06-02-2023, 10:16 PM | #1 |
Rep 165
E85 Mix On California Gas
Good Evening,
I am extremely new to the BM3 platform and logging and I decided to try out 1 gallon of E85 mix today. I am from Southern California and I have a OG M2. The reason i did this was because after getting all the recommended mods for BM3 Stage 1 91ACN I was not pleased with the results. Below I will attach logs I took yesterday running BM3 Stg 1 91ACN with 1 gallon of E85 and next I will post a BM3 Stg 1 Octane (non-ACN) from the same fuel batch. With these logs my biggest worries were my ignition timings. My HPFP target and actuals seemed pretty good in my opinion. If I could get some feedback on it that would be amazing. I appreciate Nezil , tom @ eas , and Orange fever for giving me their two senses and knowledge. Mod List: CTS CP CTS CAI CSF FMIC 3rd gear pulls: https://www.bootmod3.net/log?id=6479...0b43bddc39ad6a (BM3 Stage 1 91ACN) https://www.bootmod3.net/log?id=647a...90c6ae6bddb77b (BM3 Stage 1 91 Octane) 4th gear pulls: https://www.bootmod3.net/log?id=6479...0b43ba811abf12 (BM3 Stage 1 91ACN) https://www.bootmod3.net/log?id=647a...0b4312fd905649 (BM3 Stage 1 91 Octane) https://www.bootmod3.net/log?id=647a...729b3aca5e2082 (Bm3 Stage 1 91 Octane) https://www.bootmod3.net/log?id=647a...729b3e18a3a04b (BM3 Stage 1 91 Octane) |
06-03-2023, 11:45 PM | #2 |
@lbb_kev
496
Rep 516
The ACN logs don't look bad in my opinion. The non-ACN ones look like more octane is needed - maybe two gallons of E85 instead of one.
Remember, 91 ACN is truly terrible. I've also noticed recently that pump E85 is testing more like E70-E75 vs. the usual E80 in SoCal. I've also been through this rodeo before. I wouldn't waste a lot of time trying to make power on any of the stage 1 maps or ACN maps. Save the headache and worries and stay with stock tune or get a downpipe and hpfp to run the stage 2 e30 maps.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
F87Tomei270.00 |
06-06-2023, 03:08 PM | #3 |
Rep 569
I have had similar experiences to you. Dirty looking logs on Stage 1 and Stage 2 91 octane using SoCal gas (OC, LA, and SD). I typically run Stage 2 91ACN without issue, and occasionally grab some E85 and use the Stage 2 E30 blend. I do not have an upgraded HPFP, and have not had issues since I began using an ethanol tester at the pump. Like -Eidos said, there is some significant variance in the ethanol content at the pump. I believe the pump handles actually specify that they can range between 50%-83%. My HPFP is not maxed out with a 30 blend, and my timing corrections are minimal or nonexistent.
I have fairly similar mods to you, with the addition of a high-flow cat. |
F87Tomei270.00 |
06-06-2023, 09:59 PM | #4 |
Rep 255
Agreed. Tried a lot of "set-ups" myself, explored a lot.
Stop messing with stage 1/2 91oct in SoCal. I've had perfect logs with stage 2 91acn(Shell 91). It's nice to drive, enough to have fun. But I think sweet spot for N55 M2 is stage 2 E30 if ethanol is available. linear power band towards redline like stock tune. especially with good tires. My butt tells me that stage2 E30 spools a little early than stage2+ E30. Currently I'm running Stage 2+ E30 with upgraded HPFP for daily street sprinting or freeway pulls. More boost, more mid range torque but power will be dying down fast after 6500rpm. If I'm pushing the car on track or any situation I need to keep rpms at high range, I'd stick with stage 2 E30. It just feels great. |
F87Tomei270.00 |
06-12-2023, 01:14 PM | #5 |
Rep 165
Just put in my highflow DP, ran stage 2 91ACN, and did a dyno run over at EAS in Anaheim (super chill guys)
My timing seems to be everywhere and wondering what your guys inputs were. Mods: CTS CP CTS CAI CSF FMIC VRSF Catted DP BM3 Stage 2 91ACN Here are the results. Run 1: https://bootmod3.net/log?id=64874665ae729bdef1a17eb9 Run 2: https://bootmod3.net/log?id=648748f1d10b43cb86d886c4 Run3: https://bootmod3.net/log?id=64874b11d10b43c80b8140ee |
06-12-2023, 03:13 PM | #7 |
Rep 165
Updated links thank you
06-13-2023, 06:36 PM | #8 |
Rep 569
F87Tomei
I just put on the updated Stage 2 multimap, set to ACN 91 and I am now having a rough idle for about 2 seconds on initial cold startup that wasn't present on the regular Stage 2 ACN 91, I am going to play around with the tunes and let you know what I find. |
F87Tomei270.00 |
06-13-2023, 07:47 PM | #9 | |
Rep 165
06-14-2023, 02:31 PM | #11 |
Rep 569
My car is at EAS right now getting an engine and diff oil change, but I am going to change the tune this evening and see if that resolves the idle issue. The odd thing is that it is only on initial startup for about two seconds and then resolves, the car is operating normally with just a little bit of timing correction on power pulls etc.
06-14-2023, 03:01 PM | #12 | |
Rep 213
06-14-2023, 03:11 PM | #13 |
Rep 569
Yes, I have had the cold start cat heating disabled on my car since late 2020. With a high flow DP the car sounds like a tractor and is so loud on startup. I haven't had issues like this with the rough idle before on this (Stage 2 ACN 91) or any of the other BM3 tunes I have run, but I will trying turning it back on and see if that is related to the issue.
06-14-2023, 03:38 PM | #14 | |
Rep 165
That’s freakin odd man I hope you get it all figured out! |
06-14-2023, 06:24 PM | #15 |
Rep 569
Picked my car up from EAS, flashed the non-multimap Stage 2 91 ACN and the car is running totally normal now. No good explanation but it seems like the issue is resolved. Let me know if you end up running the snow kit, I’m intrigued by it.
F87Tomei270.00 |
06-16-2023, 08:32 PM | #16 | |
Rep 165
Glad the car it’s normal now brotha. |
CalAcacian553.00 |
