05-07-2023, 09:07 PM | #1 |
this is the way
21042
Rep 9,154
IND | G87 M2 Build with Front Lip Painted Body Color
![]() Featured on BIMMERPOST.com |
51
ronin130131129.50 Albator_IIII1077.00 AlpineBoost3888.00 02M3ForMe4361.00 JY01715.00 jas1651638.50 MikeM6155.50 M3N4CE155.00 nathanm4692.50 RockinPA4894.00 Vervain493.50 Quadruple VANOS1461.00 MaC-N54-E82633.00 BMWGirlFL7033.00 peelerec1502.00 JSP///M4C106.50 2srsman97.50 bholler5586.00 Tenac4845.00 M3 boi3224.50 zizikos0.00 ellipsis2121681.50 M3WC3867.50 5LEEPR_G011113.00 Sedan_Clan27312.50 IND-Distribution10233.00 JustChris17703.00 Vancouver_M440183.00 -EndOfAnEra-664.50 chicagofan0020760.50 Galandel230.50 M3ANSPEC394.50 TractionControlDelete4725.00 DNYC1919477.00 spammysammich2199.00 Bimmerfun8210198.00 Silverlining_m21757.00 |
05-07-2023, 10:18 PM | #3 |
![]() ![]() 635
Rep 255
It really amplifies the vertical pieces which I'm not sure is good.
I prefer it the way it is from the factory. |
10
StickyPickle1632.00 TrentMeister3065.50 ScottyK329106.50 JustinHEMI7526.50 Connors5453518.00 2srsman97.50 GDouble33519.50 GuyOh1253.00 DailyDownshift523.00 rcouchh2675.50 |
05-07-2023, 10:54 PM | #4 | |
![]() ![]() ![]() ![]() 1632
Rep 785
For now I think the black looks better than this but I appreciate companies are actively looking to improve it. |
05-07-2023, 11:52 PM | #5 | ||
this is the way
21042
Rep 9,154
23
Albator_IIII1077.00 dukat136.00 RockinPA4894.00 pw497.00 StickyPickle1632.00 pizza2401220.50 M3WC3867.50 2srsman97.50 Vancouver_M440183.00 -EndOfAnEra-664.50 GDouble33519.50 CFO292.00 chenry2420.50 rwemersonrw542.50 ballagans14.50 Ev0lutionx1168.00 DBV868.50 Psychos1s563.00 ComingInHot406.50 JTO246107.50 Blue Angel1366.50 Detailers Domain2544.00 MASHCT1476.50 |
05-08-2023, 07:50 AM | #7 |
![]() ![]() ![]() ![]() ![]() 1640
Rep 850
Looks so much better. And this if aftermarket. If BMW designed it this way in mind it would probabaly look even better. LCI maybe?
05-08-2023, 07:50 AM | #8 |
Rep 25
I want it!! On my ride!!
It should have come from factory. |
Kevin_The_Clean14744.50 |
05-08-2023, 07:51 AM | #9 |
![]() ![]() 4722
Rep 1,774
Drives: 2022 X5 m50i
Looks better than factory setup. Still missing something to look as aggressive as the rest of the car.
25 G70 760i Msport
25 RR SV E2 RETIRED BMWs: '23 F92 M8 Comp / '22 G05 X5 m50i / '18 F15 X5 50i / '16 F10 550xi / '13 BMW F10 535i / '07 E64 630i / '03 E65 745i / '95 E34 540i / '89 E30 M3 |
05-08-2023, 07:52 AM | #10 |
![]() 3539
Rep 1,690
Wow way way better
chrisk03162.00 Kevin_The_Clean14744.50 |
05-08-2023, 07:59 AM | #12 |
Bimmer without rage
244
Rep 103
Drives: 2022 X3 M40i | 2020 X5 M50i
I had the exact thought before. Definitely complete the look of the front end
05-08-2023, 08:12 AM | #14 |
Not great. Not terrible
7527
Rep 2,700
I'm glad they did that. Definitely not for me.
Current: 2024 BMW X3 M40i.
FlashmanM23.00 ///M TOWN33443.00 |
05-08-2023, 08:16 AM | #15 |
![]() 335
Rep 154
I like it. Now give it dual headlamps and it would be (almost) perfect.
05-08-2023, 08:44 AM | #17 |
![]() ![]() ![]() ![]() ![]() 693
Rep 734
Actually I kinda like it!
05-08-2023, 08:46 AM | #18 |
![]() ![]() 6093
Rep 9,183
While i'm still not a fan of the front fascia this looks way better. With the right front lip design this has a lot of potential.
Alan
05-08-2023, 09:08 AM | #19 |
![]() 240
Rep 204
I like it in theory and if I don't look too closely it looks good. But to me where it goes wrong is that it doesn't make sense with the rest of the bumper. It emphasizes that the painted lower section isn't connected to the intake sections of the bumper, as opposed to being all one piece as you'd expect. That and the places where the vertical pieces connect to the lower section look too obvious to me that it's been painted and isn't factory. I think you'd need an entirely new bumper that includes an integrated painted center section to truly do this right. Which is probably not worth the cost or the effort, but I can't see another way of doing it such that it would look correct.
05-08-2023, 09:09 AM | #20 |
![]() ![]() 1596
Rep 6,441
Overall I like the idea of highlighting the center section and giving it more definition. It makes the car look more complete.
I dont think I would have gone with the same painting approach though. As others pointed out, the vertical fins that slice into the colored lip look uncomfortable. Same time, intakes either side look rather big still. I propose something like this instead: 1) use the natural curve for all three intakes as the area of demarcation for where painted and unpainted bits are (green) 2) may be consider painting lower lip of the side intakes to match the center one, but thats optional (blue) 3) consider making sure that the black vertical splitters meet the lip thats also black near them, so they dont stand out so much. (red) EDIT: as pointed out, the IND side scoops are carbon, factory ones are body painted. This makes my 2) point irrelevant. From stock, you would do pretty great just by highlighting the edge of the lip, without getting into the "trees" of the vertical slats.
F30.F11.E86.E90.E90.E36 Last edited by Tallest; 05-08-2023 at 12:39 PM.. |
twistedspoon161.00 Doubleojon13.50 GuyOh1253.00 DBV868.50 Kevin_The_Clean14744.50 JTO246107.50 Clippy56.50 |
05-08-2023, 09:13 AM | #21 |
![]() ![]() ![]() ![]() 1461
Rep 938
Well executed. Looks much better. Thanks.
05-08-2023, 09:18 AM | #22 |
Rep 785
Yup, pretty much. From a distance the way it was done by IND looks fine until you get up close to it and see how the paint goes around the vertical slats. Gives it kind of a “teeth” appearance imo. Just doing the front edge of the lip would look much better to me but again, I’m glad companies are experimenting with this. We’re sure to have some great options to change the look of this in short time.
