E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Engine sudden shut down problem
Reply
      05-18-2006, 11:58 PM   #1
wu852
Drives: Alpine White 325i
Has anyone had this problem... I drove from pittsburgh to Boston today and on the way, my car sometimes just turned off by itself. I would b driving then i shift the car into neutral ( have a manual). and before i know it, the service engine soon light turns on and the power steering is off, etc etc. I have to restart the car before everything gets back to normal but after a while, it will happen again. Happaned about 3 or 4 times on the drive up. Any ideas or suggestions?
thanks
      05-19-2006, 12:07 AM   #2
wu852
also should I be concerned? is it safe to drive back to pittsburgh...? I dont feel that safe. for example when turning off a ramp, suddenly the powersteering disengaged and i almost couldnt make the turn off the ramp... kinda dangerous....
      05-19-2006, 12:09 AM   #3
shimshimhada
shimshimhada's Avatar
Drives: Portal
Why are you putting the car into neutral turning off a ramp? Or do you mean when you pass through neutral?
Doesn't sound normal though. I would take it slow, if you need to keep driving.
      05-19-2006, 12:19 AM   #4
wu852
sometimes when cruising i put it in neutral....its quieter if you change the exhaust like i did... lol but yeh. is that normal? It seems like the the car is stalling without actually stalling, just the aftereffect of stalling
      05-19-2006, 12:20 AM   #5
shimshimhada
Drives: Portal
lol, you shouldn't be putting the car into neutral at higher speeds. Just keep it in gear, and that's not normal.
      05-19-2006, 12:43 AM   #6
difush
Drives: E90
I have an automatic and it never happen to me. I say its very dangerous to have the engine stalled when driving. It happened my dad's Merc. before, I was going down a pretty steep hill and the engine stalled. Its not just the power steering, the power brakes also went and the stopping distance, I would say more than doubled. It a fortunate thing that there were no cars in front.
For the Merc., the dealer told us that it has a faulty engine management computer or something and they change it and the problem was gone.
      05-19-2006, 01:52 AM   #7
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
Sounds potentially deadly. Being intermittent may cause some fault finding issues but maybe the service computer can delve deep into the ECU and extract the suitable info.
Be safe and let your dealer know as soon as you can.
All the best.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      05-19-2006, 08:29 AM   #8
stack
Drives: 06 325i
Mine did that when I got some bad Gas. I had to have the car towed and the tank drained. That kind of stuff always happen when you are out of town. I couldn't get the gas station to return any of my calls and I was not going to drive 6 hours back there so in the end it cost me $400 to be fixed
stack
      05-19-2006, 09:33 AM   #9
clutch09
clutch09's Avatar
31
Drives: '08 320i
Yo WU,
Walk Back.
Sounds pretty serious man, have you given Alex a call? Call if you need anything. The above post makes some sense, when did the car first start stalling?
      05-21-2006, 08:08 PM   #10
Driv3r
Driv3r's Avatar
Drives: 2006 E46 M3 ZCP
2006 325i  [0.00]
thanks
Oh dang....you have an exhaust too and this happens to you too?! (i have Eisenmann)
-I have a manual and while i was on the highway i do the same as you and occasionally coast in neutral.. while doing this my car suddenly turns off and wheel stiffens, it was pretty scary. One time while i was on the highway, it shut down and so i had to time to react, i just popped it into a gear and the engine came back alive...im worried about this problem too...if you get it solved let us know..
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting
      05-21-2006, 09:00 PM   #11
sblument
sblument's Avatar
Drives: 2006 330i
2006 330i  [0.00]
if that happened to my car I would take it to the nearest BMW center and have it looked at, immediately. Sounds dangerous.
2006 330i, SP, PP, fold down rear seats, sparkling graphite, black leather, metallic trim.
