grooveK146.50
VegasG42696.00
BlueLEDz223.50
      05-07-2023, 02:16 PM   #2
MrPickles
MrPickles's Avatar
Drives: 2023 M240ix
Did this today... Appreciate the write up!
      05-07-2023, 02:23 PM   #3
Vudumonkey25
Awesome! Looks great. Did you use the same snap on style and cut them down? Or a wrap?
MrPickles206.50
      05-07-2023, 02:45 PM   #4
MrPickles
MrPickles's Avatar
Drives: 2023 M240ix
Yep, snap ons. Got them on ebay. Had to cut about an inch and a half off of each.
      08-11-2023, 08:47 PM   #5
Vudumonkey25
Video for the carbon fiber kidney surrounds is the same steps for teh v-brace covers if you rather follow a video
