04-26-2023, 12:29 PM | #1 |
Rep 30
M240i service intervals ?
ok just ordered a new M240i ,the sales guy was very vague to say the least ,what are the recommended service intervals inc brake servicing .
trying work out if to buy the service pack ,i do low miles but a lot of short journeys about 6k a year. |
04-26-2023, 12:49 PM | #2 | ||
Rep 149
04-26-2023, 12:54 PM | #4 |
Rep 201
Drives: 2023 BMW 240i xDrive
I traded my 2015 M235 with 72k miles on the original brakes and still hadn’t tripped the wear sensors. Rear pads were gettin real close though. Strictly street driving with mostly highway mileage. Just an example.
2023 BMW M240i
2015 BMW 235xi Alpine White, Coral Red Dakota.Traded 2009 BMW 328xi Alpine White-Traded |
04-26-2023, 01:15 PM | #5 | |
Rep 149
The maintenance booklet doesn't have your typical schedule and table of maintenance like your typical car, say a Toyota Camry. It really relies on the onboard computer.
04-26-2023, 03:04 PM | #6 | |
Rep 2,094
I will probably do less miles than you but in 5 years you will get minor and major service, vehicle check and a brake fluid change. Service is time or mileage based whichever comes first. Yours will end up time based. Oil - every 2 years ( alternate minor /major service) Brake fluid first one is 3 years then every 2. Vehicle check every 4 years. An oil change with micro filter on its own is £346, brake fluid service £71, oil service with micro filter and spark plugs £636. You’ll also have fluid disposal charges and standard scope costs on of that. God knows what the price will be a few years down the line so also safeguards against price rises. Note, brake pads are not included as a service item. They are consumables. |
04-27-2023, 02:22 AM | #7 |
Rep 122
Imo the service pack (as it is currently*) is a no-brainer. For a start it locks in the price of routine servicing for 5 years.
* they change it from time to time. It's last incarnation wasn't worth having in my view, the one before was and it is again now.
G42 M240i xDrive. Brooklyn Grey, 19" Bicolour Double-spoke style 893 M alloy wheels with performance tyres, Technology Plus Pack, M Adaptive Suspension, Harman/Kardon Surround Sound Audio System, Heated Steering Wheel, Aluminium Rhombicle Interior Trim
Nate48150.00 |
04-27-2023, 08:52 AM | #8 | |
Rep 1,200
With my 230i I changed the oil early: At ~600 miles, ~1300 miles, and ~5500 miles. This last change was last October just before winter. The car doesn't get driven in bad weather or road conditions but I wanted fresh oil in the engine. Would be changing it now at the start of the driving season but I traded it in (with 7026 miles) for a M2 on April 14. (The M2 is booked to get an oil/filter service (not part of the free scheduled service that came with the new car) Monday and it should have around 600 miles. At 600 miles is when the 2nd phase of break in begins. I'll have the car in at 1200 miles (end of break in) for its break in service (which is part of the scheduled services and thus free). For brake servicing that is pads/rotors R&R that depends upon usage and the vehicle. Have managed up to 100+K miles from brakes (Porsche Turbo) to an estimated less than 30K miles with my Hellcat. The difference was not the power (Turbo: 420hp; Hellcat: 707hp) but the difference in weight. Turbo: 3500lbs; Hellcat: 4600lbs. And the Turbo was a manual which provided more engine braking -- but I didn't downshift to get more braking (and the clutch was still quite good at 161K miles) -- while the Hellcat was equipped with an automatic and there was not much engine braking to be had. However, based on my experience over the years even if BMW doesn't call for brake fluid services I'd recommend you have this done every 2 years. While brake fluid makers I think call for this Porsche no less called for it as well. I adhered to the 2 year fluid service schedule but I felt it a bit overkill. However, I let it go once and while the brakes were not manifesting any issues the clutch (and transmission) were. This is because the clutch hydraulic system shared fluid with the brake hydraulic system and the clutch hydraulic system proved to be quite sensitive to the past its change by date brake fluid. After the past due brake fluid service done (both the brake system and clutch systems were flushed/bled) the clutch action was once again good and transmission shifting woes were no more. Really quite a striking change and for the better. While the brakes weren't manifesting any signs of any issues clearly the fluid was "bad" and a brake fluid service is way less expensive than renewing brake calipers, master cylinder, hydraulic lines, and clutch master and slave cylinders. |
04-27-2023, 12:30 PM | #9 |
Rep 71
you can always add it later. Added it on my wifes F29 at about 79k kilometers and had her brakes changed for "free" shortly after.
'04 RX8 - sold
'03 350Z - sold '10 Z4 35i - RIP '22 m240i |
04-27-2023, 01:54 PM | #10 | |
Rep 2,094
The brakes change above is a red herring. Pads and discs are not included in the service pack. |
04-29-2023, 11:24 AM | #11 | ||
Rep 706
It is quite confusing, as the plan details change by county (US is different than UK), and they vary by model year, and there are various BMW plans that cover different stuff. Note: Ultimate Care+ does cover brake pads, while the standard Ultimate Care covers only fluid. See plan descriptions below:
Here is the breakdown for US (from 2/04/2022 BMW) Quote:
04-29-2023, 01:52 PM | #12 | |
Rep 2,094
It’s a “hook” to get out of warranty vehicles without a service plan to dealers for their service. Most go to a good indy in that circumstance. |
05-01-2023, 06:55 AM | #13 | |
Rep 71
inclusive plus: Front Brake Pads and Discs Rear Brake Pads and Discs Clutch (if worn)* Windshield Wiper Blades
'04 RX8 - sold
05-01-2023, 08:22 AM | #14 | |
Rep 2,094
You said service inclusive could be added, not service inclusive plus as you now added above. In either case it’s irrelevant for the OP as there is no service plus inclusive in the UK and he asked about the service inclusive. https://www.bmw.co.uk/en/topics/owne...E&gclsrc=aw.ds |
09-14-2023, 08:39 AM | #17 |
Rep 2,094
