05-31-2023, 07:02 AM | #1 |
![]() ![]() ![]() ![]() 1254
Rep 637
G87 M2 vs Porsche Cayman 718 GTS - Drag Race
![]() Featured on BIMMERPOST.com ![]() |
13
Mani5917665.00 ronin130131129.50 AlpineBoost3888.00 02M3ForMe4361.00 SebG87277.00 RichyN37.50 M3 boi3224.50 CatchF22DirtyF30201.00 MrLoneWolf21052.50 bcjbmwm3340.00 Tenac4845.00 asianbeamer1.50 ///M TOWN33443.00 |
05-31-2023, 07:11 AM | #3 |
Not great. Not terrible
7527
Rep 2,700
Summary?
Current: 2024 BMW X3 M40i.
pizza2401220.50 antzcrashing1956.00 |
05-31-2023, 07:11 AM | #4 |
Rep 637
9
JustinHEMI7526.50 deleted_807865_k0a0df9ee6876.00 pizza2401220.50 ScottyK329106.50 M3 boi3224.50 CatchF22DirtyF30201.00 starlord725.50 Ikester192224.00 asianbeamer1.50 |
05-31-2023, 07:14 AM | #5 |
![]() ![]() ![]() 744
Rep 494
05-31-2023, 07:29 AM | #7 |
Rep 494
They did call out the 718 is significantly more expensive. In AU, it's a 70k difference, roughly 45k USD equivalent.
JustinHEMI7526.50 ///M TOWN33443.00 |
05-31-2023, 07:45 AM | #8 |
![]() 266
Rep 206
Are you a YouTuber and need an infusion of cash? Make a drag race video!
05-31-2023, 08:06 AM | #9 |
![]() 630
Rep 186
Do they ever explain in the vids how they got an M2 to weigh 3950LBS???
05-31-2023, 09:21 AM | #10 |
![]() 2400
Rep 1,192
All I got from that video is that the 718 is overpriced...
2020 M2C
2018 M2 LCI Gone 1M, 991.1, 991.2, 718S, 991.2 TT, R8 Spyder RWD ![]() |
05-31-2023, 09:54 AM | #11 |
![]() ![]() 1993
Rep 1,759
Really like the look of that red M2, looking mean and muscular
05-31-2023, 10:09 AM | #12 |
![]() 6481
Rep 3,877
people underestimate how much an advantage cup/track tires give.
hopefully TH eventually gets a manual car on regular tires soon.
2018 Porsche GT3 6MT 2023 X3 M40i Previous: Ferrari 458 | R35 GTR | F80 M3 | F87 M2c | E46 M3 | E36 M3 | Scion FRS |
05-31-2023, 10:11 AM | #13 |
![]() ![]() ![]() ![]() 3888
Rep 870
The faces of defeat
ronin130131129.50 RoidRage1503.50 02M3ForMe4361.00 JustinHEMI7526.50 turbowilly64.00 baron951899.00 kozzi977.00 MrLoneWolf21052.50 |
05-31-2023, 10:15 AM | #14 |
![]() 137
Rep 63
Question about the bmw launch control: there is no way to select the launch RPM? I remember in the previous generations there was a switch, you could set 2500, 3000, ...
The GTS is rated at a 4.7s 0-60 and G87vat 3.9, both conservatively. It should have won that drag race. |
zero213288.50 |
05-31-2023, 10:35 AM | #15 | |
![]() 3289
Rep 1,843
They clearly didn't weigh the car and they definitely post the highest possible weight. |
atopa2002235.50 |
05-31-2023, 10:44 AM | #16 | |
![]() ![]() 6753
Rep 2,737
Also, yes the G87 should have won that roll race, the car is at a minimum 500 HP, probably somewhere between 500 and 550. Also, one thing to note is that track times will vary on different times of day let alone different days. Meaning, unless you take every car on their list and race them at the same time, the list is just for fun. Which is what this channel is, it's pure entertainment and I actually love it.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed 2017 M3 YMB Executive, 6 Speed, ZCP Everything else: 2024 Wrangler 4Xe 2020 MK 7.5 GTI |
JustinHEMI7526.50 atopa2002235.50 |
05-31-2023, 10:57 AM | #17 | |
![]() 6481
Rep 3,877
https://www.caranddriver.com/reviews...y-the-numbers/ 0-60 in 3.8, and trap speed of 120. its similar the G87. But mid engine and no turbo usually result in a more consistent launch. the ecu can make minor adjustments to throttle since there is no turbo to keep spooled up
baron951899.00 |
05-31-2023, 11:18 AM | #18 | |
7527
Rep 2,700
05-31-2023, 11:19 AM | #19 |
![]() 3949
Rep 1,767
So much this. I won't daily drive a GTS. Even if the GTS was significantly faster, it wouldn't change my calculus.
05-31-2023, 11:20 AM | #20 | |
![]() 3949
Rep 1,767
2) Did your CA not spend a hour with you going over all the features of your car? They should have! |
Bumpinjeep6752.50 |
05-31-2023, 11:21 AM | #21 | |
![]() 3949
Rep 1,767
Also the manual asks you to not do launches before break-in, IIRC. |
05-31-2023, 11:22 AM | #22 |
7527
Rep 2,700
Yep both true.
