05-31-2023, 08:05 AM | #1 |
Not great. Not terrible
7445
Rep 2,700
295 rear 275 front.
When I'm done with these Pzeros, I'm probably going to want to go to 295/30/20 in the rear while staying OEM size up front.
Any concerns with that? I think the 285-295 increase should be negligible in terms of changing dynamics, but wanted to see if I should be thinking about bumping the front from 275 to 285 as well. Thanks! (Not interested in 305s)
Current: 2024 BMW X3 M40i.
05-31-2023, 09:26 AM | #2 |
Rep 2,987
Drives: A Family Sedan
Why do you want to do that specifically? We can discuss it based on your goals.
One thing to note is that the rear will be raised a bit, increasing the rake, since the tires will be taller in the rear. But not by much. |
05-31-2023, 09:39 AM | #3 | |
this is the way
18157
Rep 8,527
05-31-2023, 10:21 AM | #4 |
Rep 63
I wouldn't worry about understeer that much, Porsche runs some crazy staggered setups on the 911 GT3, like 315R/265F.
Stay within the traction limits of the front tires and you will be fine. Add some negative camber to improve surface patch contact. |
05-31-2023, 11:13 AM | #5 | ||
7445
Rep 2,700
Yes there is a little difference, but not enough to matter, IMO. Quote:
Thank you!
05-31-2023, 11:16 AM | #6 |
7445
Rep 2,700
Here's upsizing the front. Seems like bumping both may be the best option.
Chet for short203.50 |
05-31-2023, 01:02 PM | #7 | ||
this is the way
18157
Rep 8,527
Let's do some number crunching. 275/35/19 = 675 mm diameter 285/30/20 = 679 mm diameter Difference = 4 mm 285/30/20 = 679 mm diameter 295/25/21 = 681 mm diameter Difference = 2 mm There you have it. I would not deviate from these figures. You don't want the tire diameter to be more than 4 mm larger than stock when you upsize your tires. Of course there might be some more wiggle room but you may then start rubbing, etc. Notice, you need a taller wheel in the rear to get close in diameter. If you try to put a 295 on 20" rear wheel the overall diameter will be 656 mm which is far too small. This is also why BMW had to put a larger wheel in the rear to accommodate a wider tire. |
05-31-2023, 01:32 PM | #8 | |
7445
Rep 2,700
The bolded will depend on wheels and offset, no? My new wheels are 19x10 ET14 front, 20x11 ET11 rear. OEM are 19x9.5 ET20 front 20x10.5 ET20 rear. I'm missing something, for 295/30/20, I'm coming up with 686mm, not 656mm?
05-31-2023, 01:42 PM | #9 |
Rep 63
I have a crazy idea I may try when I get the car:
Keep the same front (275/35r19) Go bonzai in the back with 325/30r19 It works because the total diameter on 325/30r19 is the same as stock. Once you lower the rear tire pressure to adjust for the bigger width, you will get crazy acceleration from 0-60 ans on track you won't get as much power-on oversteer when getting out of slow corners. But you need 12x19 wheels for this. This setup will also look better because the sidewalls will have the same thickness between front and rear. And the ride should get comfier. I don't know if the 325 will fit but if you have 1" between the tires and suspension, I think it will. You just need to find a 12" wheel with a reasonable offset (less than ET44). Downsides are increased *static* understeer, tramlining and reduced brand choice when it comes to tire (the big ones all make 325 tires both for street and track). Last edited by babym_gen; 05-31-2023 at 01:48 PM.. |
05-31-2023, 02:11 PM | #10 |
Rep 51
that is a bad example, there is not weight on the front axle of a gt3 vs an m2
InspectorSeb115.00 |
05-31-2023, 02:33 PM | #11 | |
this is the way
18157
Rep 8,527
Offset doesn't matter when it comes to the overall diameter of the tire. Wheel size does matter because it dictates what tire size you'll run. It all has to do with size of wheel you are putting the tire on and the tires aspect ratio.
I used this tire size calculator: https://www.wheel-size.com/calc/ |
05-31-2023, 02:42 PM | #12 | |
7445
Rep 2,700
I also used that tool for the scenario I'm considering and it seems like it's good to go; Front: OEM to 285/35/19. Rear: OEM to 295/30/20. OR I might just live with the "stretch."
05-31-2023, 02:49 PM | #13 | |
this is the way
18157
Rep 8,527
JustinHEMI7445.00 |
05-31-2023, 02:50 PM | #14 | |
7445
Rep 2,700
Tag18156.50 |
05-31-2023, 02:56 PM | #15 | ||
7445
Rep 2,700
Here's part of what's confusing me with some of your input (which I appreciate by the way, it's the point of the thread, to help me ensure I think through all the possibilities!) You said putting a 295 on a 20 would be far too small. That's a big part of my confusion and when re-reading, I'm still confused on that. Also, out of curiosity, why would you use that package to compare to? Is it specified for G87?
M3SQRD2164.00 |
05-31-2023, 03:03 PM | #16 |
7445
Rep 2,700
By that calculator for rears;
285/30/20 to 295/30/20 = +6mm For front; 275/35/19 to 285/35/19 = +7mm In both cases the calculator yields positive results.
05-31-2023, 03:32 PM | #17 | |
this is the way
18157
Rep 8,527
Now do the same thing for a 21" wheel. 295/20 21" will be 651 mm, still too small. But, if we go up to the next aspect ratio size we're golden. 295/25 21" is 681 mm, only 2 mm more than stock. |
05-31-2023, 03:46 PM | #19 | |
Rep 63
Bigger rear tires = more understeer More weight on the front = more oversteer So all in all, less static understeer than the 911 with the bigger rear tires. |
05-31-2023, 03:47 PM | #20 |
this is the way
18157
Rep 8,527
05-31-2023, 03:56 PM | #21 | |
7445
Rep 2,700
Not by much according to the calculator. 285/30/20 to 295/30/20 = +6mm