      05-21-2006, 09:00 PM   #12
sblument
sblument's Avatar
Drives: 2006 330i
2006 330i  [0.00]
uuh, assuming you've got enough gas, haha
      05-22-2006, 01:12 AM   #13
wu852
yeah its really shady... i can reproduce the problem everytime now... what happnes is if im driving and i shift to neutral and let teh car just roll.... the rpm needle kidna goes bazurk for a while and then stops at 0 rpms.... the service engine light turns on.... and the power steering breaks etc dont work.... this is potentially very dangerous and dont know if i should be talking to BMWNA about this.....
      05-22-2006, 01:19 AM   #14
wu852
o i forgot the rpm needle starts to go crazy when im rolling and i start to apply the breaks... then everything goes nuts...
      05-22-2006, 11:51 PM   #15
ages944
ages944's Avatar
Poland
99
Drives: E90 325i
crud.
This sounds just like a problem that a lot of the E46 owners are experiencing with their Vanos systems. Do you by chance have a really rough idle with erratic RPMs, or do your problems only appear while in motion?
Whatever the case, the dealer needs to see the car ASAP, imo.
      05-23-2006, 12:06 AM   #16
wu852
happens only while in motion...... no idea whats going on. iv had this car since last august and this is the 1st real problem iv had... bringing it to the dealer first thing in the morning.
      05-23-2006, 06:02 PM   #17
wu852
so i just got a call from the dealeship and they claim theres no problem wiht the engine... they were unwilling to run more diagnostics until i put my stock air box in. Does anyone thingk the fujita intake could really contribute to this.... as of now i guess i have to put the stock box in and bring it back to the dealership...........
      05-23-2006, 06:13 PM   #18
ages944
ages944's Avatar
Poland
99
Drives: E90 325i
lol, that sounds a bit retarded to me. I thought the whole point of aftermarket airboxes was to allow for more airflow.... It also sounds retarded to me since you don't seem to have mods that are any different than half of the other ppl on this board.
that being said, dealerships can be a PITA that way. I would change your airbox back to stock, but I can see the next line being "We won't do anything till you change your exhaust back to stock..."
either way, good luck with it all, and keep up posted.
      06-03-2006, 10:30 PM   #19
Lucid4000
Lucid4000's Avatar
Drives: 335i AW Sport 6MT
2006 330i Sport  [0.00]
What was the out come of the problem?
      06-03-2006, 11:05 PM   #20
RyBMW
RyBMW's Avatar
78
Drives: X5
2012 BMW X5  [0.00]
2008 335i  [0.00]
This problem was happening to some G35 coupe owners also. The cause of the problem was the aftermarket intake. It was only this one brand of intake that was causing the problem.
How long had you have your intake installed? Try removing the intake and put the stock air box in and see if the problem still exists.
New: 12 X5 xDrive35i Premium Alpine White/Cinn Brown
Old: 08 E92 335i|Space Gray/Coral Red/Gray Poplar
Old: 06 E90 330i|Black Sapphire/Black /Burl
      06-06-2006, 07:40 PM   #21
MIKEYMIKE
MIKEYMIKE's Avatar
Drives: 330i 6mt
Ahhhhhhh, so you have an intake.
Well, I know for a fact a lot of guys with G35's were having their engines going out on them when they had cold air intakes installed.
Turned out the intake was getting so much air at higher speeds it was causing the engine to stall out. The remedy was to put a windshield on there so the wind wouldn't hit it straight on...or just remove it.
      02-19-2008, 03:49 PM   #22
Alex@TAG
Alex@TAG's Avatar
Drives: 16 RS7, 488 Spider, i3 REX, 57
anyone still having this problem?
they hadto replace my ENTIRE Vanos system about 2 months ago, engine cut out on the freeway, then once i got it running again, it was powered down bigtime and constantly stalled.
they replaced the vanos unit, then 3 months later (this weekend) im driving on the highway, shuts down, service engine soon (chk engine) comes on, and is powered down. I pull over, turn it off. once back on, the car runs ok just a bit in limp mode, then yesterday, i start the car, and its fine feels strong as ever but now its guzzling gas like its its job! i went thru a quarter tank in under 35 miles...
Reply
e90post
